Results 1 to 2 of 2
    ROG Member Array
    Apr 2013
    7
    Multiple problems with G75VW
    Well I wouldn't really call it multiple problems, more just a single problem that when fixed creates another problem! So basically my charging port is loose or something so the Asus on Screen display constantly flashes "on Battery" "charging" well I fixed that by uninstalling the ATK Pack. Now onto the issue that arise from that, I can not figure out how to turn off the keyboard back light without the fn key and it drives me nuts! If anyone can help me with this issue I would appreciate it, I looked around and the only thing I find is the exact opposite of my problem in that the back light doesn't work period I wish that was my issue!
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,121
    Yes you need the ATK package installed for the FN keys to work and many other things.
    Sounds like you may have removed the warning about your power situation, not the issue since that would be a hardware issue. Your socket on your motherboard is going defective?
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
