Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    ROG Enthusiast Array
    Dec 2016
    50
    GPU Speed stuck at 109%
    Like the title says, even in idle my gpu speed is stuck at 109%. I honestly dont even know if this is normal but I dont think it is. I tried booting into safe mode and removing all drivers and then making a clean install of em. I even reset my computer as well, nothing worked.
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse ROG Chakram Core
    Mouse Pad Steelseries QCK Prism XL
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,437
    Hi Feels123
    In the nvidia control panel, manage 3d settings, do you have the power management mode set to optimal power?
    Dec 2016
    50
    Quote Originally Posted by Nate152 View Post
    Hi Feels123
    Hi, yes I do. I just tried changing it to Adaptive but it didnt work
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,437
    Try reinstalling the latest nvidia driver 381.89
    After the license agreement click custom (advanced) install then uncheck everything except the graphics driver and physx driver and check the only box that says perform a clean installation.
    How does it go after this ?
    If this doesn't help, uninstall the nvidia driver and reinstall your gpu.
    Can you post us a screen shot of GPU Tweak II ?
    Dec 2016
    50
    Yea doing a clean install didnt work. I got the latest driver version and clean installed it too...
    Thats on IDLE as well..
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,437
    With the power management mode set to optimal power it should be down clocking at idle.
    Yours is not down clocking for some reason.
    Set power management mode to optimal power then restart GPU Tweak II, be sure to click apply in the nvidia control panel.
  7. #7
    Dec 2016
    50
    Nope, didnt work
    Also, changing between OC Mode, Gaming mode and Silent mode changes GPU Speed to 110%, 109% and 107% respectively
  8. #8
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,437
    Ok, try restarting your pc and open GPU Tweak II and see if it has down clocked.
  9. #9
    Dec 2016
    50
    Ive tried that unfortunately
  10. #10
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,437
    Well the only thing left to do is try reinstalling GPU Tweak II, are you using the latest version ?
