Results 1 to 6 of 6
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(4) SSD's - Samsung 960 & 970 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    48
    1,126
    Displayport cables - question for those who use them
    I bought new Displayport cables for my two new monitors, bought them online from Amazon. Both of them are Startech, one 6-foot and one 10-foot because I actually needed about 7 feet instead of 6 for proper cable management on the one monitor.
    https://www.startech.com/Cables/Audio-Video/DisplayPort/displayport-cable-6ft-certified~DISPLPORT6L
    https://www.startech.com/Cables/Audio-Video/DisplayPort/displayport-cable-10ft-certified~DISPLPORT10L
    The question is about the old 20-pin power problem that has cropped up in the past. The specs from the links above on the mfg's website say these are 19-conductor cables. The packaging that arrived (a bag for each) is clearly labeled 20-pin cable. Just wondering if anyone is either using these cables successfully, unsuccessfully, or has any advice on them? After receiving them I assume now that they meant 19 data conductors and 1 (unlisted) power conductor.
    My video cards, for reference, are the Sapphire R9 Radeon Fury. Should I expect any issues with these cables, such as the 20-pin power problems or anything else? The only reason for switching from what I have now (Insignia) is that they are both 6 foot cables, and one needs to be longer, and I wanted the same cable model to connect to each monitor (except for the length difference). I would appreciate any input if anyone knows.
    Davemon50
    iron man Array kkn's Avatar
    Aug 2011
    243
    6,112
    i dont think so, if so it would be minimal.
    i think my cables are around 2 meters and i dont have enny problem.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    309
    7,670
    I thought the pin 20 issue turned out to be a device issue rather than a cable issue. Basically I thought it should have been fixed in firmware by now? Have you seen anybody have issues with that recently?
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    davemon50 PC Specs
    davemon50's Avatar
    Apr 2017
    48
    1,126
    Quote Originally Posted by xeromist View Post
    Keen question, yes that's exactly why I asked here on this forum with all these knowledgeable people, and also why I stated what my video cards were in the OP. I had NOT seen anyone report the issue recently, no, and felt like I was in the clear on it. Just being cautious. A little disappointed at the misleading website advertising by that mfg though. I appreciate you confirming it's probably a non-issue.
    I haven't actually installed the cables yet since the cable management takes a bit of time behind desk, etc, lol - but should get to it soon. I'll report the results back here on this thread for anyone else following this question or with any 20-pin concerns.
    Davemon50
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    309
    7,670
    Yup, let us know. I've never had the issue myself but my stuff is connected mini dp through a KVM switch so I'm not typical.
    davemon50 PC Specs
    davemon50's Avatar
    Apr 2017
    48
    1,126
    OK I got 'em hooked up, and there doesn't seem to be any strange behavior. Of course it's beyond me why every time you hook up multiple monitors Windows wants to switch the display numbers to the wrong number, but I got that sorted and everything looks good. Thanks for the input, much appreciated.
    Davemon50
