Results 1 to 10 of 109
06-03-2017 08:48 AM #1
James-Pro PC Specs Motherboard ASUS TUF Gaming B550 Plus Wi-Fi Processor AMD Ryzen 5 3600 Memory (part number) G.Skill Ripjaws V 16GB (2x8GB) [F4-3200C16D-16GVKB] Graphics Card #1 ASUS ROG Radeon RX 470 Strix Gaming OC 4GB Sound Card Realtek ALC S1200A Monitor BenQ GW2270 Storage #1 Samsung 850 EVO Series 250GB SSD [MZ-75E250BW] Storage #2 Western Digital Caviar Green WD10EARS 1TB CPU Cooler Corsair Hydro Series H60 V2 Case Antec Nine Hundred Power Supply EVGA Supernova G2 750W Keyboard Logitech Slim Mouse Logitech G9 Laser Mouse Headset Sennheiser HD 280 PRO Headset/Speakers Edifier R1280DB 2.0 OS Windows 10 Forever Beta Accessory #1 Microsoft Xbox One S Wireless Controller Accessory #2 Wacom Intuos Pro Medium
- Join Date
- May 2017
- Reputation
- 10
- Posts
- 35
ASUS ROG Radeon RX 470 Strix Gaming OC 4GB | loses connection to monitor
When playing any video game the monitor keeps losing connection to the video card, the issue is not just my video card, it is every single ASUS ROG Radeon RX 470 Strix Gaming OC 4GB
The issue seems to be the upper two states of the video card, state 6 and 7, the voltage and frequency.
Can Asus please release another bios update for this video card that fixes the issue, the previous bios update did not fix the issue.
06-05-2017 08:45 AM #2
- Join Date
- May 2016
- Reputation
- 12
- Posts
- 417
hi James,
Try to install the new Radeon Software Crimson ReLive Edition , if still lose connection to monitor
You may contact the service center in local to help RMA service
06-07-2017 10:39 AM #3
- Join Date
- May 2017
- Reputation
- 10
- Posts
- 35
This is not a helpful reply.
I am trying to contact Asus about releasing a new bios to fix this specific model of video card, the issue is not just my video card, it is every single "ASUS ROG Radeon RX 470 Strix Gaming OC 4GB".
Who can I contact about getting Asus to release a new bios for this series of card?
From the looks of it this forum is just users trying to help other users.
06-18-2017 04:17 AM #4
- Join Date
- May 2017
- Reputation
- 10
- Posts
- 35
Would just like to mention that Asus has finally released a new bios for this video card and after using it now for a few hours it seems to have fixed the problem.
For those with this card the bios can be found on the Asus website.
US Website : https://www.asus.com/Graphics-Cards/...Desk_Download/
Australian Website : https://www.asus.com/au/Graphics-Car...Desk_Download/
Found in the Windows 10 tab under bios.
06-28-2017 07:13 PM #5
- Join Date
- Apr 2017
- Reputation
- 10
- Posts
- 3
GPU Clock Throttling
Updated the bios and the issue seems fixed. However it was very disappointing to see that even though after a bios update was provided after a long time, the gpu throttling issue has still not been fixed. I own a Asus Dual OC 480 as well as Strix 470 OC. Even after increasing the gpu temp target to 75C via asus tweakII software, the gpu never goes above 69C and the clock speed is reduced instead. This kind of issue is not present in the 480 Dual OC but is there in the Strix 470 OC and also has been covered in various reviews. It seems very misleading for ASUS to advertise higher overclock (1270) speeds while it cannot even maintain stock speeds (1250). Please fix the issue or at least clarify due to what technical reason you do not want the gpu to exceed 70C.
07-01-2017 10:05 AM #6
- Join Date
- May 2017
- Reputation
- 10
- Posts
- 35
I've put in a lot of hours now and it has not black screened once.... this bios absolutely fixed that issue, Been playing Everspace and it's running smooth.
Have you tried using Wattman instead of the asus utility?
I set my target temp to 70 and it seems to be fine... although it is winter here and the card has a 120mm fan pointed directly at it, housed inside Antec 900 case... so it isn't really getting a chance to get hot.Last edited by James-Pro; 07-01-2017 at 10:57 AM.
07-02-2017 08:50 AM #7
- Join Date
- Apr 2017
- Reputation
- 10
- Posts
- 3
Hi, thanks for the reply. I increased the fan speed in the asus gputweak fan curve so that the gpu stays in the 65C range and does not downclock. I managed to find a workaround but most people would not have or wouldn't even know that their cards are being down clocked to 1200 Mhz on a card that claims 1250 and 1270 Mhz.
Very disappointing.
07-11-2017 04:02 AM #8
- Join Date
- May 2017
- Reputation
- 10
- Posts
- 35
I have had another lost connection to screen error with this new bios update... I was playing Fallout 4 at the time.
I have reported it via the Asus registered product thingy also, seems the card needs further tweaking until it is 100% stable.
07-19-2017 04:36 PM #9
- Join Date
- Jul 2017
- Reputation
- 10
- Posts
- 3
same problem
Hi, I have the same problem, this can happens once a day or once a week, I dont know what is the cause, also I have a second graphic 470 Strix Gaming 4g (the version with out overclock), do you know if this card has the same issue?
07-24-2017 10:27 AM #10
- Join Date
- May 2017
- Reputation
- 10
- Posts
- 35
Hi... from what I can understand it seems to be just the OC model not the standard model.
Have you flashed your card with the bios update?
For the time being while waiting for Asus to release another bios update that 100% fixes this issue I am underclocking and undervolting my video card so that it does not lose connection with the monitor, just the upper state 7....
Here is a screenshot showing the settings.
