Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 30
  1. #11
    ROG Member Array
    Jun 2017
    14
    Quote Originally Posted by Riicckk View Post
    The first step is to make sure you have the latest bios. Try that first as suggested.
    Hi Riicckk,
    I have gone on the ASUS website, clicked others, BIOS and have received these options below:
    https://icr-emea.asus.com/webchat/ic...046.1494543258
    And it gives me 2 options on the left of the screen which are:
    1. [Desktop PC/All-in-One PCs]ASUS Manager-Update(Application/Driver/Bios)
    2. [Motherboard][Video]MB EZFlash 2
    So I am unsure as to what approach I should use.
  2. #12
    ROG Enthusiast Array
    Oct 2015
    42
    Go to https://www.asus.com/Motherboards/RA...Desk_Download/
    Select OS used, scroll down to bios and choose latest.
    Follow Chino's advice by extracting zip file to fat32 formatted USB drive, and use EZ Flash Utility in bios to update.
    If you want more info on updating bios please search these forums; there is plenty of advice. Or search the Asus website, etc
    If you are still not happy to upgrade bios then try my suggestion on removing Hibernation. You won't do any harm.
    Should you want to re enable hibernation use the admin cmd prompt and use
    powercfg -h on
    Then Reboot
  3. #13
    ROG Member Array
    Jun 2017
    14
    powercfg -h on
    Then Reboot
    Hi Riiicckk,
    I have downloaded the latest file and extracted it to a FAT 32 USB drive. How do I use the EZ Flash Utility in BIOS? and also why do you say if I am unhappy that I should remove hibernation? why would I be unhappy at updating BIOS is it risky? or will I lose any of my files/documents? is there a downside to updating BIOS through EZ flah utility?
    Thanks.
  4. #14
    ROG Guru: Grand Master Array
    Oct 2012
    339
    15,255
    Spam the Del key when you see the logo. Navigate to the last tab. You will find the EZ Flash Utiltiy there.
  5. #15
    ROG Member Array
    Jun 2017
    14
    Quote Originally Posted by Chino View Post
    Hi Chino,
    Is it safe to do? Will I not lose my files/documents?
    Thanks.
  6. #16
    Oct 2015
    42
    You won't lose any of your data, however updating the bios should always be treated with care and no one is 100% sure that something won't go wrong.
    Take care and everything should be ok.
    Remember, that any data that you do not want to lose should be backed up to an offline external drive or whatever. This should be carried out at regular intervals even if you are not doing any maintenance or bios update etc.
    Remember backup your data, then backup again. You can't have too many backups. Believe me, I have learned the hard way over the years.....
  7. #17
    ROG Guru: Yellow Belt Array MikeAdu PC Specs
    MikeAdu PC Specs
    MotherboardAsus Rampage V Extreme/U3.1/3701 BIOS
    ProcessorIntel i7 5960X @strap 100/4,0/3.5 1,15V both/1.92V input
    Memory (part number)CMD32GX4M4B3333C16 (two sets,64Gb,8 slots)
    Graphics Card #1Asus GTX 1080 Ti Turbo
    Graphics Card #3Asus GTX 1080 Ti Turbo
    Sound CardCreative Sound Blaster ZxR
    MonitorSamsung T260HD
    CPU CoolerEK Supremacy EVO waterblock,1x360mm + 2x240mm + 2x120mm radiators
    CaseCorsair T760 White
    Power SupplyCorsair AX1500i
    Keyboard Logitech G19S
    Mouse Logitech G700S
    Headset Logitech G35
    Headset/Speakers Logitech Z-5500 Digital 5.1 Speaker System
    OS Windows 10 64bit/Windows 8.1 64bit/Windows 7 64bit
    Nov 2016
    13
    245
    Hi.
    This is how I updated my Bios several times.
    1.Clean CMOS.
    2.insert your USB drive into bios flashback USB port.
    3.Press and hold button with two "crossed circles".After seconds this button will start to flash.Firs it will flash slow then faster and faster.After update is done this button will NOT flash(it will be Off).
    After that clean CMOSS one more time and then hit the Power button.
    Let us know did that helped or not.
    If not,press and hold MEM OK button.Maybe it will help also.
    Отправлено с моего iPhone используя Tapatalk
  8. #18
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    20
    1,470
    Quote Originally Posted by MikeAdu View Post
    Hi.
    1.Clean CMOS.
    That'r proper way for installing BIOS and somehow I have more confidence than in EZ Update through mobo BIOS.
    But second one work as well. Only if someone have issue there is probably big change that will be fixed with ASUS Flashback method.
    If you turn off PC or restart and you see some code it's better to shut down system holding mobo power button few seconds and than to wait few minutes and turn again. There is very big chance that will boot normaly.
  9. #19
    ROG Guru: Yellow Belt Array AdamC PC Specs
    AdamC PC Specs
    MotherboardR5E
    Processori7 5930k
    Memory (part number)8 x G.SKILL Ripjaws F4-3000C15Q-16GRBB
    Graphics Card #1MSI GTX980Ti
    Graphics Card #2MSI GTX980Ti
    Monitor3 x BenQ BL3201PH
    Storage #1SAMSUNG XP941 512G
    Storage #2Too many to list
    CPU CoolerNoctua NH-D15
    CaseRosewill THRONE-W
    Power SupplyEVGA 220-P2-1200-X1
    OS Windows 7 64 Ultimate
    Dec 2014
    27
    136
    I have had this same b1 problem since I got this mb. It happened once in a while. Drain the power then start up always fix this problem. No you don't need to clear the CMOS. Just drain the power off the mb by holding the power switch for a few seconds while the power supply is unplugged or switched off.
  10. #20
    ROG Member Array
    Jun 2017
    14
    primar 4600
    Quote Originally Posted by AdamC View Post
    Yes this is what I had attempted previously but than realized this shouldn't be the only solution, having to unplug the power button or push it down when the power is off. It didn't make sense thus I was looking for a permanent fix/solution...........
Tags for this Thread
