Results 1 to 3 of 3
    New ROGer Array
    Apr 2016
    2
    G551jw Direct 3d Acceleration issue
    Hi guys I am an owner of a g551JW with a 960m and i7 4750hq.
    My issue is that after countless driver reinstall and 2 clean windows my Direct 3D Acceleration (which can be seen in Dxdiag) disappears.
    For example when I install the nvidia driver and the Direct 3d is enabled for a short while I can play HoTS on ultra without dipping below 30 fps, but when the Direct3d goes to disabled i can barely play on medium without dropping below 30. It is the same issue with every other game I've tried (Dota 2, Cs:go,Overwatch,Diablo etc...).
    Everything is set to maximum performance I've tried with the latest drivers, and i have also tried with the drivers from asus but without any luck.
    I turn to you rog forum gods please help a fellow gamer ^__^ .
    ROG Junior Member Array
    Jul 2014
    1
    Quote Originally Posted by fayde View Post
    I have the same problem with a G750JM. The only way I have got the 3d accelaeration to work is uninstalling (and deleting) the manufacturer's driver and reinstalling the latest intel driver. Dxdiag then shows 3d as enabled. The only trouble is that Windows automatically updates to the horrendously out of date ROG driver so you need to add a key to the registry to disable automatic driver updates. I am currently trying Rolling back the driver after it has reinstalled itself so I don't have to manually check all the other drivers
    ROG Guru: Blue Belt Array Gps3dx PC Specs
    Gps3dx PC Specs
    Laptop (Model)Current: G751JT | Retired: G55VW, G51JX
    MotherboardInc M.2 slot
    Storage #1Samsungs EVO 850 128GB
    Storage #21TB HGST Travelstar 7K1000 (HTS721010A9E630)
    CPU CoolerMother Nature & Thermodynamics laws
    Mouse Logitech MX 518
    Headset/Speakers Logitech T6060
    OS Cleaned installed Windows 10 HOME x64
    Accessory #1 Leap Motion
    Feb 2015
    71
    779
    forget Asus's GPU driver - NEVER use it as they are OUTDATED in term of YEARS !
    make sure to install latest DX9 - even though you play using DX10/11/12, and GET LATEST GPU DRIVER FROM THE GPU MANUFACTURER ! ( intel / Nvidia / AMD ) !
    more tips about getting better FPS and avoiding stuttering on win10 1709+, please see my latest posts in the sticky thread/guide about windows clean installation ( links in my sig ).
Tags for this Thread
