Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 75
    ROG Guru: White Belt Array
    Jun 2013
    16
    79
    X299 VRM Disaster (overheat) ??
    Administrator Array Silent Scone@ASUS's Avatar
    Mar 2016
    124
    1,801
    Quote Originally Posted by Beto556 View Post
    Seems cooling is the issue here. At least the ROG offerings will be revised, but it's an age old problem. I will likely go monoblock for this generation, although I don't plan on subjecting the system to massive AVX loads.
    Active cooling can go a long way, even on the X99 Deluxe I always have a fan over the VRM - even though temps are well within spec without.
    ROG Guru: Blue Belt Array mdzcpa PC Specs
    mdzcpa PC Specs
    MotherboardMaximus Hero XI
    Processor9900k @ 5.1Ghz All Core 1.315v AVX -2
    Memory (part number)Gskill GTZ 4133 C17 32GB (4x8GB)
    Graphics Card #1ROG Strix 2080 TI OC
    Sound CardOn Board
    MonitorROG PG348Q
    Storage #1Samsung 970 Pro M.2 512GB for OS & APPS
    Storage #2Samsung 970 Pro M.2 1TB for GAMES
    CPU CoolerROG Ryujin 360
    CasePhanteks Evolv X
    Power SupplySeasonic Prime 1000W Titanium
    Keyboard Corsair K70 LUX RGB
    Mouse Corsair M65 RGB
    Headset Corsaur VOID Pro
    Mouse Pad Corsair MM300 Wide Desk Mat
    OS WIN 10 Pro
    Network RouterLinksys VELOP
    Accessory #1 ROG 751JY Laptop for Moobile Gaming
    Accessory #2 Koolance EXC-800 Chiller
    Accessory #3 25+ years of overclocking
    Nov 2011
    79
    907
    They will need to get this addressed asap. This issue is another casualty of Intel pulling ahead the release of X299 in response to AMD. What a mess
    I've been active cooling or water cooling my VRMs since X79 and the Rampage IV. There were heat issues with them too especially when water cooling and eliminating the minimal airflow over the VRM heat sink. BUT...those boards would not throttle in just 10 minutes with a modest over clock. So this issue is definitely worse here on X299. All the mobo makers need to re-think this or there will be too many novice or aesthetic orientated clockers running into throttling issues.
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    I'd like confirmation from more than one source.
    This guy could have received a "bad" processor part. Or he could have received a "bad" ASUS mobo. Did he even buy these parts, or are they pre-release media samples?
    Which firmware/BIOS version is he running? Exactly what BIOS settings did he change? What other power-sucking stuff does he have installed while measuring VRM temps?
    His methodology could somehow be flawed (though I don't know how, lol). Maybe he's even just using a lousy TIM.
    Or, yes, he could have measured a very real and possibly very serious VRM overheating issue. Exactly what the title says.
    I do actually applaud him for performing these measurements and reporting his findings. It provides a great service to those of us who cannot do such testing on a bunch of new X299 mobos ourselves.
    But a single motherboard from each manufacturer is not necessarily representative. Need more VRM temp measurements from different people running the same-model mobos before the apparent/speculative conclusion becomes an obvious/inarguable conclusion.
    This sort of thing is part of the reason I'm not rushing into X299 for the first year or so, lol. Maybe these temps can be corrected or reduced through firmware updates. Intel rushing the X299 launch (and thus rushing all mobo maker X299 launches) doesn't help, lol.
    ROG Guru: Brown Belt Array tistou77 PC Specs
    tistou77 PC Specs
    MotherboardRampage VI Extreme
    Processor7980XE @4.6Ghz
    Memory (part number)G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    Graphics Card #1EVGA RTX 2080ti XC Ultra
    Sound CardXonar Phoebus
    MonitorDell U2417H
    Storage #1Intel Optane 900P
    Storage #2Samsung 970 EVO Plus
    CPU CoolerWatercooling
    CaseLian Li A77F
    Power SupplySeasonic Prime Ultra Titanium 1000W
    Keyboard Logitech LIK
    Mouse Logitech MX revolution
    OS Windows 10 Pro x64
    tistou77's Avatar
    Apr 2012
    74
    1,340
    You do not know der8auer ??
    Sorry for my english
    Case: Lian Li A77F
    MB: Rampage VI Extreme
    CPU: i9 7980XE
    RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
    GPU: EVGA RTX 2080ti XC Ultra
    PSU: Seasonic Prime Ultra Titanium 1000W
    OS: Intel Optane 900P
    DATA: Samsung 970 EVO Plus
    SOUND: Asus Xonar Phoebus
    ROG Guru: Green Belt Array haihane PC Specs
    haihane PC Specs
    MotherboardCrosshair V Formula Z
    ProcessorAMD FX 8350
    Memory (part number)Gskill F3-2400C10-8GTX
    Graphics Card #1ASUS HD 6950
    Storage #1WD Velociraptor 1TB
    Storage #2Corsair Neutron GTX 120GB SSD
    CPU CoolerCooler Master Seidon 120XL
    CaseCooler Master Silencio 650
    Power SupplyCorsair HX850
    Keyboard Corsair K70 RGB
    Mouse Logitech G500
    OS Windows 7 X64
    Network RouterLinksys E2500
    haihane's Avatar
    Jul 2013
    106
    609
    Quote Originally Posted by tistou77 View Post
    i know him.
    don't mean everybody should know him though.
    @korth, news is legit (i think?) here are some more references:
    https://www.youtube.com/watch?v=q1apy-AgCRM
    https://www.youtube.com/watch?v=WyhJ8_d1FHM <- LinusTechtips' Wan show. seek to time @ 01:06:30
    no siggy, saw stuff that made me sad.
  7. #7
    mdzcpa PC Specs
    Sound CardOn Board
    MonitorROG PG348Q
    OS WIN 10 Pro
    Nov 2011
    79
    907
    I know der8auer fairly well. He is legit. The only real criticism I see of his testing was his choice of PSU. That particular model has some limitations on its 12v CPU 8 pin rail. That said, I'm suspecting since he tested on 3 brand of mobos, the issue is likely real. It's not a show stopper, but something all the board makers need to address. We haven't even seen the higher core count chips yet. The 7900X is enough to see the throttling without active cooling. If you see most of the reviews of 7900X thus far on X299, they have been using a fan over the VRMs for overlocking testing on their reviews. That's fine....but a bit misleading as most end users likely were not planning on a 100mm man over that area in a case.
    Again, for the hardcore guys, this is not an big issue. But for prosumer workstations or those folks concerned about case aesthetics and cooling...they need a better solution.
    I am also not rushing to the new HEDT this time. Too much movement in the segment at the moment, and lots of rushed and pulled ahead releases. I'm going to considering jumping after the dust settles.
  8. #8
    Korth PC Specs
    MonitorASUS PG278Q
    Korth's Avatar
    Mar 2015
    152
    2,719
    It's actually good that he chooses some components (like PSU) which better represent "typical" consumer choices. Not everyone will have an 1600W Titanium Supernova or Platinum AX1500i or monstrous server-grade super PSU.
    I agree, having now seen multiple reviews about this VRM overheat issue, it definitely appears legit.
  9. #9
    ROG Guru: Brown Belt Array abvolt's Avatar
    Aug 2013
    41
    1,131
    I was hoping to go x299 soon guess I'll wait & see..
    Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
    NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
    Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
    Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
  10. #10
    Korth PC Specs
    MonitorASUS PG278Q
    Korth's Avatar
    Mar 2015
    152
    2,719
    Intel is rushing i300 and Coffee Lake, too, again in (preemptive?) response to AMD offerings. New scheduled release dates have been bumped up, according to old "leaked" Intel roadmaps.
