Results 1 to 4 of 4
    ROG Member Array Ram Page PC Specs
    Ram Page PC Specs
    MotherboardC6H
    Processor1800X
    Memory (part number)F4-3600C16D-16GTZ
    Graphics Card #1Gigabyte GTX980ti Xtreme Gaming
    MonitorBenq Zowie XL2730 x 3
    Storage #1Samsung 950 M.2 256 Gb
    Storage #2WD Caviar 2 TB x 2
    CPU CoolerBe Quiet Silentloop 280
    CaseFractal Define R5
    Power SupplyCorsair RM1000X
    Keyboard Razer Ornata Chroma / Razer Orbweaver
    Mouse Corsair M65 Pro RGB
    Headset Steelseries Siberia 830
    Mouse Pad Templarius...
    Headset/Speakers Jamo via SPDIF on Sony amp.
    OS W10H 1607
    Network RouterCisco 3829 cable
    May 2017
    Massive VRM and Chipset temps?!
    I had everything default/auto except RAM was clocked up to 3200 Mhz (DRAM V and DRAM Vboot manually to 1.45). AIDA64 showed randomly very high temps for Chipset and VRM. Chipset was sharp 100 C/212 F and VRM 245 C/473 F :O Were they really that hot or was it some sort of a software error or such? Any idea why this happens? Or have I forgot to set something important in BIOS?
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    183
    8,327
    I guess those were errors... at those temps you should have seen some smoke... - or at least feel it by approaching your fingers (not touching!)...
    Ram Page PC Specs
    MotherboardC6H
    Processor1800X
    OS W10H 1607
    May 2017
    Thanks for the reply. Yeah I think so too I downloaded HWInfo64 to see more correct readings. I guess my OC settings messed up AIDA64 somehow. With the default settings I haven't seen no more such readings.
    ex-ASUS Employee Array Eleiyas PC Specs
    Eleiyas PC Specs
    MotherboardASUS 970 PRO GAMING/AURA
    ProcessorAMD FX 8370
    Memory (part number)Corsair 8GB XMS3 PC3-12800 1600MHz DDR3
    Graphics Card #1XFX AMD Radeon HD 6950 - 2G
    MonitorLG Flatron E2240T 21.5'' 1080p Monitor
    Storage #1Samsung 1TB 7200RPM 32MB
    Storage #2Seagate Barracuda 2TB 7200RPM 64MB 6GB/s
    CPU CoolerAMD Wraith Cooler
    CaseNZXT Lexa S
    Power SupplyCorsair CX600 600W (Bronze)
    Keyboard Logitech Wireless AZERTY
    Mouse Microsoft Wireless
    Headset Evil Witchcraft II Gaming Headset (Black/Red)
    Mouse Pad Wild Wolf Hunter
    Headset/Speakers 4Gamers 2.1 Sound-System
    OS Windows 10 Professional - Creator's
    Network RouterZiggo
    Mar 2017
    25
    378
    At those temps, not only would the PC have auto-shutdown due to security measures, but you would have indeed seen smoke and probably heard a bang.
    If your PC wasn't radiating heat like a gas heater, then I would definitely say it was a software bug.
