06-27-2017 07:21 AM - last edited on 03-05-2024 12:26 AM by ROGBot
06-27-2017 08:15 AM
06-27-2017 07:17 PM
davemon50 wrote:
Question: is your system on a UPS with a managed shutdown during the power outage, or is your system just plugged directly into the wall? Also, when you had the power outage, how long was it? Or was it just a blip?
06-27-2017 08:53 PM
06-27-2017 10:56 PM
davemon50 wrote:
Yes because it's a blip it may not be recognized as an outage. Try this: go to your System & Security > System settings in the Control Panel > Advanced System Settings > Advanced Tab > Startup & Recovery Settings. Make sure you have Automatically Restart on System Failure checked.
06-28-2017 01:01 AM
infernovak wrote:
I checked the setting. It was already enabled. Any particular reason why this PC having C6H is causing issue and the other PC doesnt?
06-28-2017 03:54 AM
06-28-2017 05:23 AM
infernovak wrote:
Hi. I have surge protection power bar. I don't use a UPS because a) its backup is minimal and b) the inverter gives enough juice to run the PC without fail during power cuts. I am using 1401 BIOS.
The question is why does the mobo not recognize that the PC has powered off, even if the power comes back in a second. It only does when its thoroughly discharged in 5-10s.
06-28-2017 08:41 PM
06-29-2017 03:35 AM
infernovak wrote:
Thanks for your replies. My old Gigabyte x58 board works fine and reboots swell. Perhaps its a software/hardware thing for Asus Mobos, beyond my reach to modify. I guess buying a UPS to survive the 0.5s blip seems to be the last resort 🙂 *searching through pockets*
