Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    ROG Guru: White Belt Array KotTHECat's Avatar
    Jan 2015
    25
    96
    M8H Q-Fan Control not working properly with 3504 BIOS
    Hello guys.
    Today i successfully flashed the 3504 BIOS and everything works well except for the Q-Fan Control.
    It does not allow me to customize my own fan curve. For example: these are the settings i used to have on 2202 BIOS (DC mode)
    But on 3504 i cant get any lower than 60% by "CPU Fan Min. Duty Cycle (%)"
    and if i set it manually to lower than 60% it says
    P.S. Sorry, but i dont know how to spoiler in these forums.
    P.P.S. I dont want to use PWM mode.
    P.P.P.S. I have 4-pin fans
    I thought "Manual" means i can go where i want to (?)
    Intel Core i7 6700K, ASUS Maximus VIII Hero, ASUS GTX 980 Strix, Kingston 2x8GB HX426C15FBK2/16, SanDisk Extreme Pro 240GB, Seagate 750GB, XFX Pro 750W, Windows 7 Ultimate
    ROG Member Array
    Apr 2017
    11
    Are the 3504 BIOS officially out yet? It was my understanding they were still in the verification process.
    Jan 2015
    25
    96
    Quote Originally Posted by Mac5555 View Post
    You are right, and i got it from here.
    ROG Guru: Orange Belt Array G75rog PC Specs
    G75rog PC Specs
    MotherboardR VI Apex
    ProcessorI9-7900X
    Memory (part number)64GB Gskill Trident Z
    Graphics Card #1AMD Radeon VII EKWB water block
    Graphics Card #2Waste of PCI lanes in NVME environment
    Sound CardStock
    MonitorLG 34" Ultra Wide3440x1440
    Storage #14ea 960 Pro 2TB, 2ea 970 Evo 2TB
    Storage #21ea 960 Pro 1 TB, 1ea 970 Pro 1TB
    CPU CoolerEKWB CPU, Swiftech Res/pump, 400mm Rad
    CaseThermaltake View 91
    Power SupplyNZXT Hale 90 1200W
    Keyboard Logitech G910
    Mouse Razer Ouroboros
    OS W10 64 1809, 1903, Ubuntu Linux
    Network RouterNetgear R9000 + 4ea R9000 AP's, 10 Gb Switch
    Accessory #1 Hyper M.2 X16 V2
    Accessory #2 10GB network via Intel 550 Nic
    Accessory #3 2 10GB Asustor NAS 7000 series
    Jan 2013
    13
    262
    Your 4 pin fan is a PWM (Pulse Width Modulation) device which allows fine grained speed control.
    DC control is limited as it requires a substantial amount of voltage to just get the fan turning.
    The bios is fine, you're just trying to make it work outside the design parameters.
    ROG Enthusiast Array KSMerg PC Specs
    KSMerg PC Specs
    MotherboardASUS ROG Maximus IX Code
    ProcessorIntel Core i7-7700k
    Memory (part number)HiperX Predator HX433C16PB3K2/16
    Graphics Card #1ROG STRIX-GTX1080-A8G-GAMING
    MonitorAsus PG278Q
    Storage #1Samsung 970 PRO
    Storage #2950 PRO/960 PRO
    CPU CoolerNoctua NH-D15S
    CaseFractal Design Define C
    Power SupplyChieftec Nitro 2 (BPS-750C2)
    Keyboard Logitech G710+
    Mouse Logitech G402
    Headset/Speakers Microlab H11
    OS W10
    Network RouterAsus RT-AS87U
    Jul 2017
    33
    Hey. Do not change the value in the CPU Fan Min. Duty Cycle. Mistakes should not be.
    Leave what happened after the calibration
    Jan 2015
    25
    96
    Guys, dont worry, i know what i am doing.
    @G75rog, i already mentioned that I DONT WANT TO USE PWM. If i am doing so, i have reasons for it, ok?
    And what do you see at first screenshot? Right, Its the curve i was able to make on 2201, but not on 3504.
    P.S. Anyway, thanks for the suggestions.
  7. #7
    Jan 2015
    25
    96
    So, i did some tests and i would say the 3504 is not yet ready (or shouldn't be) to be flashed to SPI.
    Since I do not know whether some of the devs are reading this topic, i would not mention the bugs i discovered (yet).
    P.S. Bonus (not PS):
    [spoiler=ADD SPOILER FUNCTION PLEASE]
    [/SPOILER]
    At the same moment (while in BIOS) i got a file called "MAXIMUS-VIII-HERO-ASUS-0207.CAP" on my flash drive, which is a BIOS file with unlocked Descriptor region...
  8. #8
    ROG Guru: Orange Belt Array ondersma80 PC Specs
    ondersma80 PC Specs
    MotherboardMaximus VIII Hero Alpha
    Processori7-6700K
    Memory (part number)F4-3000C15D-16GTZ
    Graphics Card #1EVGA GTX 1070 SC
    Sound CardXonar DSX
    MonitorPG278Q
    Storage #1Samsung 960 Pro
    Storage #2Assorted SSD & HDD
    CPU CoolerNH-D14
    Power SupplySilencer MK III 850W
    Keyboard G105
    Mouse G700S
    Headset/Speakers Bose Companion 5
    OS Windows 10 - I moved on from the technology of the previous decade.
    Oct 2015
    258
    Quote Originally Posted by G75rog View Post
    I have been experimenting with this bios for several days. This is the correct answer. Q-Fan stuff works perfectly as designed.
  9. #9
    Jan 2015
    25
    96
    Quote Originally Posted by ondersma80 View Post
    Then what's this?
    Try to set the latter to twenty on the new BIOS. What message do you get?
    P.S. That's the 2202 on screenshots.
  10. #10
    New ROGer Array
    May 2016
    2
    Hey, did you run the optimization before trying to adjust your fans ? You need to run that for your motherboard to figure out what values are valid.
