Results 1 to 9 of 9
    ROG Member Array Dnice1224 PC Specs
    Dnice1224 PC Specs
    MotherboardAsus Strix Z270E
    ProcessorKaby Lake i7 7700K
    Memory (part number)F4-3200C16D-16GTZB
    Graphics Card #1Strix GTX 970
    Storage #1SAMSUNG 850 EVO 2.5" 250GB
    Storage #2WB 1 TB Black Edition HDD
    CPU CoolerCorsair H115i
    CasePhanteks P400S
    Power SupplyCORSAIR RMx Series RM850X 850W 80 PLUS GOLD
    OS Windows 10 64 Bit Home Edition
    Network RouterApple Airport Extreme 2TB
    Jun 2017
    5
    Strix Z270E MB PWM case fan issues
    Hello Community how are you?
    I wanted to check with the community to see if anyone is having the same problem as I am. I have a 7700k paired with the z270e motherboard, along with the corsair h115i. I currently have 3 case fans hooked up the the PWM fan headers. I have two 140mm fans and one 120mm exhaust fan. The issue that I'm having is that my fans are throttling from the highest rpm, to the lowest rpms. It almost seems as if whenever the CPU comes under the slightest load the fans will ramp up and then gradually go down. This will repeat itself the whole time my machine is powered on. So far I have cleared my CMOS two times. I have reinstalled windows 10 twice along with that. In addition to these things I have tweeked the Q fam control quite a bit. I have tried manually configuring when the fans whould go to higher Rpms etc... I have even tried to put the profile on silent mode to no avail. Before I have the 3pin pump connector in the AIO header, and I had the other 3 fans in the CPU header, cha1, and cha2. As part of my trouble shooting I have put the pump header in the CPU output and placed the other fam headers else where. I have exhausted all options have have sinc e contacted Asus to initiate a Rma. Is it something that I'm overlooking? The last thing I want to do is RMA my board so any helpful feedback I would be most gracious.
    Dnice1224 PC Specs
    CasePhanteks P400S
    Jun 2017
    5
    Yes I updated to the lastest bios. I had this problem with the previous version also.
    ROG Guru: Yellow Belt Array Legolas PC Specs
    Legolas PC Specs
    MotherboardMaximus X Hero Wifi AC
    ProcessorIntel Core i7 8600k oc 5Ghz
    Memory (part number)Samsung DDR4 16GB
    Graphics Card #1ASUS NVIDIA GTX 1080
    MonitorASUS MS246
    Storage #1Samsung MZVPV256
    Storage #2Samsung MZVPV256
    CPU CoolerCorsair H110I v2
    Power SupplyPC 1200W Turbo-Cool 1200
    Keyboard ASUS SK2045
    Nov 2015
    242
    Also, make sure you connect the USB from Corsair H115 to the USB fan header (ROG_EXT, , looks like USB header with 1 pin missing)
    In BIOS, I went to monitor -> Q-fan Configuration -> AIO_PUMP/W_PUMP+ Control -> Disabled, F10 and saved. I let the Corsair LINK have full control of the water cooling fans and speeds.
    I also did a QFAN Tuning in monitor and then Disable AIO_PUMP controls
    Sincerely,
    Legolas
    Dnice1224 PC Specs
    CasePhanteks P400S
    Jun 2017
    5
    Quote Originally Posted by Legolas View Post
    yes everything with the AIO system is hooked up correctly. I already *have two fans that are currently hooked directly to the AIO cooling system fan connectors. I do have an PWM fan splitter I'm going to try what you suggested and hook all of my case fans up the the AIO cooling system so that the corsairlink software can control everything as you mentioned.*
  7. #7
    Dnice1224 PC Specs
    CasePhanteks P400S
    Jun 2017
    5
    Quote Originally Posted by Chino View Post
    Have you tried configuring the Duty Cycle manually?
    Is this something that i can do under the Q fan control? If not could you please walk me through how i could accomplish this?
  8. #8
    ROG Guru: Blue Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardMaximus Hero XI
    Processor9900k @ 5.1Ghz All Core 1.315v AVX -2
    Memory (part number)Gskill GTZ 4133 C17 32GB (4x8GB)
    Graphics Card #1ROG Strix 2080 TI OC
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 970 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 970 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks Evolv X
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur VOID Pro
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    79
    912
    I'm set up the same way and use Fan Expert to control the pwm case fans. You can adjust how many seconds of tamp up/ramp down time in the fan profiles. This controls the surge nicely on temporary CPU temp spikes.
  9. #9
    Dnice1224 PC Specs
    CasePhanteks P400S
    Jun 2017
    5
    Quote Originally Posted by mdzcpa View Post
    Thank's for the information I will certainly implement this!
