Results 1 to 3 of 3
    ROG Guru: White Belt Array
    May 2016
    114
    Is there a noticeable difference between 100hz and 144hz?
    I am planning to buy a new 144hz monitor and wonder if it is worth it.
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    183
    8,327
    With your bare eyes most likely you won't see any difference over 60Hz...
    ROG Guru: Blue Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardMaximus Hero XI
    Processor9900k @ 5.1Ghz All Core 1.315v AVX -2
    Memory (part number)Gskill GTZ 4133 C17 32GB (4x8GB)
    Graphics Card #1ROG Strix 2080 TI OC
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 970 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 970 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks Evolv X
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur VOID Pro
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    79
    907
    I can definitely tell the difference between 60hz and 100hz (or 144hz). Even on the desktop you can tell. That said, I have a hard time discerning anything 100hz and up. If you are already at 100hz, the upgrade to 100hz isn't going to be noticeable.
