Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 42
    ROG Member Array
    May 2017
    18
    Fans forced to 100% when CPU reaches 75C
    Been using a PRIME Z270-A, along with an i7 7700K, for a little while and I've got to say that as my first Asus product, I'm pretty disappointed. I've noticed that in both BIOS and AI Suite III fan control options, the fans attached to the motherboard force themselves to 100% speed when the CPU reaches 75 degrees Centigrade, and there doesn't seem to be any way to fix this. Having bought Asus specifically for their reputation in fan control options, and seeing other options like the "Extreme Quiet" PWM option and fan spin-up/spin-down time variation, this seems like a really strange limitation for two reasons:
    1) Competitors seem to offer much broader temperature control. MSI allows at least 85C, Asrock seems to allow 90C, and Gigabyte allows full control up to 100C. So why is Asus so behind the competition in this, especially in this day of both silent systems and easy overclocking?
    2) Intel themselves have said that a 7700K reaching 75 - 80C is "considered expected and normal". So why is Asus ramping up every fan in my system to 100% as if it's some kind of critical temperature?
    Is there any way to bypass this limit? I've tried both in the AI Suite III application and by modifying the saved profiles within the application folder, but neither seem to work.
    ROG Member Array
    May 2017
    18
    Quote Originally Posted by Chino View Post
    You can control the fan curve in AI Suite III or the BIOS.
    Unfortuantely, I can't adjust them beyond 75C, either in the BIOS or AI Suite III. Please see the attached screenshots: I cannot move the far-right circle any more to the right, and any other attempts to change the fan speed don't work.
Name:	fan control.jpg
Name:	fan control2.jpg
    ROG Member Array
    Oct 2016
    18
    And the "CPU fan step up" and "CPU fan step down" settings in the bios are not workin
    I aquired a Strix Z270F myself, and been suprised by this limitation too, and I have to add that the "CPU fan step up" and "CPU fan step down" settings in the bios are not working (tried with DC and PWM fans).
    Can we expect a bios upgrade ?
    ROG Member Array
    May 2017
    18
    Kramer Weston
    Quote Originally Posted by Aghoithae View Post
    Well I have noticed that while the BIOS seems utterly limited to 75C (entering anything more than that in the "[Fan] Critical Temperature" field found in the advanced Q-Fan menu results in an error message and being reset to 75C) the latest version of AI Suite III does allow you to set a custom critical temperature above 75C for case fans. For some strange reason you can't do the same for the CPU fan, but I suppose it's better than nothing. Helps keep my 1500rpm case fans at bay, at the very least.
    New ROGer Array
    Jun 2016
    1
    I really wish we could have this limit raised to 85-90C seeing as 7700k can easily spike to 85C under heavy load without any OC at all.
    That makes the fans go totally crazy..
  7. #7
    ROG Member Array
    May 2017
    18
    Quote Originally Posted by PadmaN View Post
    Me too. And I've checked on a friend's computer - MSI motherboards allow CPU fan control up to 100C as well. I'm getting the impression that I bought an unfinished product here...
    Oh well, I daresay if the people who are annoyed by it make enough noise about it, it'll be put on the wishlist for the next BIOS/AI Suite III version. One can hope.
  8. #8
    ROG Member Array FaaR PC Specs
    FaaR PC Specs
    MotherboardASUS ROG Strix X299-XE Gaming
    ProcessorIntel Core i9-7900X
    Memory (part number)G.Skill TridentZ RGB F4-3600C16Q-32GTZR (64GB)
    Graphics Card #1ASUS Radeon RX Vega 64 ROG Strix Gaming OC
    Graphics Card #2ASUS Radeon RX Vega 64 ROG Strix Gaming OC
    MonitorSamsung SyncMaster SA850
    Storage #1Intel Optane SSD 905P 2.5" 960GB
    Storage #2Samsung 960 Evo M.2
    CPU CoolerNoctua NH-U14S
    CaseFractal Design Define C TG
    Power SupplyCorsair RM1000i
    Keyboard Corsair Vengeance K70
    Mouse Logitech G700s
    OS Windows 10 Pro
    Jun 2013
    17
    Here's another guy wishing for higher "critical" temp allowed on the CPU than 75C.
    75C is easy street for any modern chip; at least some Intel chips have Tj values upwards of 120C, and even 100C should - while not preferable - not be terribly dangerous either. Certainly anything below 90C doesn't warrant spiking the CPU fan to max! Especially not big brute dual 140mm CPU fans like I have invested in... UGH!
    In the same vein, how about letting us freely configure the 4-pin pump power headers as fan headers instead? I can't rename the pump headers, nor set a fan location in the Fan Xpert software, which is inconvenient. I don't see why it has to be so difficult. :P
  9. #9
    ROG Member Array MacLeod77 PC Specs
    MacLeod77 PC Specs
    MotherboardAsus Z270H
    ProcessorIntel 7700k
    Memory (part number)Corsair Vengeance LPX 16GB (2x8GB) CMK16GX4M2B30
    Graphics Card #1Gigabyte GTX1080 Gaming G1
    MonitorAcer Predator IPS 1440p G-Sync
    Storage #1Intel 600p ITB Nvme
    Storage #2Some HDDs
    CPU CoolerBeQuiet Silentcool
    CaseNZXT H440
    Power SupplyCorsair 550W
    Mouse Logitech G910 Spectrum
    Feb 2017
    15
    Quote Originally Posted by TamiyaGuy View Post
    I've unplugged my AIO cooler fans from the CPU pump header and disabled monitoring for that header in the BIOS. I have the radiator fans plugged into chassis 2 and this gives fan control up to 100 degrees (when you check the critical temp box in ai suite).
    It would be FAR more elegant for ASUS to just fix this in the BIOS and make the CPU FAN control up to 100 degrees.
    It bugs the hell out of me that AI suite shows my CPU fans with big red 0000rpm.
    Not really a pro overclocking motherboard if you have to do an ugly fix like this - it's almost like they encourage delidding!
    I actually recommended to a friend that he buy an MSI board for his new PC because of this issue.
  10. #10
    ROG Enthusiast Array Dude1070 PC Specs
    Dude1070 PC Specs
    MotherboardTUF Z270 MARK 1
    Processori7-7700K
    Memory (part number)16 GB G.SKILL TRIDENT Z 3600 F4-3600C15D-16GTZ
    Graphics Card #1MSI GAMING X GTX 1080 Ti
    Sound CardStrix Soar
    MonitorASUS V32AQ (2560X1440) DELL S2309W (1920x1080)
    Storage #1Samsung SSD 960 EVO 250GB
    Storage #2SAMSUNG SSD EVO 850 500GB
    CPU CoolerNoctua DH 15
    CaseZalman H1
    Power SupplyEVGA Supernova 850GS
    Keyboard Logitech G510s
    Mouse Logitech G502 Proteus Spectrum
    Headset Cerberus V2
    Headset/Speakers Logitech Z506 Surround Sound Home Theater Speakers
    OS W10 Pro X64
    Dude1070's Avatar
    Feb 2017
    36
    Did you guys use the Fan tuning option in the BIOS or AI Suite? That opens it up for settings.
