RAMPAGE V EXTREME MOTHERBORD b1 error code, monitor no signal.
saf99
Hi there....
I have built a PC end of 2015 and I have a ASUS RAMPAGE V EXTREME motherboard fitted. Occasionally there have been cases where upon powering up the PC the screen will remain blank with a no signal message displayed and an error code b1 will be displayed by the motherboard LED.
One occasion I had this problem so I believe I either restarted or took out the CMOS button (the first a friend I believe took it out or pushed the button on the motherbord for around 5 secs or so and rebooted the motherboard); the second more recently where I was unable to find the button on the motherboard but I pushed the CMOS button at the back of the panel of the tower which I found. However prior to this I could not find a solution and I used to unplug the power cable hold down the power button for a minute or so and then plug back in the power cable and turn the computer on. This also used to work for me...........
Now I have realised that every so now and again this problem will arise BUT I am unable to find a permanent fix for this problem; I have looked on various forums and some of the solutions were a bit too technical for my understanding and some did not work for me though they worked for other people.
Hence I now seek some help into anyone that may be able to help me with this problem; and would really appreciate any help from you tech experts on here......
My PC Specs are:
System Information report written at: 06/06/17 18:20:19
System Name: SAFRAN-PC
[System Summary]
Item Value
OS Name Microsoft Windows 10 Pro
Version 10.0.14393 Build 14393
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name SAFRAN-PC
System Manufacturer ASUS
System Model All Series
System Type x64-based PC
System SKU All
Processor Intel(R) Core(TM) i7-5960X CPU @ 3.00GHz, 3001 Mhz, 8 Core(s), 16 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 1701, 14-Aug-15
SMBIOS Version 2.8
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer ASUSTeK COMPUTER INC.
BaseBoard Model Not Available
BaseBoard Name Base Board
Platform Role Desktop
Secure Boot State Unsupported
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "10.0.14393.206"
User Name Safran-PC\Safran
Time Zone GMT Daylight Time
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.9 GB
Available Physical Memory 11.8 GB
Total Virtual Memory 31.9 GB
Available Virtual Memory 27.3 GB
Page File Space 16.0 GB
Page File C:\pagefile.sys
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware No
Hyper-V - Data Execution Protection Yes
[Hardware Resources]
[Conflicts/Sharing]
Resource Device
I/O Port 0x00000000-0x0000000F Direct memory access controller
I/O Port 0x00000000-0x0000000F PCI Express Root Complex
I/O Port 0x000003C0-0x000003DF PCI-to-PCI Bridge
I/O Port 0x000003C0-0x000003DF NVIDIA GeForce GTX 980 Ti
Memory Address 0xFB600000-0xFB6FFFFF PCI-to-PCI Bridge
Memory Address 0xFB600000-0xFB6FFFFF ASMedia USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
I/O Port 0x0000E000-0x0000EFFF PCI-to-PCI Bridge
I/O Port 0x0000E000-0x0000EFFF NVIDIA GeForce GTX 980 Ti
Memory Address 0xFB700000-0xFB7001FF Asmedia 106x SATA Controller
Memory Address 0xFB700000-0xFB7001FF PCI-to-PCI Bridge
I/O Port 0x00000580-0x0000059F Intel Device
I/O Port 0x00000580-0x0000059F Motherboard resources
Memory Address 0xA0000-0xBFFFF PCI-to-PCI Bridge
Memory Address 0xA0000-0xBFFFF PCI Express Root Complex
Memory Address 0xA0000-0xBFFFF NVIDIA GeForce GTX 980 Ti
Memory Address 0xC0000000-0xD1FFFFFF PCI-to-PCI Bridge
Memory Address 0xC0000000-0xD1FFFFFF PCI Express Root Complex
Memory Address 0xC0000000-0xD1FFFFFF NVIDIA GeForce GTX 980 Ti
Memory Address 0xFB200000-0xFB4FFFFF PCI-to-PCI Bridge
Memory Address 0xFB200000-0xFB4FFFFF Broadcom 802.11ac Network Adapter
I/O Port 0x000003B0-0x000003BB PCI-to-PCI Bridge
I/O Port 0x000003B0-0x000003BB PCI Express Root Complex
I/O Port 0x000003B0-0x000003BB NVIDIA GeForce GTX 980 Ti
Memory Address 0xFA000000-0xFB0FFFFF PCI-to-PCI Bridge
Memory Address 0xFA000000-0xFB0FFFFF NVIDIA GeForce GTX 980 Ti
[DMA]
Resource Device Status
Channel 4 Direct memory access controller OK
[Forced Hardware]
Device PNP Device ID
[I/O]
0x00000290-0x0000029F Motherboard resources OK
0x0000E000-0x0000EFFF PCI-to-PCI Bridge OK
0x0000E000-0x0000EFFF NVIDIA GeForce GTX 980 Ti OK
0x000003B0-0x000003BB PCI-to-PCI Bridge OK
0x000003B0-0x000003BB PCI Express Root Complex OK
0x000003B0-0x000003BB NVIDIA GeForce GTX 980 Ti OK
0x000003C0-0x000003DF PCI-to-PCI Bridge OK
0x000003C0-0x000003DF NVIDIA GeForce GTX 980 Ti OK
0x00000070-0x00000071 System CMOS/real time clock OK
0x00000074-0x00000077 System CMOS/real time clock OK
0x00000020-0x0000003D Programmable interrupt controller OK
0x000000A0-0x000000BD Programmable interrupt controller OK
0x000004D0-0x000004D1 Programmable interrupt controller OK
0x0000D000-0x0000DFFF PCI-to-PCI Bridge OK
0x00000000-0x0000000F Direct memory access controller OK
0x00000000-0x0000000F PCI Express Root Complex OK
0x00000081-0x00000083 Direct memory access controller OK
0x00000087-0x00000087 Direct memory access controller OK
0x00000089-0x0000008B Direct memory access controller OK
0x0000008F-0x0000008F Direct memory access controller OK
0x000000C0-0x000000DF Direct memory access controller OK
0x00000580-0x0000059F Intel Device OK
0x00000580-0x0000059F Motherboard resources OK
0x000003E0-0x00000CF7 PCI Express Root Complex OK
0x00001000-0x0000FFFF PCI Express Root Complex OK
0x0000F070-0x0000F077 Intel(R) 9 Series Chipset Family SATA AHCI Controller OK
0x0000F060-0x0000F063 Intel(R) 9 Series Chipset Family SATA AHCI Controller OK
0x0000F050-0x0000F057 Intel(R) 9 Series Chipset Family SATA AHCI Controller OK
0x0000F040-0x0000F043 Intel(R) 9 Series Chipset Family SATA AHCI Controller OK
0x0000F000-0x0000F01F Intel(R) 9 Series Chipset Family SATA AHCI Controller OK
0x000000F0-0x000000F0 Numeric data processor OK
0x00000500-0x0000057F Motherboard resources OK
0x00000400-0x0000047F Motherboard resources OK
0x00000092-0x00000092 Motherboard resources OK
0x00000010-0x0000001F Motherboard resources OK
0x00000072-0x00000073 Motherboard resources OK
0x00000080-0x00000080 Motherboard resources OK
0x00000084-0x00000086 Motherboard resources OK
0x00000088-0x00000088 Motherboard resources OK
0x0000008C-0x0000008E Motherboard resources OK
0x00000090-0x0000009F Motherboard resources OK
0x00000600-0x0000061F Motherboard resources OK
0x00000880-0x00000883 Motherboard resources OK
0x00000800-0x0000081F Motherboard resources OK
0x00000061-0x00000061 System speaker OK
0x00000062-0x00000062 Microsoft ACPI-Compliant Embedded Controller OK
0x00000066-0x00000066 Microsoft ACPI-Compliant Embedded Controller OK
0x00000040-0x00000043 System timer OK
0x00000050-0x00000053 System timer OK
So if anyone of you tech specialists can read over this and let me know of the solution to this problem as it has been bugging me for quite a bit......MUCH APPRECIATED.
Thanks for your time & effort.
Saf
29 REPLIES 29
Hi Chino,
Thanks for your reply.....I have been thinking of doing this but I am not sure how to do this; I mean I went on the ASUS website but I wasn't sure what I needed to download as there were a whole lotta files on there......
Thanks,
Saf
saf99 wrote:
Hi Chino,
Thanks,
Saf
Look under Others than BIOS.
Put the file on a FAT32 formatted USB pendrive and use the EZ Flash Utility inside the BIOS for the update.
Try turning off Hibernation in Windows 10.
In an elevated command prompt, copy and paste the command below, and press Enter.
powercfg -h off Reboot.
This will also turn off Fast Start in Windows 10. It won't make any difference to boot time. Can cure a wealth of boot problems if using EUFI bios.
In previous post there is typo.
The admin command prompt is only.
powercfg -h off
Then reboot. Sorry, should have put in full stop .
Hi guys.....
Thanks for your replies.....
Okay what should I do first? I've noticed some of you have given different instructions. Should I do the update first?
Thanks.
The first step is to make sure you have the latest bios. Try that first as suggested.
Hi Riicckk,
I have gone on the ASUS website, clicked others, BIOS and have received these options below:
https://icr-emea.asus.com/webchat/icr.html?rootTreeId=EMEA.ACUK.EN-UK&treeId=EMEA.ACUK.EN-UK.Desktop...
And it gives me 2 options on the left of the screen which are:
1. [Desktop PC/All-in-One PCs]ASUS Manager-Update(Application/Driver/Bios)
2. [Motherboard][Video]MB EZFlash 2
So I am unsure as to what approach I should use.
Go to https://www.asus.com/Motherboards/RAMPAGE_V_EXTREME/HelpDesk_Download/
Select OS used, scroll down to bios and choose latest.
Follow Chino's advice by extracting zip file to fat32 formatted USB drive, and use EZ Flash Utility in bios to update.
If you want more info on updating bios please search these forums; there is plenty of advice. Or search the Asus website, etc
If you are still not happy to upgrade bios then try my suggestion on removing Hibernation. You won't do any harm.
Should you want to re enable hibernation use the admin cmd prompt and use
powercfg -h on
Then Reboot
