Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    ROG Enthusiast Array amalkumar PC Specs
    amalkumar PC Specs
    MotherboardROG CROSSHAIR VI HERO
    ProcessorRyzen 1700 3.9Ghz
    Memory (part number)CMK32GX4M2B3000C15
    Graphics Card #1GTX 1070
    MonitorAcer
    Storage #1Samsung SSD
    Storage #2Segate
    CPU CoolerHydro Series™ H115i 280mm Extreme Performance Liquid CPU Cooler
    CaseCosair 750D
    Power SupplyCosari RM 750
    Jul 2017
    42
    Lightbulb CROSSHAIR VI HERO Less Cold boot bug /Cold boot start, stop, start problem
    DRAM 2133MHZ WORKING FINE.
    DRAM OVER CLOCKING 2400MHZ/2666MHZ/2933MHZ Cold boot BUG
    HEPL ME
    ROG Enthusiast Array Big_Gray PC Specs
    Big_Gray PC Specs
    Laptop (Model)Zenpad Z580CA
    MotherboardCrosshair VII Hero
    ProcessorRyzen 2700X
    Memory (part number)CMU16GX4M2C320016R
    Graphics Card #1ROG STRIX RX VEGA56 O8G
    MonitorAcer XF270HU 144Hz IPS
    Storage #1Samsung 970 Evo
    Storage #2Samsung 960 Evo
    CPU CoolerCorsair H115i
    CaseCorsair Air 540
    Power SupplySeasonic 850W Titanium
    Keyboard Corsair K70 RGB
    Mouse Corsair M65 RGB
    Headset N/A
    Mouse Pad Corsair
    Headset/Speakers Edifier Monitors
    OS Windows10 x64
    Network RouterTP-Link VR2800
    Accessory #1 Oculus Rift VR
    Accessory #2 Synology DS216+II
    Accessory #3 Synology DS116
    Nov 2013
    11
    64
    Hey Amal,
    Does this happen only when the system has been completely powered down, psu off? When you reconnect power and press the start button the system starts up, shuts down, then restarts and boots up?
    I think this is normal when memory speed is changed from default 2133 setting. The microcode is adjusting settings to run the memory at the selected speed. I too have never experienced this behaviour before!
    Can someone confirm that this start/stop/start behaviour is normal please.
    New ROGer Array
    Jul 2017
    Quote Originally Posted by amalkumar View Post
    HEPL ME
    +1
    end when I secs another speed mainbord allways give error 24 (all bios has this problem)
    New ROGer Array Sketchy_kam PC Specs
    MotherboardROG CROSSHAIR HERO IV
    ProcessorRYZEN 1700
    Memory (part number)G.SKILL FLARE X - F4-2400C15D-16GFX
    Graphics Card #1ROG STRIX GTX 1080 O8G 11GBPS
    MonitorAOC U3277PWQU 32in 4K AMVA Pro-Line
    Storage #1Samsung 960 EVO 250GB M.2 NVMe SSD MZ-V6E250BW
    Storage #2Seagate Barracuda 2TB ST2000DM006
    CPU CoolerAMD WRAITH SPIRE - AIR
    CaseNZXT S340 ELITE MATTE BLACK
    Power SupplyCORSAIR HX750i 80+ PLATINUM
    OS WINDOWS 10 64BIT PRO
    Sketchy_kam's Avatar
    Aug 2017
    4
    Im having a similar issue, with a cold boot. PC is completely turned off, flick power switch on and hit power button. PC starts to boot, then within a couple of seconds I hear a slight click, the PC restarts and then boots normally.
    Is this something that can be adjusted in the bios? is this a normal operation?
    cheers,
    ROG Guru: Brown Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    103
    1,017
    Normal. No option I have seen in bios that will affect this.
    My Asus P5K Premium (had since 2007) will post twice, been like that always regardless of stock/OC, etc.
    My Asus Maximus VII Ranger if power is switched off on PSU prior to power up from shutdown will post twice, when power has not been switched off on PSU it will post only once. So the C6H behaves the same as my M7R Z97 Intel board.
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme Alpha - G.Skill Trident Z 3400MHz C14 QC - RX VEGA 64
    R5 3600 - Custom WC - Asus Crosshair VII Hero Wifi - G.Skill Ripjaws V 3800MHz C16 - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
    ProcessorRYZEN 1700
    Aug 2017
    4
    Quote Originally Posted by gupsterg View Post
    Legend! That's what I was hoping to hear. Thanks for taking the time to respond, very helpful and much appreciated. Cheers mate!
  7. #7
    ROG Guru: White Belt Array MrPhil17 PC Specs
    MrPhil17 PC Specs
    Laptop (Model)MacBook Pro Retina 15" Mid 2014
    MotherboardAsus Maximus IV Extreme
    ProcessorIntel Core i7 2600k
    Memory (part number)F3-14900CL9Q-16GBSR
    Graphics Card #1nVidia GeForce GTX 580
    Sound CardIntegrated
    Storage #1Samsung 850 Pro 256GB
    CPU CoolerNoctua NH-D14
    OS Windows 10 Home 64Bit
    Mar 2017
    76
    With my "old" Maximus IV Extreme i don't have this kind of issue. I use DDR3 @ 1866MHz with it (with X.M.P. profile), and it boot successfully at first time. My C6H instead need to reboot THREE times! i'm stuck in this situation since i bought it in March. This isn't normal. AMD or ASUS or both must fix this issue asap.
  8. #8
    gupsterg PC Specs
    Processori5 4690K
    MonitorAsus MG279Q
    Storage #2HGST 2TB
    gupsterg's Avatar
    Feb 2015
    103
    1,017
    Differing "Setups" can be different, perhaps state how you have system setup and what RAM, RAM MHz, etc, etc.
    i) a post prior to PSU having power differs to a post where PSU had no power.
    ii) a post from "Sleep/Resume" differs from above.
    iii) a restart also differs from post cases stated above.
    So there are at least 4 differing situations relating to how mobo will post. Perhaps state which type of post is leading to "My C6H instead need to reboot THREE times!".
    The Maximus IV Extreme may also behave the same in differing post situations. IMO the post process on Ryzen is more like a X99 system, a lot more is going on at post than "mainstream CPU" past Intel boards IMO.
  9. #9
    MrPhil17 PC Specs
    Mar 2017
    76
    If we are "talking" about cold boot bug I suppose it's a boot from powered off psu/power stripe.
  10. #10
    ProcessorRYZEN 1700
    Aug 2017
    4
    So looking at my current scenario, and based on the above discussion my system does the following:
    Cold Start (PSU off at back of system and power off at wall switch)
    • Switch at wall on
    • Switch at PSU on
    • PC power button depressed
    • PC boots, after 3 sec reboots and boots to windows
    Non Cold start
    • PC is shutdown
    • Switch on PSU on
    • PC boots directly to windows
