06-01-2017 01:35 PM - last edited on 03-05-2024 10:21 PM by ROGBot
06-01-2017 02:52 PM
06-01-2017 03:50 PM
06-01-2017 04:29 PM
06-01-2017 08:14 PM
06-02-2017 12:50 AM
06-02-2017 06:55 AM
LiveOrDie wrote:
You will need a custom water loop for overclock any CPU with more than 8+ cores, mild overclocks will be fine but it will all depend on your core voltage 1.22v on load on a 10core cpu on a air cooler will not be able to handle it for long periods of time.
06-02-2017 07:22 AM
06-02-2017 09:01 AM
Zka17 wrote:
I am using custom loops, but either way the radiator is not creating the vibrations - the pump, but most likely the fans are doing it (in AIOs the pumps can be a culprit too).
Check some of these kit: https://www.ekwb.com/shop/kits
These are way more efficient than the AIOs, still easy to use.
Pay attention to the radiator size, if it fits your case.
06-02-2017 07:50 AM
