Results 1 to 6 of 6
    ROG Member Array
    May 2017
    8
    Help with identifying the right Core Voltage indicator
    Hi, I am using Ryzen 1700 OC'ed @3.8, manually set at 1.35V on Asus Crosshair VI. My primary issue is which is the correct metric to use as reference for core voltage. I am using Hwinfo64, CPUz and Asus utility for reference. Here is the screenshet for voltages at idle state.
    HWinfo - Ryzen CPU Core Voltage (SVI2 TFN) - 1.344V
    Hwinfo - Vcore (under Mobo) - 1.417V
    CPUz - Vcore - 1.417V
    Asus Utility - 1.417V
    I am using LLC1 setting in BIOS to keep the vcore tight. Please help me in understanding which is the metric I need to look at. If its the 1.417V ones, I am concerned as I dont want it to run over 1.4V 24/7. Your help is truly appreciated as I am new to overclocking.
    ROG Guru: Blue Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    102
    995
    IMO CPU Core Voltage (SVI2 TFN). A few members on OCN measured at the socket using a DMM and concurred that that voltages is what CPU gets.
    Vcore (under Mobo) is close to what you'd read if measuring at the ProbeIt point using a DMM. This has "LLC" to power plane.
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme Alpha - G.Skill Trident Z 3400MHz C14 QC - RX VEGA 64
    R5 3600 - Custom WC - Asus Crosshair VII Hero Wifi - G.Skill Ripjaws V 3800MHz C16 - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    The voltages explained/discussed in many places, including here and here and here (and that's just the top three google hits which looked relevant).
    Motherboard VRM implementation (detailed here and here and here) on CH6/X370 mobos uses exactly the same component hardware as on M8/Z170 mobos. The power phases should be able to handle ~320A on CPU and ~160A on SOC (plus main chipset) and ~34A on DDR4 MCU, at >90% power efficiency up to 125C. With very high (several hundred KHz) PWM/switching frequencies and overrated bulk filter reservoirs, it looks like it should be able to respond to (mV resolution) load line transients within a couple of milliseconds.
    Ryzen processor voltage monitoring is briefly outlined here:
    AMD's opting out of FIVR, the fully-integrated voltage regulator that Intel has recently used. Instead, AMD is option for a more traditional linear voltage regulator and LDO (low-dropout regulator), and is localizing voltage regulations across the core. Continuing its newfound obsession with sensors (for the record, we think this is a good thing), AMD has 9 vDroop detectors alongside 48 power supply monitors that help ensure stable and fine-tuned voltage regulation. When asked the benefit of LDOs, we were told that an LDO allows for faster cores to operated with lower voltage, thus saving power (and heat).
    (etc)
    So I'm not seeing much real value in firmware-level LLC controls. They wouldn't be as responsive as motherboard VRM hardware or processor power regulation sensors/cutouts ... firmware is fast and powerful, but it just seems too sluggish and laggy for useful realtime voltage regulation on a GHz processor, I'd think it's mainly useful only as another redundancy to fall back onto during fault conditions or for truly extreme out of spec operation (like crazy LN2 OC record attempts, because CH6 mobos are already overengineered for "normal" overclock/overspec operation).
    Of course I might be wrong. Do (reasonable values for) these LLC BIOS settings really appear to make measurable differences in performance or stability?
    ROG Member Array
    Jul 2016
    16
    With Bios 1107. CPUZ is 1.373v, In hardware info CPU Core (SVI2 TFN) reads 1.337v Multi meter reads 1.35v. The multi meter is to be the most trusted. Applying 1.35v to ram, the bios reads 1.41 even if I apply 1.385v it still reads 1.41 but for 1.35v the multi meter shows that I'm actually receiving 1.358v to the ram. Just buy a multi meter to get proper voltage readings. As of right now the bios does not show proper temps nor voltage.
    Tech Marketing Manager HQ Array Raja@ASUS's Avatar
    Apr 2011
    161
    7,454
    Some brief LLC info here.
    gupsterg PC Specs
    Processori5 4690K
    MonitorAsus MG279Q
    Storage #2HGST 2TB
    gupsterg's Avatar
    Feb 2015
    102
    995
    MrGreaseMonkkey
    The ProbeIt points include "Load Line Calibration" to "Power Plane". See this post by Elmor on OCN. There are also others posts and info I have collated in this thread on OCN.
