Results 1 to 3 of 3
    ROG Guru: Orange Belt Array navis995's Avatar
    Oct 2014
    50
    320
    Read this if you're going to use thermal pads for GPU (G750)
    If you are going to use thermal pads for GPU VRAM modules and other chips DO NOT use 1mm thick ones as they are too thick, won't make great connection with cooling pad and cause high temperatures almost immediately.
    I have not tested it yet with 0.5 mm so they may be fine but 1mm is definitely too much.
    The laptop was Asus Rog G750JZ but I'm sure all of the G750 models have the same.
    Asus Rog G750JZ
    Screen: 1920x1080 17.3'
    CPU: Intel® Core™ i7-4700HQ (3.4Ghz @ -70mV)
    GPU: GeForce GTX 880M 4GB (OC +125Mhz Core, +600Mhz Memory @ 1.062V)
    RAM: Samsung 32GB 1600MHz
    Storage #1: Samsung Evo 840 250GB
    Storage #2: Samsung Evo 850 500GB
    Storage #3: Seagate Barracuda 2TB
    Storage #4: Samsung Evo 128GB MicroSD
    ROG Junior Member Array
    Sep 2014
    1
    Hello!
    Can you please share with us if the 0.5mm pads worked out? What pad thickness did you end up with?
    Oct 2014
    50
    320
    Quote Originally Posted by vakkov View Post
    Hello!
    I used the ones from artic silver and 0.5 worked great!
    Asus Rog G750JZ
Tags for this Thread
