Water Cooler Header in Bios
vidguys
I have a Maximus VIII Hero Alpha.
How do I set the water cooler header in the Bios? I cannot find it.
5 REPLIES 5
dirtyred
Should be in the Monitoring section.
Correct under the section "Monitor" in the bios scroll down you will see the water cooled option,
64524
Thank you both so very much.
When Dual Intelligent Processors 5 starts will Fan Xpert 3 over ride the bios setting?
In my experience, yes. Though the bios should allow the Dave customization in my opinion
Sent from my Nexus 6P using Tapatalk
vidguys
Thank You all for your support.
