Results 1 to 4 of 4
    New ROGer Array
    May 2017
    6
    Lightbulb G 752 VS Touchpad Gesture Fix
    I have a solution for the problem that the gesture function after a start from the hibernation state no longer works.
    Here the instruction:
    1. Download the Zip from the Link below
    2. extract the zip into a folder where you want
    3. open the "WinIAP_X64.exe"
    4. select "Load Bin File" and now select the File "SB463D-1407_Fv0x06.bin" in the the same folder that you extractet
    5. after the .bin file is loaded in the programm klick "Update Rom" (do nothing before the Update Process is finished)
    6. when the update is finished, close the programm and restart your computer
    7. the gesture function should now work after hibernation mode
    I accept no liability for damages and use of the program
    Programm Download:
    http://www.share-online.biz/dl/E5NEO8QOUVO
    ROG Member Array
    Mar 2017
    6
    Thanks! It worked.
    Jeez, I spent hours trying to fix this. Don't think my next Laptop will be an ASUS. Bad support, buggy drivers, and every nvidia update is hit or miss.
    Trusting that there's no trojan/backdoor in here Jaeger, but thanks again.
    ROG Member Array
    Jan 2017
    6
    Holy GOD!
    IT WORKED!!!!!!!!! Thank you so much, I've spent over 6-7 hours in total on trying to solve this issue, installed all previous versions of drivers of ATK, Precision Touchpad and many other stuff!!!
    Ex-employee Array
    Jun 2020
    108
    2,154
    Please DO NOT download this file, it's reported with malware. Solution may work but you need to accept that this could be a Backdoor Trojan.
Tags for this Thread
