Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    ROG Member Array tommywho1 PC Specs
    tommywho1 PC Specs
    Motherboardrog maximus 1X code
    Processori7 7700k kaby lake 4.2 ghz
    Memory (part number)G.SKILL 16GBDDR4 TRIDENT Z 3200MHZ
    Graphics Card #1ASUS 1080ti FE
    MonitorROG SWIFT PG348Q 34'' G-SYNC CURVED
    Storage #1SAMSUNG 850 EVO1TB SSD
    CPU CoolerCORSAIR HYDRO H100i v2
    Casecooler master maker 5 full tower
    Power Supplycorsair ax1200i 1200w 80+
    Keyboard ROG-Claymore
    Mouse microsoft
    Network Routerasus rt-ac565
    Apr 2017
    9
    Improvments to my system
    If you look at what my system is and say if any good and what can i do to make it better
    need top of the range to check emails lol
    i'm sure you guys know heaps more i'm just learning
    cheers
    Nate152 PC Specs
    Graphics Card #2Titan Xp
    Sound CardROG SupremeFX 2015
    MonitorHP ZR30w
    Storage #1Toshiba OCZ VX500 256GB
    CPU CoolerSwiftech Apogee GTZ
    CaseThermaltake Armor+ VH6000
    Mouse Razer Basilisk
    OS Windows 10 Home 64 bit
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Hi Tommywho1
    You have an awesome gaming pc, the only thing I see to increase performance is add another 1080 ti for SLI but I don't know if you need it with the PG348Q monitor. It depends on the games you play and how many frames per second you're currently getting if you'd want or need one.
    Or you could keep what you have and overclock your cpu and gpu.
    tommywho1 PC Specs
    Mouse microsoft
    Apr 2017
    9
    Quote Originally Posted by nate152 View Post
    hi tommywho1
    you have an awesome gaming pc, the only thing i see to increase performance is add another 1080 ti for sli but i don't know if you need it with the pg348q monitor. It depends on the games you play and how many frames per second you're currently getting if you'd want or need one.
    thanks nate still doing a lot of checking out how to overclock havn't started to experiment just yet
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    You should see how many frames per second you're getting, if you're hitting 100 FPS in your games you really don't need to overclock.
    Do you have a program that shows FPS while playing games ?
    tommywho1 PC Specs
    Mouse microsoft
    Apr 2017
    9
    Quote Originally Posted by Nate152 View Post
    I think I can get the monitor to put on screen whilst playing I'LL SUS IT OUT CURIOUS TO SEE WHAT I GET
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Ok yeah tell us how many Frames Per Second you're getting, then if you want or need more I'll help you overclock if you like.
  7. #7
    tommywho1 PC Specs
    Mouse microsoft
    Apr 2017
    9
    cheers I just did benchmark with game for Honor and it said average of 83fps not sure on how to test I don't have a program as such to test if you could recommend one cheers I'll give it a go
  8. #8
    Nate152 PC Specs
    MonitorHP ZR30w
    Nate152's Avatar
    Feb 2013
    308
    16,359
    Well that's pretty good, you could overclock to see if you can hit 100 FPS.
    You can start with your 1080 Ti, Chino made a guide for overclocking the ROG Strix 1080, you can use it as everything applies to your 1080 Ti.
    https://rog.asus.com/forum/showthrea...Strix-GTX-1080
    Once you get your gpu overclocked then you can overclock your cpu.
    I'm going to sign off, it's 2 am here in the u.s. if you would like help overclocking your cpu I'll gladly help you tomorrow.
  9. #9
    tommywho1 PC Specs
    Mouse microsoft
    Apr 2017
    9
    cheers Nate its a sunny Wednesday 2pm day here lol thanks
  10. #10
    ROG Guru: Yellow Belt Array AlexB121 PC Specs
    AlexB121 PC Specs
    Laptop (Model)Asus Rog G501
    MotherboardROG CROSSHAIR VI EXTREME
    ProcessorAMD RYZEN 7 1800X 8-Core 3.6 GHz (4.0 GHz Turbo) Socket AM4
    Memory (part number)G.Skill Trident Z RGB 32GB 4 x 8GB DDR4-3200 PC4-25600 CL16 Dual Channel
    Graphics Card #1ASUS ROG STRIX GeForce® GTX 1080 TI
    MonitorASUS MG28UQ Gaming Monitor x2
    Storage #1Samsung 960 PRO Series - 512GB PCIe NVMe - M.2
    Storage #2SAMSUNG 950 PRO M.2 2280 512GB PCI-Express 3.0 x4
    CPU CoolerEKWater EK-KIT X360
    CasePhanteks ENTHOO EVOLV ATX GLASS
    Power SupplyEVGA SuperNOVA 850 G3 850 Watt 80 Plus Gold Modular ATX Power Supply
    Keyboard Corsair Gaming K95 RGB
    Mouse ROG Spatha
    Headset ASUS Strix 7.1 Superior True 7.1 Surround Gaming Headset & ASUS Strix 7.1 Superior True 7.1 Wireless
    Mouse Pad Asus ROG Republic of Gamers Design 001
    Headset/Speakers Asus STRIX 7.1
    OS Microsoft Windows 10 Pro
    Network RouterVerizon's FiOS Quantum + Asus RT-AC87U
    AlexB121's Avatar
    Jan 2014
    193
    dude with a system like that and ur 100 fps is not that good buddy get a 4k monitor and ull love the difference imop qhd is old news 4k is the truth right now buy a 4k monitor an ull see the difference.. im using a zotac 1080 not the ti yet im running 70 fps on it ultra settings 4k 4880x2160 its a huge difference
