Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    ROG Enthusiast Array PakRatJR's Avatar
    Apr 2014
    40
    Attempt number two...FAILED!...Now Fixed?
    New board, new cpu, 1700x and new memory, flarex 16gb. 1403 bios.
    Used this thread to start with memory setting to 3200 and cpu stock. https://rog.asus.com/forum/showthrea...ance-amp-Guide
    So far bios shows 3200. No errors so far on a few reboots into bios, except for once with a cpu overtemp after reboot from bios update?? Haven't got it since tho. Currently installing windows on 512gb m.2.
    The big difference this go around, I am leaving it set up on the bench for a few days this time instead of pulling my current setup apart. It is Wednesday. If it is still running smooth and stable when I get home from work Friday THEN I will swap it into my case.
    We'll see what happens
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    294
    7,403
    Fingers crossed. Hopefully this new board doesn't attempt a "number two."
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Apr 2014
    40
    Quote Originally Posted by xeromist View Post
    Hehe Thanks
    ROG Guru: Yellow Belt Array syldon PC Specs
    syldon PC Specs
    MotherboardAsus crosshair VII
    Processor2700X
    Memory (part number)G.Skill Trident Z 32GB DDR4 F4-4000C18Q-32GTZKW running at 3466 14-14-14-28
    Graphics Card #1MSI 1080
    Graphics Card #2MSI 1080
    Sound Cardon board
    MonitorAsus PB287Q X 2
    Storage #1480gb M2 samsung m961
    Storage #21tb 850 evo and 2tb 850 evo
    CPU Coolercorsair hydro 110i
    Casegeneric
    Power Supplytitanium 1600w platinum
    Keyboard corsair strafe
    Mouse logitech g700
    Headset logitech g930
    Mouse Pad corsair duo
    OS Windows 10 po
    Network RouterVirgin media super hub 2
    Accessory #1 https://imgur.com/KRQSu70
    syldon's Avatar
    Nov 2013
    12
    198
    Good luck with the new board.
    Apr 2014
    40
    Well, so far things seem to be working well. I already have more up time than my last try. Granted it has only been running bare windows and a screen saver since yesterday BUT I have actually been using and playing with with it for several hours today including running a few benchmarks and stress tests with no issues that I can see so far.
    I don't have my "real" video card installed yet and it will actually be on water once I put it in my case. Bumped the 1700x up to 3.8 for now, bios says 3200 on the memory but cpu-z still shows it as 2400? Altho the MHz reading shows 1600 so I am assuming that is right....dual channel an all....for 3200.
    Aura seems to be working well so far also but it is only controlling the board, but it's working.
    The only two head scratchers I have,
    1 When it boots, cold or restart, the bios logo comes up then some other screen, I think something to do with drives...it goes by too fast to actually make out what it is....then back to bios logo then into windows.
    2 I have a M.2 drive nvme 1.2 but in bios it says no nvme installed under the config for it. Not really a problem I guess as it seems to be working just fine.
    I am still going to wait till tomorrow to swap things into the case as I don't really have the time to spend tonight but so far it seems like things are good.
    Apr 2014
    40
    Well, It was nice while it lasted
    Was running great. Been running nonstop since Wednesday. Got home today, Friday, at 4pm. Got everything swapped over. Been getting my stuff installed, playing with things ect....for HOURS straight with no issues at all. NONE.
    Now, here it is 1:30 AM Friday night/Saturday morning, and I am now stuck at stock cpu and 2400 on the memory after a good 20 minutes of screwing around. Was doing my usual cleaning up of my startup entries prepping for a couple more installs.....and my keyboard and mouse went away, things froze, and I had to power off on the power supply to get things to shut down. GRRRRRR!!!!!
    After quite a few reboot attempts and bios resets and several 8 codes later and here we are. Anything over stock cpu and 2400 on the memory and it won't post. Even loading "optimized" values took a few tries.
    It's late, I'm tired and frustrated now and I am done for tonight. I am going to bed. I will leave it running overnight and I guess I will start fresh tomorrow.
  7. #7
    Apr 2014
    40
    Woke up today to a froze system.
    No keyboard, no mouse, locked up on the screen saver. Had to power off the power supply again to get it to turn off and can't even get it to post now.
    If I hit the red safeboot button or the white retry button, it goes straight to code 8. Holding the clear cmos button for 30 seconds will give me a 8 blip but then goes into looking like it will post but it wont. Never seems to stop with the same code eather. Sometimes it goes for a bit, sometimes it only 4 or 5 codes befor it stops.
  8. #8
    Apr 2014
    40
    And I'm done......again.
    After several hours of screwing around, I haven't even been able to get it post. Not once today. Between constant code 8s and general hangs and inconsistent post codes and Qleds...its coming back apart.
    Now I really don't know what to do here. I think Newegg only allows for replacement returns on the board and processor and I don't know that I really want to keep messing with this anymore.
    ETA: Best Newegg can do is refund on memory and store credit for board and processor. So basically I guess I am still out $500+ at the moment and now need to come up with something to use that on.
  9. #9
    Apr 2014
    40
    WTF!!!
    Now I am really confused and thoroughly annoyed.
    Pulled everything apart and put my old system back together. Put the crosshair back on the bench so I could play with it and HOPE to at least get back into bios to erase the M.2 drive.
    SOB BOOTED RIGHT UP!!!! like nothing ever happened. Memory currently set at DOCP standard for 3200 and working fine.
  10. #10
    syldon PC Specs
    Processor2700X
    Sound Cardon board
    Casegeneric
    Mouse logitech g700
    OS Windows 10 po
    syldon's Avatar
    Nov 2013
    12
    198
    Quote Originally Posted by PakRatJR View Post
    WTF!!!
    Running memory on DOCP at its rated speed doesn't go well on a CH6. I went for a new memory set up midweek. It took me about 2 hours to get the best settings for it. Try this.
    Boot to an OS install HWinfo. Retreive the timings for the following:
    Dram Cas# lantency
    Dram Ras# to Cas# read delay
    Dram Ras# to Cas# write delay
    Dram Ras# pre time
    Dram Ras# act time
    Trc_SM:
    TrrdS_SM:
    TrrdL_SM:
    Tfaw_ SM:
    Trfc_SM:
    Trfc2_SM:
    Trfc4_SM:
    reboot back into the Bios
    On Main extreme tweaker screen
    AI overclocker set to manual
    Bclk 100
    CPU core leave at 36 for now
    Memory frequency set memory to 2800 (since you ran at 3200 for a while this settings should be fine)
    Disable CPU boost
    Set CPU core voltage to offset mode and +
    Set cpu core offset to 0.03125 (I run on a 1800x so this may need to be 0.3750, but not higher, Try to keep your cpu below 1.42v)
    I have CPU soc voltage on Offset mode + @ 0.0500. This keeps it below 1.15v for me.
    I leave Dram on auto.
    Go into Dram timing control and add those setting that HWinfo gave
    Dram Cas# lantency
    Dram Ras# pre time
    Dram Ras# act time
    Trc_SM:
    TrrdS_SM:
    TrrdL_SM:
    Tfaw_ SM:
    Trfc_SM:
    Trfc2_SM:
    Trfc4_SM:
    It should reboot with no issues.
    Ok now to fine tune.
    In Dram timing control at the bottom add CMD2t to 1T
    Reboot. If this works then start to work the PROcODT. In Dram timing control again at the bottom.
    Asus recommends 40-96. Work from 96 ohm and work your way to 40. Reboot on each setting. Find the lowest setting and leave it there.
    Once you have this increase your CPU in increments till you are happy with the temps. Remember the hotter it is the shorter the life of the CPU. On an 1800x I find 3850 is my sweet spot. It is marginally hotter than 3600 (default). I gain 10 degrees at 3900.
    Then increase your memory in increments till you get your max .
    Good luck again. I will edit this if I missed anything.
