Results 1 to 6 of 6
    ROG Member Array
    Jun 2017
    Asus ROG GL702VS Battery plugged in not charging
    I am new to the gaming laptop scene and i was wondering if this is normal my battery usually when i boot up after it has been in sleep mode or shut down shows 99% not charging and when i play games on high performance sometimes the battery will show somewhere in the high 90's plugged in not charging, i then have to unplug the charger and let the battery go below 90 for it to start charging again. Something else i have noticed is that the battery life while gaming on high performance is under 1 hour and 30 minutes from a full charge with low screen brightness is this normal or do i have a faulty battery/charger.
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(4) SSD's - Samsung 960 & 970 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    48
    1,126
    For your first question, that is normal. See THIS POST for more information.
    For your second question, go into your W10 power options (advanced settings) and check the Display section which allows you to alter screen brightness under various conditions. You may have to create your own power profile to change things, or else select performance mode.
    Davemon50
    ROG Member Array
    Jun 2017
    Quote Originally Posted by davemon50 View Post
    Thank you!
    I just tried uninstalling and reinstalling the battery driver and that seems to have worked but i havent tested it while gaming yet! Hopefully this fixes my issue and i dont have to return the laptop.
    Edit: nevermind it has been like 5 mins and it did it again I think it might be to "prolong" the life of the battery like one other user suggested it slowly trickles the power after fully charging the laptop but i still find it odd, I mean it charges to full then slowly drops below 100% over the course of the night it seems
    davemon50 PC Specs
    davemon50's Avatar
    Apr 2017
    48
    1,126
    Make sure adaptive brightness is turned off on the display tab in the advance power options menu.
    Davemon50
    ROG Member Array
    Jun 2017
    I have that turned off, the battery life is still iffy sitting around 1.5 hours
    Super Moderator Array
    Jan 2013
    99
    2,191
    Quote Originally Posted by cro68 View Post
    fyi.
    If anyone is interested about the plugged in, not charging issue, there is an ASUS website FAQ about it. Thanks.
    Why doesn’t the battery charge when power level is above 95% with AC adapter connected?
    https://www.asus.com/us/support/FAQ/1012793/
Tags for this Thread
