Page 1 of 10 1 2 3 ... LastLast
Results 1 to 10 of 91
    ROG Guru: Yellow Belt Array xarot PC Specs
    xarot PC Specs
    Laptop (Model)Asus GL504GM
    MotherboardAsus Rampage VI Extreme
    Processori9-7980XE
    Memory (part number)Corsair Dominator Platinum 64GB CL16-18-18
    Graphics Card #1Palit RTX2080TI
    Sound CardIntegrated
    MonitorAsus PG279Q
    Storage #1Intel 750 1.2 TB PCIe
    Storage #2Samsung 960 Pro 1 TB
    CPU CoolerEK Supremacy EVO Full Nickel
    CasePhanteks Enthoo Primo
    Power SupplyCorsair AX1500i
    Keyboard Blackstorm Mech RGB
    Mouse Steelseries Rival 310
    Headset Sennheiser HD555
    Mouse Pad Razer Goliathus Extended
    OS Windows 10 x64
    xarot's Avatar
    Oct 2013
    44
    198
    Asus Strix X299-E very low SLI scaling after going from X99 to X299
    I posted this question on NVIDIA forums too but perhaps there's a chance someone else might have the same issue. I cannot tell if this a UEFI or driver problem?
    I have a strange problem with Strix X299-E motherboard and SLI with the latest NVIDIA driver 384.76 (actually, with any driver but the X299 platform is brand new and hit retail around week ago so I guess this is the correct to use).
    The thing is, SLI scaling is only around 45 % to 75 %, usually sits around 60 to 66 % per card only. The 1080TI cards and PSU have been working perfectly fine on old X99 before I swapped the motherboard and CPU. Everything else is the same. I have tried Windows 8.1 and Windows 10 to no avail, changed all UEFI settings, checked PCIe lane speeds, tried HB and single SLI bridges, disabled G-Sync, disabled V-sync, changed game settings, disabled antialiasing, updated UEFI, changed motherboard voltages and what else. Nothing else to try I guess.
    Only some titles like Metro 2033 seem to work somewhat normal, the rest don't. Even Fire Strike 1.1 doesn't but then again Fire Strike Ultra does? In Fire Strike 1.1 combined test the scaling is around 35 % per card and the scores are way off.
    Setup:
    i9-7900X
    Asus Strix X299-E motherboard
    64 GB DDR4-3200 MHz (yeah, a single kit, CMD64GX4M8B3200C16)
    Asus Strix 1080 TI OC SLI
    Asus motherboard bundled HB bridge
    Corsair AX1500i
    Asus PG279Q G-Sync
    Main: Xeon W-3175X - Dominus Extreme - 48 GB Corsair Dominator Platinum DDR4-3200 - Palit RTX2080TI H2O - Phanteks Enthoo Primo - Corsair AX1500i - Samsung 960 PRO 1 TB + Intel 600P 1TB
    HTPC: i7-6950X - X99-M WS - 32 GB G.Skill RipjawsV DDR4-2400 - GTX1070 - Bitfenix Pandora - Corsair AX860 - Intel 750 400 GB + Samsung 1 TB 850 EVO
    All around: i7-7980XE - H150i Pro - Rampage VI Extreme - 64 GB G.Skill 4000 CL18-19-19-39 - Strix RTX2060 - In Win 101C - Samsung 960 EVO 512 GB
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,718
    The (X299) chipset is still very new. And it was rushed to market, months ahead of Intel's initially "leaked" roadmap/schedule. There are always teething pains and unforeseen bugs on every first-gen platform release. (Low-power/sleep/shutdown faults, RAM compatibility issues, broken RAID, USB bugs galore, PCIe/SLI problems, M.2/NVMe worries ... all the usual sorts of stuff which eventually become evident and get fixed up, lol, and only made worse every time Microsoft pushes out a new WinOS version.)
    And - as with any other OEM mobo which implements nonstandard (non-Intel) features/extensions/functionality - your X299 may require firmware fixes from the OEM (ASUS) before "proper" functionality is realized. Blanketed within the usual "Increased stability / Increased compatibility / Increased performance" BIOS notes, lol.
    X99 and Z170 required a bunch of BIOS revisions, some NVIDIA driver releases, and countless Win10 driver updates before "everything just worked". X299 is just starting the cycle, lol, even AM4 stuff is slightly ahead. Just hope that ASUS can keep up with supporting all their existing i100/i200 mobos, upcoming i300 mobos, X99/X299 mobos, existing AMD mobos, upcoming AMD mobos, enterprise and consumer and gamer markets alike ... lol they'll be very busy debugging and supporting this glut of new chipsets/firmwares, and they're not making it easier for themselves by offering one or two dozen mobo variants for each generation.
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardM 10 Apex / XI gene
    Processor8700K / 9900K
    Memory (part number)2x8 Gskill Trident Z 4266/2x2x8 Gskill Trident Z 4500
    Graphics Card #1RTX 2080ti / GTX 1060
    Sound CardSoundBlaster Ae5 / Onboard
    MonitorBENQ 32" 4K
    Storage #1Intel 900p 480GB/Samsung 960 Pro 1TB
    Storage #2Intel 750 1.2TB/Plextor 1 TB 2X 950 Pro
    CPU CoolerCorsair H150i AIO / H1110i
    CaseCorsair 740 ? Lian Li Air
    Power SupplyCorsair AX 1200i / AX 1200i
    Keyboard Corsair
    Mouse ASUS Strix
    Headset HyperX Cloud Alpha
    Mouse Pad ASUS
    Headset/Speakers Logitech Z906
    OS 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 Intel Wifi BT pcie card
    Accessory #2 Red Bull
    Accessory #3 English Breakfast Tea
    Menthol's Avatar
    Jan 2012
    241
    4,548
    I don't know why you have poor sli scaling for sure, but if you read X299 reviews there are issues related to poor gaming performance due at least partially to Intel's specs, not owning this platform yet I can't do any testing myself but if you read some reviews you may get some tips to help, run Windows high performance power plan while gaming may help, bios settings to keep your CPU from downclocking may help at least in gaming in general, please come back and share your experience if you get this resolved
    xarot PC Specs
    Processori9-7980XE
    MonitorAsus PG279Q
    OS Windows 10 x64
    xarot's Avatar
    Oct 2013
    44
    198
    Quote Originally Posted by Menthol View Post
    That's what I've read and seen from performance perspective on single card too, that the performance is not very good in games in comparison to BW-E. I tried high power plan already but it didn't help. I think I tried those UEFI settings for power already but I don't recall exactly what settings I tried, most likely LLC and Cpu Current Capability. Temps are not really an issue in games.
    Are you going to try X299 out?
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    166
    2,093
    SLI performance will take a hit until NVIDIA release a fully supported driver. No different to any other launch thus far.
    ROG Guru: Brown Belt Array LiveOrDie PC Specs
    LiveOrDie PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel Core i9 10980XE 4.6Ghz 1.12v WC
    Memory (part number)G.Skill Trident Z RGB F4-3000C14D 64GB
    Graphics Card #1EVGA RTX 3080 XC3 ULTRA EK WB/BP
    MonitorLG 4k 43inch
    Storage #1Samsung 960 Pro NVME 1TB
    Storage #2Samsung 860 Evo 1TB x 3
    CPU CoolerEK-Velocity , EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
    CaseCorsair Obsidian 500D SE ATX-E Modded
    Power SupplyCooler Master V 1300W
    Keyboard Logitech G910
    Mouse Logitech G900
    Headset Razer Tiamat 2.2 v2
    OS Windows 10 x64
    Network RouterNetGear
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    SLI on pascal is a waste of time and X299 is a waste of money for hardly no gain.
  7. #7
    xarot PC Specs
    Processori9-7980XE
    MonitorAsus PG279Q
    OS Windows 10 x64
    xarot's Avatar
    Oct 2013
    44
    198
    Quote Originally Posted by Silent Scone View Post
    I really hope this is something NVIDIA can and will fix.
    Quote Originally Posted by LiveOrDie View Post
    Yeah, after Pascal release I saw SLI taking a nosedive into the ground but now it is not working well anywhere. Titan X Maxwells were pretty good in SLI.
    I still have my 6950X/RVE10 and I can always go back. Maybe I will. It's just that I live in a small country and selling these things is very frustrating.
  8. #8
    LiveOrDie PC Specs
    MonitorLG 4k 43inch
    Mouse Logitech G900
    OS Windows 10 x64
    LiveOrDie's Avatar
    Dec 2011
    41
    1,682
    Quote Originally Posted by xarot View Post
    Yeah i really wanted to move to a i9 but after seeing they don't clock well without delidding and most of them cant push past 4.8Ghz it puts me off upgrading as i wanted to for the overclocking a nice 5.2ghz overclock would of been nice lol.
  9. #9
    Menthol PC Specs
    MonitorBENQ 32" 4K
    Keyboard Corsair
    Mouse ASUS Strix
    Mouse Pad ASUS
    OS 10 X64 Pro
    Menthol's Avatar
    Jan 2012
    241
    4,548
    That may be more true than false, performance on the X299 platform will improve over time for sure, Intel's sales rely on it, sli may or may not improve by much, it depends on if it's profitable enough for Nvidia, re sellers can't keep cards in stock as is and it is so game dependent
  10. #10
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    21
    1,476
    X299 is not so bad at all. Nice single threaded performance, nice ROG motherboards will show up soon.
    Only whole picture is not so nice because Intel used thermal paste.
    But because high Turbo clock anyway no place for some huge OC.
    If someone have enough money and chance to find i7-7820X or i9-7900X on Silicon Lottery with replaced paste, they use MX-4, Gelid and Grizzly, stable on 4.8GHz example that's pure win.
    Skylake X on 4.8GHz is like Broadwell on 5.0GHz plus amazing memory results near 100.000 MB/s.
    It would be much better without thermal paste. i7-7820X have only 28 PCI-E lanes, but PCH have 24 more.
    I understand that X299 not worth for people with i7-5960X or i7-6900K, but upgrade from other models is very nice upgrade.
