Hardware or driver issue?
ChroMiuM_Deejay
Hi guys! Im confuse about a error ...
Sometimes when i turn ON my computer ,win auto restarts on boot screen...
I heard arround that error its nvidia related. but im not sure if its my videocard or just a driver issue.... the issue started some days ago
The computer was rebooted after an error check. This check was: 0x00000116 (0xffffd10f80df4010, 0xfffff80378346028, 0xffffffffc000009a, 0x0000000000000004). A memory dump was saved in: C: \ Windows \ MEMORY.DMP. Report Id: 5e7de54b-646f-4700-a551-11e27c2504ad.
And every restart i see this also, im not sure if can be related but i checked UEFI and everything looks fine...
The driver has detected a driver error in \ Device \ RaidPort1.
- System
- Provider
[ Name] stornvme
- EventID 11
[ Qualifiers] 49156
Level 2
Task 0
Keywords 0x80000000000000
EventRecordID 15818
Channel System
Security
- EventData
\Device\RaidPort1
0F00240001000000000000000B0004C001000000000000000000000000000000000000000000000001000000200004000B0004C0010000000000000000000000000000000000000000000100
Any ideas? The videocard its new, just 2 months...
FuryA
hi, ChroMiuM stornvme error looks like drive problem, You can try reinstall driver and operating system of cleaning status
or install the card to other platforms for troubleshooting 😄
ty guys! re-installed win10 again and problem solved ! lol No videocard issue at all, and about the stornvme its becuz of my ssd, win10 does not have a proper driver for patriot hellfire...and patriot dont have any too..but still works so i will just ignore it =S
