Gtx 1080 oc 8gb 11gbps bios problem
ivo63
Hi today I have update to a new tool quiet bios rev. AS04 but now the all fans run and stop quickly also to hight temps and the a fan sometimes is always stop.*
Now I want to return to original bios 86.04.66.00.38 AS01more better.*
This problem is allowed to own gtx1080 Ti but in download section of gtx1080 08C 11gbps there is only one bios and *no the original...
Please help me *
33 REPLIES 33
ivo63
Hi nobody can help me?*
bios original version : 86.04.66.00.38 AS01>
*>installed with update : 86.04.66.00.38 AS04 tool quiet >
*>I want to instal the original version
nobody help me?*
haihane
ok.
can ya tell me the exact model of your GTX 1080? and we'll see where to go from there.
no siggy, saw stuff that made me sad.
Thank Asus Strix GTX1080 oc 8gb 11gbps I have installed this bios (tool qiuet version) by Asus site*
https://www.asus.com/it/Graphics-Cards/ROG-STRIX-GTX1080-O8G-11GBPS/HelpDesk/?SearchKey=gtx%201080/
original bios version was :86.04.66.00.38 AS01
the tool quiet version is : 86.04.66.00.38 AS04
haihane
Description Bios update tool
Quiet BIOS for ROG-STRIX-GTX1080-O8G-11GBPS
File Size 3.89 MBytesupdate 2017/05/04
Download from Global
there's this thing. tried this yet?
ah shoot. sorry. i thought it included GPU bios flasher
haihane
http://www.overclock.net/t/1627212/how-to-flash-a-different-bios-on-your-1080-ti found
edit again: shoot. now i get it.
you telling me you used that GPU flasher from asus, one click flash and easy flash to update your bios right?
have you done a manual flash before?
the guide is for 1080ti, don't use the flash rom there. but rather find your original 1080 ROM.
i can't seem to find it. but i did remember there was a site that collected these flash roms. will update when i find it.
edit 2:
found : https://www.techpowerup.com/vgabios/
find your GPU here. then update it.
Thank on the TechPowerUp site there is no.*
I would donwload only from official site like Asus for safety *
haihane
well, you should have saved your original rom using GPUz then 😕
