Results 1 to 5 of 5
Thread: RGB strip length more than 2m
04-26-2017 08:02 AM #1
Cold_Fire_18 PC Specs Motherboard Asus Maximus VIII Formula Processor i5 6600k Memory (part number) CMU16GX4M2A2666C16 Graphics Card #1 STRIX-GTX1070-8G-GAMING Monitor Samsung C24F390 Storage #1 Samsung 850 EVO 500GB CPU Cooler Cryorig M9i Case Phanteks Enthoo Evolv ATX Tempered Glass Power Supply Corsair RM750i Keyboard Logitech K270 Mouse Lenovo M331 Mouse Pad Hyper X Headset/Speakers Creative T4 Wireless OS Windows 10 Education Network Router D-Link DIR-868L
- Join Date
- Sep 2016
- Reputation
- 27
- Posts
- 17
Hello everyone!
I bought a 5 meter long RGB LED strip and cut into 2 equal pieces for lighting up the top and bottom of my desk. Then, using a Y-splitter, I connected them to the M8F's RGB Header and they are working perfectly in all modes with very good brightness (my room is bright in the day but the light from the 5m strip is still not affected by it). At night, the strip is bright enough for me to move around my room as usual without turning on the main ceiling lights.
My concern is would this damage the motherboard in anyway? The manual only says use strips below 2m for maximum brightness. So if I can accept a lower brightness, I assume that I should be able to use this 5m strip without anything going wrong.
I am posting this to get your thoughts/experiences on this. I will post pictures in like a week when I am done with all the wiring on my desk.
Let's talk about RGB!
04-26-2017 08:27 AM #2
Nate152 PC Specs Motherboard ROG Strix Z690-F Gaming WiFi Processor i7-12700KF Memory (part number) Kingston Fury Beast 16GB (2x8GB) 6000MT/s (KF560C40B) Graphics Card #1 ROG Strix 3090 Ti LC OC Sound Card SupremeFX Monitor HP ZR30w Storage #1 Seagate Firecuda 530 1TB CPU Cooler EK Quantum Velocity2 Case Thermaltake Tower 900 Power Supply EVGA Supernova 1600 T2 Keyboard ROG Falchion NX / Strix Flare II Mouse ROG Chakram X/Chakram Core/Spatha X Headset ROG Delta S Animate Mouse Pad Steelseries Prism XL + ROG Scabbard II OS Windows 11 Home Accessory #1 2x Swiftech Maelstrom X300 D5 V2 Accessory #2 2x Hardware Labs SR2 560 MP radiators Accessory #3 Lamptron FC-5 V3 fan controller
- Join Date
- Feb 2013
- Reputation
- 386
- Posts
- 17,409
Hi Cold_Fire_18
The RGB header is capable of supplying up to 2 amps (24 watts), as long as you're not exceeding that it should be fine.
04-26-2017 10:22 AM #3
- Join Date
- Sep 2016
- Reputation
- 27
- Posts
- 17
Hello Nate152, nice to see you again.
I am using this strip.
https://www.lazada.sg/5m-12v-72w-smd...6.html?boost=2
It is stated as 72 watts. Do I assume that it is only taking in 24 watts? The header cannot output more than 12V and I suppose that the current has a limit too, that's why I think that it is safe.
04-26-2017 10:44 AM #4
- Join Date
- Feb 2013
- Reputation
- 386
- Posts
- 17,409
I imagine you're pushing the RGB header to the limit, this could impact the longevity of the header.
04-26-2017 01:09 PM #5
- Join Date
- Sep 2016
- Reputation
- 27
- Posts
- 17
I agree. When I tried white at the brightest setting, after a few seconds the lights start flickering with an increasing rate. I have to use it at a lower brightness or switch back to cyan. I guess when all the 3 leds are lighted up, it is too much for the header to handle. I will stick to only displaying colours and see how it goes. Hope I don't fry anything else on the board.
