SDK Release not working for GSkill Trident RGB?
Bl4d3s
Hello,
finally there is this SDK for Aura. But after I updated the corresponding Aura program my GSkill Trident RGB Ram doesnt show up in the AURA software anymore, also if I run the sample software provided, it only recognizes my Mobo, not the RAM (Im on ASUS X370 Prime).
Is this a bug? Or will the support for the RAM be added later?
Greetings
Michael
22 REPLIES 22
InhexSTER
I also see that it only shows my motherboard in the device list.
Can't check if the GPUs are supported since I don't own Aura enabled one.
Thanks
how you install aura sdk?
If you are asking how to use SDK, you need to build sample in Visual Studio and go from there. I have C# binding in the works.
Also SDK comes with new version of Aura software (needed for SDK to work ) which I installed and now I don't see the GSkill ram or independent section for motherboard control. It only shows motherboard synchronized as a device
Can you share those bindings? Thanks man!
Here you go. Just add this as a reference in your C# app
it mimics methods in C++ version
Aura SDK DLL for C#
InhexSTER wrote:
Aura SDK DLL for C#
That's amazing! Thanks!
InhexSTER wrote:
Aura SDK DLL for C#
Would it be possible to make a update version with the latest SDK?
dudu631
Bl4d3s wrote:
Hello,
Greetings
Michael
After playing around, with InhexSTER bindings (thanks a lot), i can confirm that i'm not getting my Trident z on device list. Can't say about the gpu.
Did Gskill manage to sort it's problem with rgb spd tables getting corrupted more frequently with ryzen motherboards? Still seeing people deal with it but haven't looked if gskill's come up with a fix.
