Results 1 to 7 of 7
    New ROGer Array
    Apr 2017
    3
    Maximus IX Code - MoBo believes somehting is wrong with DRAM
    Hey!
    I have an Asus ROG Maximus Code IX and it's been working perfectly, but I have a peculiar issue.
    There is a yellow LED on the MoBo that will light up when something is wrong the DRAM (memory), yet I have had no issues. The yellow light is not static either and will basically blink like an HDD-light. I have had no stability problems, all temps/performances are wonderful and I have triple checked that nothing is bothering the RAM/seating.
    After some testing, I still have no idea what might be the problem.
    I have tested through stability tests, Windows Memory Tool, BIOS and regular use. Nothing reports that anything is wrong. The issue only occurs when I get past BIOS and into Windows. When I'm in BIOS there are no lights.
    CPU: 7700k
    RAM: Corsair Vengeace RGB 2x8 3000mhz
    MoBo: Maximus IX CODE
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,247
    Perhaps you're confusing the HDD activity LED with the DRAM QLED. The DRAM QLED flashes briefly when your turn on your system. If there was a problem with your RAM, the DRAM QLED would remain lit and your system wouldn't post.
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Power SupplyPCP&C Turbo Cool 1200w
    Mouse ROG Chakram Core
    Mouse Pad Steelseries QCK Prism XL
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,463
    This little yellow/orange LED flashes like a busy hdd for me too, maybe it's a normal thing with the Code ?
    Like BlueV I'm not experiencing any problems.
    New ROGer Array
    Apr 2017
    3
    Interesting! It would be rather peculiar if it's actually an HDD-led since the manual says there are no onboard LED's of that type. Glad to know others are experiencing similar issues, though.
    ROG Guru: White Belt Array CODE MAXIMUS PC Specs
    MotherboardMAXIMUS IX CODE • BIOS 1009
    Processor7700K • 4.5GHz
    Memory (part number)Corsair Vengeance LPX • CMK16GX4M2B3600C18 ver4.31 • 3866MHz • 15-15-15-36-2CR
    Graphics Card #1ASUS STRIX 1080Ti OC
    Sound CardOnboard • SupremeFX S1220
    MonitorASUS ROG SWIFT PG279Q
    Storage #1Intel Optane 900P 480GB
    CPU Cooler2016 EKWB Supremacy EVO • Acetal + Nickel • Straight Distilled Water
    CaseCORSAIR AIR 540
    Power SupplyEVGA Supernova 850W P2
    Keyboard HyperX FPS Alloy TKL
    Mouse SteelSeries SENSEI 310
    Headset Coolermaster Masterpulse
    Mouse Pad SteelSeries QCK Limited
    Headset/Speakers 100W BLACKWEB ZULU 2.1 • Soundbar + 8" Sub • TOSLINK
    OS WIN 10 64bit
    Network RouterNETGEAR X4S • Gigabit fiber optic connection
    Accessory #1 3X Corsair Magnetic Levitation 140mm PWM case fans
    Accessory #2 2X Corsair Magnetic Levitation 120mm PWM radiator fans
    Accessory #3 APC XS 1000 • Backup
    CODE MAXIMUS's Avatar
    Mar 2017
    42
    123
    Quote Originally Posted by BlueV View Post
    Does this LED also blink while you are in windows as well or just blink between posting and windows loading only?
    New ROGer Array
    Apr 2017
    3
    Quote Originally Posted by CODE MAXIMUS View Post
    After I get past post/BIOS and see the Windows-logo it starts blinking. Then it keeps blinking as long as the computer is in Windows. It doesn't have any set pattern og predictability. It basically behaves just like an HDD-light.
  7. #7
    CaseCORSAIR AIR 540
    OS WIN 10 64bit
    Mar 2017
    42
    123
    I can confirm it is HDD activity, I have my HDD activity LED for my case connected to the Q-panel and it synchronizes with that LED behind the USB 3.0 header. Now I have done my good deed of the day it is now officially beer time. Nothing wrong with your RAM.
