Results 1 to 5 of 5
Thread: front panel audio hissing
01-13-2012 10:30 AM #1
- Join Date
- Jan 2012
- Reputation
- 10
- Posts
- 2
i recently put this system together and i plugged my headset in today and i get this hissing sound (its more like a high pitched squeal) i was wondering if anyone else had this issue or if its just my motherboard. im using the onboard audio. the rear outputs work fine with no hissing. please help its driving me nuts. thanks in advance
01-13-2012 10:34 AM #2
Please check your front panel header to see if there is dust or any other contaminates that might be causing this interference. Also look at the motherboard connector too.
And welcome.
01-13-2012 05:19 PM #3
xeromist PC Specs Laptop (Model) Dell Inspiron 15 7567 Motherboard MSI x470 Gaming Plus Processor AMD 2600X Memory (part number) 16GB Crucial Ballistix Elite 3600 Graphics Card #1 ASUS GTX 1080 Strix Monitor BenQ BL3200PT Storage #1 Intel 600p NVMe CPU Cooler Wraith Case custom Antec 900 Power Supply Corsair HX1000 Keyboard Logitech Orion Spark Mouse Logitech MX500 Headset Plantronics 777 with Oregon Aero upgrade
- Join Date
- Jul 2010
- Reputation
- 318
- Posts
- 7,763
You should also inspect the front header cables for damage. Depending on the case people have found everything from frayed cables to bad grounding causing problems.
* Support disease research with Folding@Home *
< < < Click the drop-down above my avatar for my PC specs!
01-13-2012 09:37 PM #4
- Join Date
- Jan 2012
- Reputation
- 10
- Posts
- 2
thanks
hey thanks guys i just tested the audio with a different cases fp audio connectors and it is an issue with my current fp audio ports. just need to find a place to get a replacement. thanks again
01-14-2012 09:30 AM #5
