Flare X 3200MHZ 16GB 2x8: F4-3200C14D-16GFX // Performance & Guide
aeonconcepts
Ryzen Memory and the hate from non-certified B-Die variants is easy to find. Information pertaining to Flare X memory is lost to the vast amount of issues that consumers are having with older modules and or Hynix chips. There is actually a good write up of these chips on an i7 chip, WTF! This is meant as a repository for Flare X 3200Mhz memory only, and without raising the CPU FSB (BCLK) I will update this with information on the 8x4 kits once they are available. GSkill will have the 3466 kits available soon, but with the current performance of the 3200Mhz... It might be a waste of time and money (If you just want to achieve the 3600Mhz mark) ... but GSkill can send me a kit if they want!
This thread will only focus on the intended 100Mhz FSB. This is the most important factor: 3200-3600Mhz are all using the rated timings of: 14-14-14-34-48 and 1T. Also keep in mind that this system is running on an Ekwb extreme loop, Supremacy Evo block and several reservoirs: so your results may vary if heat is an issue for you. I also do not inflate numbers for any reason. The Aida numbers listed here are under a normal workload, normal environment, and with normal programs running in the background; even the complete Adobe CS 2017 suite of BS that runs in the background. Obviously the numbers could be improved, but you wouldn't want to do an excessive BCLK overclock while sacrificing stability and being forced to increase latency. (Agesa 1.0.0.6) Bios Release candidates (Non-Beta) should slightly improve these numbers in the next few weeks.
Testing is done with:
Ryzen 1800X @ 40.75 Multiplier (4075Mhz The best overclock with overall stability in mind)
CPU FSB @ 100Mhz
Flare X 16GB 2x8 3200Mhz:
Amazon: https://www.amazon.com/G-SKILL-Flare-288-Pin-Memory-F4-3200C14D-16GFX/dp/B06XWKNMQQ
Newegg: https://www.newegg.com/Product/Product.aspx?Item=N82E16820232530
Before we get into 3200Mhz and beyond; the numbers for 2400Mhz:
Basic rundown:
2400Mhz: 36263 MB/s @ 90.8 ns (Latency)
3200Mhz: 48705 MB/s @ 73.3 ns (Latency)
3466Mhz: 51551 MB/s @ 69.2 ns (Latency)
3600Mhz: 38422 MB/s @ 67.3 ns (Latency) // Obviously issues to be resolved & excessive heat. Only improvement is in Write speeds.
-3733Mhz fails to boot with the rated timings and settings described below.
@3600Mhz // You may also get a BSOD: System_Service_Exception due to: for WIN/AMD driver problems and/or excessive heat. I can only suggest to run 3466 for the stability, and be happy you are at the 3200 and beyond spectrum.
Choose your speed and using the following voltages: 1.35V (3200Mhz) 1.38V (3466Mhz) 1.40V (3600Mhz) The following screenshots are for use with a 3466Mhz setting. Also note: Bios voltages show 1.395 as the shots were grabbed when going from 3600Mhz to a 3466 w/o a reboot // you get the point, etc:
Step 1: Extreme Tweaker (Mild Overclock and Ram Voltage)
Step 2: DRAM Timing (force the rated timings and select 1T-CR)
Step 3: Digi+ Power Control (vBoot located at the bottom)
Step 4: ProcODT & Fail_CNT (This is the most important aspect aside from forcing 1T-CR and the low rated timings)
Step 5: Ensure that the 2nd set of Power Down options are disabled // (optional)
Notes: Cold boot will do a single reset but that is why we force a (4) Fail_CNT which is plenty for a good power on.
Now the current Bios: 1401 for this memory has made more improvements:
3200Mhz @ 1.35 Voltage & 1.35 vBoot:
3466Mhz @ 1.38 Voltage & 1.38 vBoot:
3600Mhz @ 1.40 Voltage & 1.40 vBoot:
It seems that the 3466Mhz settings may offer the best overall performance.
Memtest x64 was run for 90 minutes on all 3 tests with 0 errors. One thing to note: Bios 9943 & 9945 introduced a new bug (at least for me) Win10 will now only show 1200mhz (rated 2400Mhz) in task manager for anything above 3200Mhz settings. CPU-Z will be blank with only timing display for anything above 3205Mhz (1599.7 and lower will display) and Memtest will also only show 1200mhz. Aida 64, RTC and Bios displays proper frequency every time. Hopefully this will be fully resolved soon. You will NOT want to use Bios: 9945 with this memory kit.
Update: Windows 10 updates have fixed Memory speed in Task manager June 13, 2017
Update: CPUZ fixed in latest version, ROG skin update as well.
MemTest64 (tested at a minimum 0f 90 minutes on all speeds) regardless of speed shows 0 errors:
And for a Overclock increase with the 3466 strap going from a 40.75 to a 41 Multiplier:
As a comparison with a +3 (103 // CPU FSB) 4120MHZ CPU & 3300MHZ Memory:
Initial Reviews:
http://hexus.net/tech/reviews/ram/105241-gskill-flare-x-16gb-ddr4-3200-f4-3200c14d-16gfx/?page=4
http://www.legitreviews.com/g-skill-flare-x-series-16gb-ddr4-3200mhz-amd-memory-kit-review_194153
https://proclockers.com/reviews/memory/gskill-flare-x-3200mhz-ddr4-2x8gb-16gb-memory-review
Summary: Initial performance was lacking, but with a beta 1.0.0.6 code it is performing beyond my initial expectations. Now if we can overclock the Ryzen like these modules...
49 REPLIES 49
FlanK3r
good info man. IM still testing E-die, before I put in B-die 🙂
Who knows me, knows me ;)....AMD 3000+, AMD x2 4600+ EE, AMD X4 955 BE C2,2x AMD X4 965 BE C3, AMD X4 970 BE C3, AMD x4 975 BE, AMD x4 980 BE, AMD X6 1090T BE, AMD x6 1100T BE, 2x AMD FX-8120, 2x AMD FX-8150, FX-6300, FX-8300, FX-8320E, FX-8320, FX-8350, FX-8370, FX-8370E, FX-9370, FX-9590, AMD A8-3850, AMD A8-3870K, A8-5600K, A10-5800K, A10-6800K, A10-7850K, A10-7870K, A 5150, Athlon x4 860K, Intel i7-5960X, i7-6700K, Intel i7-4770K, Intel i7-980x, Intel i7 2600k, Intel i7-3770K, i7-3930K.
purecain
make sure you make a copy of your ram spd. it seems to affect rgb ram although we're not sure if the spd's on normal ddr4 get corrupted aswell.
AsusCrosshairHeroVIII - 5950X
32Gb G.Skill RGB Trident 16gb3466Mhz B-Die + 16gb4266Mhz B-Die
Asus Tuf RTX3090
1TbSamsung960EVO M.2 1TbSamsung850EVO SSD Seagate2TB/3Tb CorsairForceGt 64gb
Seasonic Focus1000w 80+ Gold
Thermaltake Core X71 Tempered glass side panal
Thanks for sharing your settings, with same RAM and your settings i have to go 1.4v on ram to boot @3466; impossible to boot @ 3600 (no big deal, i didn't try more than 1,41v anyway)
@ 3466 it fails cold boot from time to time; when back in uefi @ 2400 i notice that all setting in the "advanced" tab (amd cbs/ddr4...) are reset (Fail_CNT is reset to 1); it boots again when i re-set those amd cbs settings like yours. Few cold boots after it fails again and i reset amd cbs again to boot again.
@3333 absolutly no problem at 1,35v, boots every time
I'll stick to 3333 for now until next stable bios.
Edit: i tried with bios 9945 at first and had much difficulty to boot @3466; then i tried with 9943 and it was way much easier.
From what Elmor was saying on: http://www.overclock.net/t/1624603/rog-crosshair-vi-overclocking-thread the 9945 is more of a 4x8GB and Hynix beta. It's in my opinion that almost every Beta build so far is for the benefit of the non-certified memory; more than what you should be running. As this makes more users "Happier" there really hasn't been much in the way of: "Here is a Flare-X build, Enjoy!" 9943 Is a really good start for Flare-X, and i'll keep the info updated here as the builds come in. The biggest hurdle right now is how Windows handles this new AMD architecture, and extended gaming (heat) effecting memory stability in the upper 70c cpu temps. In almost every case the Ryzen will charge on, but the SOC craps out and freezes the DRAM. Whatever speed you run just keep the temps as low as possible and you can run higher speeds. At this time I am running the 3466Mhz strap with absolutely no issues, as long as the temps are in line. If you are using a Cpu Fan or AIO I would strongly suggest that you stay in the 3200Mhz range. If you are following this thread, just keep an eye on the first pic in this thread, that will update with the current tested Bios, and will change with stability or speed increases that we can benefit from.
I tried your 3466 settings on my Flare X 3200mhz and it seems it wasn't stable. So I rolled back to 3200Mhz. Not a big deal really aneway.
aeonconcepts
Post updated: Windows pushed updates today correcting memory speed in Task Manager. Latest version of CPUZ, including the ROG skinned version now shows correct memory speed and FSB. No issues regarding Flare X on Bios 1401. Very nice to see CPU temps with -20 offset as default. More speed (with stability) possible in response to SOC/DRAM controller reporting lower temps. I'll do a full re-test and post Aida numbers over the next few days, and have the 9943 numbers under each new image. Thanks to Elmor for a 1.0.0.6 RC
@aeonconcepts Thank you buddy!*
Are the guideline values ​​valid for the new 1401?
Silent_Scone
Super Moderator
Just a word to the wise, Memtest64 can show false positives compared with alternatives as HCI Memtest Pro and Google Stress App test. Personally would recommend running Stress App Test as well. It's also good to have more than one stresser in ones arsenal. Great guide nevertheless!
andyliu
this is my result with flare-x
65352
and here is my setting.
https://pastebin.com/Uz6kfeWe
I basically just manually input the detected speed, seems to be working well 🙂
ran memtest for an hour and play games for 3+ hours
