Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
    ROG Member Array
    Jun 2017
    14
    RAMPAGE V EXTREME MOTHERBORD b1 error code, monitor no signal.
    Hi there....
    I have built a PC end of 2015 and I have a ASUS RAMPAGE V EXTREME motherboard fitted. Occasionally there have been cases where upon powering up the PC the screen will remain blank with a no signal message displayed and an error code b1 will be displayed by the motherboard LED.
    One occasion I had this problem so I believe I either restarted or took out the CMOS button (the first a friend I believe took it out or pushed the button on the motherbord for around 5 secs or so and rebooted the motherboard); the second more recently where I was unable to find the button on the motherboard but I pushed the CMOS button at the back of the panel of the tower which I found. However prior to this I could not find a solution and I used to unplug the power cable hold down the power button for a minute or so and then plug back in the power cable and turn the computer on. This also used to work for me...........
    Now I have realised that every so now and again this problem will arise BUT I am unable to find a permanent fix for this problem; I have looked on various forums and some of the solutions were a bit too technical for my understanding and some did not work for me though they worked for other people.
    Hence I now seek some help into anyone that may be able to help me with this problem; and would really appreciate any help from you tech experts on here......
    My PC Specs are:
    System Information report written at: 06/06/17 18:20:19
    System Name: SAFRAN-PC
    [System Summary]
    Item Value
    OS Name Microsoft Windows 10 Pro
    Version 10.0.14393 Build 14393
    Other OS Description Not Available
    OS Manufacturer Microsoft Corporation
    System Name SAFRAN-PC
    System Manufacturer ASUS
    System Model All Series
    System Type x64-based PC
    System SKU All
    Processor Intel(R) Core(TM) i7-5960X CPU @ 3.00GHz, 3001 Mhz, 8 Core(s), 16 Logical Processor(s)
    BIOS Version/Date American Megatrends Inc. 1701, 14-Aug-15
    SMBIOS Version 2.8
    Embedded Controller Version 255.255
    BIOS Mode Legacy
    BaseBoard Manufacturer ASUSTeK COMPUTER INC.
    BaseBoard Model Not Available
    BaseBoard Name Base Board
    Platform Role Desktop
    Secure Boot State Unsupported
    PCR7 Configuration Binding Not Possible
    Windows Directory C:\WINDOWS
    System Directory C:\WINDOWS\system32
    Boot Device \Device\HarddiskVolume1
    Locale United States
    Hardware Abstraction Layer Version = "10.0.14393.206"
    User Name Safran-PC\Safran
    Time Zone GMT Daylight Time
    Installed Physical Memory (RAM) 16.0 GB
    Total Physical Memory 15.9 GB
    Available Physical Memory 11.8 GB
    Total Virtual Memory 31.9 GB
    Available Virtual Memory 27.3 GB
    Page File Space 16.0 GB
    Page File C:\pagefile.sys
    Hyper-V - VM Monitor Mode Extensions Yes
    Hyper-V - Second Level Address Translation Extensions Yes
    Hyper-V - Virtualization Enabled in Firmware No
    Hyper-V - Data Execution Protection Yes
    [Hardware Resources]
    [Conflicts/Sharing]
    Resource Device
    I/O Port 0x00000000-0x0000000F Direct memory access controller
    I/O Port 0x00000000-0x0000000F PCI Express Root Complex
    I/O Port 0x000003C0-0x000003DF PCI-to-PCI Bridge
    I/O Port 0x000003C0-0x000003DF NVIDIA GeForce GTX 980 Ti
    Memory Address 0xFB600000-0xFB6FFFFF PCI-to-PCI Bridge
    Memory Address 0xFB600000-0xFB6FFFFF ASMedia USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
    I/O Port 0x0000E000-0x0000EFFF PCI-to-PCI Bridge
    I/O Port 0x0000E000-0x0000EFFF NVIDIA GeForce GTX 980 Ti
    Memory Address 0xFB700000-0xFB7001FF Asmedia 106x SATA Controller
    Memory Address 0xFB700000-0xFB7001FF PCI-to-PCI Bridge
    I/O Port 0x00000580-0x0000059F Intel Device
    I/O Port 0x00000580-0x0000059F Motherboard resources
    Memory Address 0xA0000-0xBFFFF PCI-to-PCI Bridge
    Memory Address 0xA0000-0xBFFFF PCI Express Root Complex
    Memory Address 0xA0000-0xBFFFF NVIDIA GeForce GTX 980 Ti
    Memory Address 0xC0000000-0xD1FFFFFF PCI-to-PCI Bridge
    Memory Address 0xC0000000-0xD1FFFFFF PCI Express Root Complex
    Memory Address 0xC0000000-0xD1FFFFFF NVIDIA GeForce GTX 980 Ti
    Memory Address 0xFB200000-0xFB4FFFFF PCI-to-PCI Bridge
    Memory Address 0xFB200000-0xFB4FFFFF Broadcom 802.11ac Network Adapter
    I/O Port 0x000003B0-0x000003BB PCI-to-PCI Bridge
    I/O Port 0x000003B0-0x000003BB PCI Express Root Complex
    I/O Port 0x000003B0-0x000003BB NVIDIA GeForce GTX 980 Ti
    Memory Address 0xFA000000-0xFB0FFFFF PCI-to-PCI Bridge
    Memory Address 0xFA000000-0xFB0FFFFF NVIDIA GeForce GTX 980 Ti
    [DMA]
    Resource Device Status
    Channel 4 Direct memory access controller OK
    [Forced Hardware]
    Device PNP Device ID
    [I/O]
    0x00000290-0x0000029F Motherboard resources OK
    0x0000E000-0x0000EFFF PCI-to-PCI Bridge OK
    0x0000E000-0x0000EFFF NVIDIA GeForce GTX 980 Ti OK
    0x000003B0-0x000003BB PCI-to-PCI Bridge OK
    0x000003B0-0x000003BB PCI Express Root Complex OK
    0x000003B0-0x000003BB NVIDIA GeForce GTX 980 Ti OK
    0x000003C0-0x000003DF PCI-to-PCI Bridge OK
    0x000003C0-0x000003DF NVIDIA GeForce GTX 980 Ti OK
    0x00000070-0x00000071 System CMOS/real time clock OK
    0x00000074-0x00000077 System CMOS/real time clock OK
    0x00000020-0x0000003D Programmable interrupt controller OK
    0x000000A0-0x000000BD Programmable interrupt controller OK
    0x000004D0-0x000004D1 Programmable interrupt controller OK
    0x0000D000-0x0000DFFF PCI-to-PCI Bridge OK
    0x00000000-0x0000000F Direct memory access controller OK
    0x00000000-0x0000000F PCI Express Root Complex OK
    0x00000081-0x00000083 Direct memory access controller OK
    0x00000087-0x00000087 Direct memory access controller OK
    0x00000089-0x0000008B Direct memory access controller OK
    0x0000008F-0x0000008F Direct memory access controller OK
    0x000000C0-0x000000DF Direct memory access controller OK
    0x00000580-0x0000059F Intel Device OK
    0x00000580-0x0000059F Motherboard resources OK
    0x000003E0-0x00000CF7 PCI Express Root Complex OK
    0x00001000-0x0000FFFF PCI Express Root Complex OK
    0x0000F070-0x0000F077 Intel(R) 9 Series Chipset Family SATA AHCI Controller OK
    0x0000F060-0x0000F063 Intel(R) 9 Series Chipset Family SATA AHCI Controller OK
    0x0000F050-0x0000F057 Intel(R) 9 Series Chipset Family SATA AHCI Controller OK
    0x0000F040-0x0000F043 Intel(R) 9 Series Chipset Family SATA AHCI Controller OK
    0x0000F000-0x0000F01F Intel(R) 9 Series Chipset Family SATA AHCI Controller OK
    0x000000F0-0x000000F0 Numeric data processor OK
    0x00000500-0x0000057F Motherboard resources OK
    0x00000400-0x0000047F Motherboard resources OK
    0x00000092-0x00000092 Motherboard resources OK
    0x00000010-0x0000001F Motherboard resources OK
    0x00000072-0x00000073 Motherboard resources OK
    0x00000080-0x00000080 Motherboard resources OK
    0x00000084-0x00000086 Motherboard resources OK
    0x00000088-0x00000088 Motherboard resources OK
    0x0000008C-0x0000008E Motherboard resources OK
    0x00000090-0x0000009F Motherboard resources OK
    0x00000600-0x0000061F Motherboard resources OK
    0x00000880-0x00000883 Motherboard resources OK
    0x00000800-0x0000081F Motherboard resources OK
    0x00000061-0x00000061 System speaker OK
    0x00000062-0x00000062 Microsoft ACPI-Compliant Embedded Controller OK
    0x00000066-0x00000066 Microsoft ACPI-Compliant Embedded Controller OK
    0x00000040-0x00000043 System timer OK
    0x00000050-0x00000053 System timer OK
    So if anyone of you tech specialists can read over this and let me know of the solution to this problem as it has been bugging me for quite a bit......MUCH APPRECIATED.
    Thanks for your time & effort.
    Saf
    ROG Member Array
    Jun 2017
    14
    Hi Chino,
    Thanks for your reply.....I have been thinking of doing this but I am not sure how to do this; I mean I went on the ASUS website but I wasn't sure what I needed to download as there were a whole lotta files on there......
    Thanks,
    Saf
    ROG Guru: Yellow Belt Array MikeAdu PC Specs
    MikeAdu PC Specs
    MotherboardAsus Rampage V Extreme/U3.1/3701 BIOS
    ProcessorIntel i7 5960X @strap 100/4,0/3.5 1,15V both/1.92V input
    Memory (part number)CMD32GX4M4B3333C16 (two sets,64Gb,8 slots)
    Graphics Card #1Asus GTX 1080 Ti Turbo
    Graphics Card #3Asus GTX 1080 Ti Turbo
    Sound CardCreative Sound Blaster ZxR
    MonitorSamsung T260HD
    CPU CoolerEK Supremacy EVO waterblock,1x360mm + 2x240mm + 2x120mm radiators
    CaseCorsair T760 White
    Power SupplyCorsair AX1500i
    Keyboard Logitech G19S
    Mouse Logitech G700S
    Headset Logitech G35
    Headset/Speakers Logitech Z-5500 Digital 5.1 Speaker System
    OS Windows 10 64bit/Windows 8.1 64bit/Windows 7 64bit
    Nov 2016
    13
    245
    1701 is used here.Which small red LEDs is on(CPU,ram,etc)?
    Отправлено с моего iPhone используя Tapatalk
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Quote Originally Posted by saf99 View Post
    Hi Chino,
    Thanks,
    Saf
    Look under Others than BIOS.
    Put the file on a FAT32 formatted USB pendrive and use the EZ Flash Utility inside the BIOS for the update.
    ROG Enthusiast Array
    Oct 2015
    42
    Try turning off Hibernation in Windows 10.
    In an elevated command prompt, copy and paste the command below, and press Enter.
    powercfg -h off Reboot.
    This will also turn off Fast Start in Windows 10. It won't make any difference to boot time. Can cure a wealth of boot problems if using EUFI bios.
  7. #7
    Oct 2015
    42
    In previous post there is typo.
    The admin command prompt is only.
    powercfg -h off
    Then reboot. Sorry, should have put in full stop .
  8. #8
    ROG Member Array
    Jun 2017
    14
    avenida calle
    Hi guys.....
    Thanks for your replies.....
    Okay what should I do first? I've noticed some of you have given different instructions. Should I do the update first?
    Thanks.
  9. #9
    Oct 2015
    42
    The first step is to make sure you have the latest bios. Try that first as suggested.
  10. #10
    ROG Member Array
    Jun 2017
    14
    Quote Originally Posted by MikeAdu View Post
    I'm sorry?.... I get a red b1 LED that shows up on the motherboard.
Tags for this Thread
