Fan xpert 4 not seeing EXT fan card on X299 PRIME DELUXE
Rob_Ainscough
I'm running BIOS 0402 and Qfan control works fine from BIOS and sees and sets all the fans including the external card fans.
However, when I boot into Win10 AI Suite 3 fan expert does NOT see my EXT fan card and reports the fans as NA? this is a problem because the fans will run at 100% when I boot into Win10 and AI Suite stats.
I want to use AI Suite 3 since I have a few OC profiles that I use, but I do NOT want to use fan xpert 4 since it's not working correctly (I'm fine with QFan control from the BIOS). But for some strange reason ASUS don't let me disable fan xpert from within AI Suite 3?
Other than moving to a separate fan control, any suggestions?
Cheer, Rob.
0 REPLIES 0
