Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    ROG Member Array
    Mar 2015
    16
    Talking [Case Mod] Aero Cube
    Hey enthusiastic PC builders,
    I'm going to start a new casemod, this time a micro-ATX build in the Aerocool DS cube.
    It has to be an HTPC that can also be used as a LAN-box, so it has to be a freaking awesome case.
    Hardware : not known yet
    Cooling components: Not known yet
    Here are some pictures of the Aerocool DS Cube.
    Playing with some LED`s.
    See you soon
    ROG Member Array
    Mar 2015
    16
    This week started making a midplate and some minor adjustments to the case itself :
    Pre-drill the holes and then cut out with the cutter.
    Mid plate fits perfectly :
    I made a window in both side panels, here you can see the graphics card en later the cooling en hardware.
    Problem ?? Little space for power cables,s o I did a little adjustment.
    Did some wrapping on the midplate with some mat black.
    ROG Member Array
    Mar 2015
    16
    I got the idea of ​​making a pump with reservoir combo in the front of the case, so the round hole has already been made.
    Had two more pass through fittings spare, so I used them to make an easy connection through the midplate.
    ROG Member Array
    Mar 2015
    16
    Hey, another update.
    This week I started with the front panel of the case.
    I used the Asus Mayan pattern for the front, later on there will be a lot of RGB led`s behind this panel and case parts.
    Used some primer, more in the next update
    If you have any questions, I'd love to hear those
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600
    Memory (part number)16GB DDR4
    Graphics Card #1GTX980
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    293
    7,296
    What did you use to make your cuts?
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Member Array
    Mar 2015
    16
    Quote Originally Posted by xeromist View Post
    I used a Fretsaw, I spent about two nights doing it.
  7. #7
    xeromist PC Specs
    ProcessorAMD 2600
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    293
    7,296
    I'm impressed by your patience. I probably would have sent it out for laser/water cutting or something.
  8. #8
    ROG Member Array
    Mar 2015
    16
    I call this Case modding DIY.
  9. #9
    ROG Member Array
    Mar 2015
    16
    I got a new tool for modding, bought this airbrush starter-pack with some paint to get started.
    For a first time I did a nice job I think, of course there are some points we can improve but we can work on that.
    These colors I`m going to use on the case. (red madder dark, black)
    First I used the color (red madder dark), then I used a airbrush and brush and added the color (black). And added a clear coating, for a first time I did a great job I think.
    The sharpness of the pictures will improve in the next update.
  10. #10
    ROG Member Array
    Mar 2015
    16
    So I got two packages last week, one with all the hardware and one from Highflow.nl with all the cooling parts. So let`s get started with the inside.
    MB: Asus ROG Strix Z270G Gaming
    CPU: Intel Core i7-6700K
    GPU: Asus Strix GTX1070 O8G Gaming
    RAM: Avexir ROG Tesla Red 2666 MHz 16GB
    PSU: Corsair RM850I
    And of course ''CableMod''
    For cooling I chose EKWB
    EK-FC1080 GTX Strix – Nickel with a shinny Nickel Backplate
    EK-Supremacy EVO – Nickel
    A group photo
    It`s time for some PETG bending
    EK-XRES 140 DDC 3.2 PWM Elite – incl. pump
    Best handy tool ever, no sharp edges anymore.
