DDCM Desk Project: Unique. Simple. Powerful
DD_Custom_Mods
It’s time for DDCM to start the next project!
So… I present to you, DDCM Desk! Unique. Simple. Powerful.
We will start by thanking our sponsors that have partnered with us to make this project a reality!
First, we start with ModMyMods.com(MMM), who partnered with DDCM for our last mod, Project: Military Tech. They have continued their support and I’m very excited that they are coming onboard again.
Second, we welcome a new partner with DDCM, Alphacool! After hearing about our project and about PMT, they were happy to join MMM in supporting this project.
Third, we have another new partner in InWin. They will be supplying the Aurora fans and Classic 900W PSU for the build!
I can't believe we've already gained a 4th sponsor! Nanoxia will be supplying our beast of a desk with their one and only Retro Mechanical Keyboard with the white switches. I can't wait to feel the typewriter nostalgia again!! Now it looks like I'm going to have to mod a mouse to match....
Project background:
Inspired after I saw several majestic works of PC art and the need to replace my old desk. My old desk was clunky, super heavy, and only provided a cabinet with limited airflow for the storage of my modded PC, Night Shark.
After great PC desks like L3p D3sk by Peter Brands and Project Alternate by DeBlow came into the spotlight, I began to contemplate ways to own such a unique piece of modding mastery. As I have always been a fan of the non conventional builds, thus became the challenge of making one my own. Now that my workshop can handle this sized project and I gave away my old desk to a local gamer, the stage is set to begin my own approach to the PC Desk culture. It has been a long time since I have created something for my personal use and very excited about the prospect of recording/editing content on this new desk.
So kick back relax and enjoy this journey with me as I work to create this unique creation. Let me know what you think and I’m always open to hear suggestions or other’s experience with similar projects.
Our final renders. With a possible move in the near future, I will most likely make it a free-standing desk instead.
35 REPLIES 35
DD_Custom_Mods
26 June 2017
Good morning DDCM fans and followers!
Time for another #DDCMdesk update:
Today let’s work with a little wood. Some might argue my choice of material, but sticking with the theme of being unique, I picked up a sheet of ¾” Radiata Pine Plywood.
First steps began with marking out my first cuts of the pieces. Hardest part was trying to figure out how much angle I needed to ensure my planned components would fit. Thankfully, my old, well used components come to my rescue again.
Angled pieces cut out as the starting point to the rest of the build. Then I moved onto the second cut which is the first angled front window. By why stop there, after mocking up the cuts we continued to cut the back angle and the underside(5gal for reference). Next steps, the mid shelf and the bottom piece to measure and cut.
07/03/2017
Once the panels were cut, we needed to get all the miter cuts so that we can continue forward with the brads and glue. Thank you to the one and only Mod-squito for confirming my technique would work. Nothing like trying to cut angles with only a skill saw. Always have a straight edge guide or at least a factory cut edge of a board.
Once all the mitered edges were set up and verified everything joined up the way it should, it was time to start glue and nailing the panels together. We start with the bottom brace that the back panel will hinge off of.
Then we cut the main window out and got the rest of the panels glued together. Each join was reinforced with 1 ¼” brads shot with my nailer.
Then we moved on to cut out the middle shelf that the radiators will mount to. Got it cut and fit nicely with a mitered edge to join with the angled back panel.
Next up, cut out the side window and cut/nail the base plate.
08/14/2017
First, I share our current setup…… Be gentle on this poor man.
Second, the last progress of the desk included mounting the mid shelf to the back piece.
Last but not least, we have our first procured part for the desk….. a Seagate Barracuda 2TB drive. Initially purchased to back up our media/important files before I dare shut down everything and move it to the new house.
Next up, cut out the side window and cut/nail the base plate. Once we have our workshop set up at the new house. In the meantime, we are working on getting more parts/sponsorships.
I apologize for the lack of quicker updates, the project is on a slight hiatus as we get settled into our new house and I have been DIY working all over the house. The wife has kept me busy on the projects so I’ve only managed to get my workshop set up.
But I wanted to drop a quick update to introduce our new sponsor!
That’s right! InWin has been gracious enough to sponsor DDCM desk project! They are going to be sending two of their awesome products!
Their Aurora fan kits(which of course will be red LEDs)
And their Classic Series 900W power supply!
I can’t thank them enough and I can’t wait to get the unboxing video done! Will be posted to our YT channel: https://www.youtube.com/channel/UCog6RbBUSD_zfNEujIBX2dg
Until our next update on the desk, we will be working on a client mod of a NZXT H440 with a Final Fantasy X theme. 😮
Happy Modding all and thanks for sticking with us. 😄
We’ll start off this update with the updated renders. Made to match the cabinet shape a little better and shortened the length to fit in the new room. We lost the Sketchup file and had to rebuild from scratch so I apologies if things are a little off.
Next we’ll move onto showing off our legs….. our black IKEA table legs that is. Black polished metal and adjustable. Going to work perfectly!
While waiting for some paint to dry on our client’s build, we got some backplates marked out for the desk. Motherboard, GPU, 2x SSD, PSU bracket
Also we set up a temporary desk as the wife was going to kill me if she had to work on the budget using her Macbook only. *chuckles*
Finally, we’ll wrap up this update with a picture of our part’s shelf getting full and linking our unboxing from Inwin below. Thanks for tuning in and having patience as we work through this desk project.
Unboxing Video of InWin goodness!(PSU and Aurora Fan Kits):
https://youtu.be/U_Z91F2SCAM
How about some DDCM desk PC current state updates?
First our current state of DDCM desk PC, we now have both side windows cut out, the base plate cut and placed, and everything trimmed to fit nicely. Next steps, attach the hinge, cut the desk top, and get ready to start painting!
Our biggest thanks to ModMyMods, Alphacool.com, and In Win USA for helping make this a reality!
For those bored enough... keep reading
Speaking of a hinge.... here's ours in all it's 24" steel glory! Going to need to trim off a couple inches to make it fit right.
Next tool upgrades, my wife was nice enough to pick up some metal Dremel blades and a 18" magnetic strip for more OCD in the dungeon.
But the rest of the DDCM desk PC updates, we first drug the Skilsaw outside and cut out the baseplate. The cut was so perfect and snug I almost don't need to nail it in place.
Then we got straight at plunge cutting the remaining side window hole. Our #DIY skills are improving!
After some small cuts to the backplate and shelf, everything fit nice and snug into its proper place.
Until next time.... Happy Modding!
How about another DDCM desk PC update? But first I want to say how much I appreciate each one of my fans and those who comment on my work. My passion is PC modding, but the fuel that ignites my drive is the interaction I get with my fans. So, again, thank you.
Now enough with the touchy feely stuff and get to the real heart warming stuff!
We marked out the component backplates on some ¼” white acrylic, then grabbed the jigsaw and got straight to cutting. We cut out the motherboard plate, GPU plate, SSD covers, and the PSU mount. Of course we had to test placement afterwards.
We then had a super early Christmas by getting not one sponsors packages but 3 sponsors in 2 boxes 😄 ModMyMods box contains my Alphacool motherlode as well. Baby dragon helps us protect our treasures before I take them to the modding dungeon! Keep an eye out for the unboxing videos on or YouTube channel….. or wait for the next update for the links.
For the unboxing videos I needed a table…. So I figured it was a good time to prep the rest of the desk top. First we marked our cuts out of my wife’s old craft desk top since it was a good pine.
After attaching the legs and getting them adjusted was just the natural next step.
And now I present the rough structure of the desk, now we start to get things placed and get the hinged door secured in place before painting.
I hope you have enjoyed this mild update!
Until next time, Happy Modding!
kkn
Level 14
looking great so far!
whow - fantastic idea! Hope to see the finished build soon
