Results 1 to 6 of 6
    ROG Enthusiast Array
    Jul 2017
    28
    How to enable XFR mode of Ryzen?
    When my 1700X CPU is under load, I see that it's not working with 3.8 Ghz as it was needed to be with XFR. I did not overclock CPU. I just changed my RAM's to 3200mhz.
    Do you guys can use XFR? If yes, how?
    ROG Guru: Brown Belt Array gupsterg PC Specs
    gupsterg PC Specs
    MotherboardAsus Maximus VII Ranger
    Processori5 4690K
    Memory (part number)HyperX Savage 2400MHz 16GB
    Graphics Card #1Sapphire R9 Fury X (1145/545 Custom ROM)
    MonitorAsus MG279Q
    Storage #1Samsung 840 Evo 250GB
    Storage #2HGST 2TB
    CPU CoolerThermalRight Archon SB-E X2
    CaseSilverstone Temjin 06
    Power SupplyCooler Master V850
    Headset/Speakers HyperX Cloud
    OS Win 7 Pro x64 / Win 10 Pro x64
    gupsterg's Avatar
    Feb 2015
    103
    1,017
    Quote Originally Posted by chonk View Post
    For the 1700X SKU the clock configuration is following:
    - 3.4GHz all core frequency (MACF)
    - 3.5GHz maximum all core XFR ceiling (ACXFRC)
    - 3.8GHz single core frequency (MSCF)
    - 3.9GHz maximum single core XFR ceiling (SCXFRC)
    You will only see 3.8GHz when a single core is loaded. If you are at UEFI defaults then Precision Boost/XFR will be active. RAM clock change to 3200MHz will not cause PB/XFR not to function.
    Intel Defector AMD Rebel
    TR 1950X - Custom WC - Asus Zenith Extreme Alpha - G.Skill Trident Z 3400MHz C14 QC - RX VEGA 64
    R5 3600 - Custom WC - Asus Crosshair VII Hero Wifi - G.Skill Ripjaws V 3800MHz C16 - Sapphire HD 5850 Toxic
    24/7 OC: i5 4690K @ 4.9GHz CPU@1.255v 4.4GHz Cache@1.10v - Archon SB-E X2 - Asus Maximus VII Ranger
    Sapphire Fury X (1145/545 ~17.7K GS 3DM FS)
    ROG Guru: Brown Belt Array MeanMachine PC Specs
    Laptop (Model)I enjoy my wife
    MotherboardCVI HERO + CVII Hero Wifi
    ProcessorRyzen 7 1800X + 2700X
    Memory (part number)CMD16GX4M2B3000C15 + F4-3200C14D-16GTZR
    Graphics Card #1EVGA GTX980 SC for CVFZ
    Graphics Card #2EVGA GTX 1080 hybrid
    Graphics Card #3GTX 770 for phys x
    Sound CardMB
    MonitorHP w2408h
    Storage #1Samsung 970 EVO 500GB M.2
    Storage #2Samsung 840EVO 500GB and 960 M.2 pro
    CPU CoolerCorsair H105, H110 and H115i
    CaseCorsair 750D and 780T
    Power SupplyCorsair AX-1200i and Antec 850 pro platinum
    Keyboard Logitech K800
    Mouse Razer Mamba
    Headset Corsair Vengeance 2100
    OS W7 Ultimate 64bit and W10 pro 64bit
    Network RouterNetcom Wireless NF18ACV
    MeanMachine's Avatar
    Apr 2014
    126
    1,686
    So far, I have found XFR (Extended Frequency Range) Boost only works in Automated OC mode and also the frequency gain is limited.
    XFR will boost clock frequencies above the turbo frequency range and is also based on the capabilities of the CPU cooler. Just 200MHz on the Ryzen 5 1300X and 1500X. Down to 50MHz on Ryzen 5 1400 and Ryzen 3 1200.
    I am on the 1800X with just 100MHz boost (if Auto mode selected) and same on the 1700X.
    Best performance gains I have got are in manual mode and tuned to my best RAM frequency.
    There are a number of ways to OC in Bios and XFR is not the best way to achieve your MAX OC.
    We owe our existence to the scum of the earth, Cyanobacteria
    My System Specs:
    MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
    CPU:
    AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
    Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
    ROG Guru: Yellow Belt Array unknownmiscreant PC Specs
    Laptop (Model)Dell E430s (i7)
    MotherboardCrosshair VI Hero
    ProcessorRyzen 7 1700X
    Memory (part number)F4-3200C14D-16GFX (Currently clocked 3466MHz)
    Graphics Card #1EVGA GTX1070 FTW
    Sound CardAsus Strix Soar
    Monitor2x Dell U2412M
    Storage #1Intel 540s
    Storage #2Intel 520
    CPU CoolerEK Supremacy Evo
    CaseCorsair 460x
    Power SupplyEVGA 850 G2
    Keyboard Logitech G610 Cherry MX Brown
    Mouse Logitech G502
    Mouse Pad Logitech G640
    Headset/Speakers Custom built sound system
    OS Win 10
    Network RouterNetgear Nighthawk
    Jul 2017
    180
    I had everything enabled right on a 1700x but couldn't get it going past 3.45GHz cooled by custom water loop (40deg load temps). I got tired of that and OCed it to 4.025GHz.
    gupsterg PC Specs
    Processori5 4690K
    MonitorAsus MG279Q
    Storage #2HGST 2TB
    gupsterg's Avatar
    Feb 2015
    103
    1,017
    Quote Originally Posted by MeanMachine View Post
    That is strange. I have never used "Automated OC mode". But the fundamental rule of CPU going to "OC mode" by change of multipler/PState 0 FID would mean PB/XFR would be disabled.
    You see when the CPU ratio is placed out of default value for PState 0 PB/XFR is disabled automatically.
    It does not matter if a PState OC is done or multiplier.
    So:-
    i) R7 1700 = 30.25 (default PState 0 30)
    ii) 1700X = 34.25 (default PState 0 34)
    iii) 1800X = 36.25 (default PState 0 36)
    Will = OC mode = no PB/XFR.
    If a PState 0 OC is used I have observed single/multiple cores boosting up and down, but that is not PB/XFR IMO, it's just how a PState OC is.
    ROG Guru: Yellow Belt Array Clouseau PC Specs
    Clouseau PC Specs
    MotherboardROG STRIX X470-F GAMING
    Processor3800X @ PE lvl3
    Memory (part number)F4-3600C16D-16GTZ @ 3600
    Graphics Card #1ROG STRIX OC GTX 1080
    MonitorSamsung C27HG70
    Storage #1Samsung 960 EVO
    Storage #2Samsung 850 EVO
    CPU CoolerNoctua NH-D15 SE-AM4
    CaseThermaltake Core X9
    Power SupplySeasonic Prime SSR-1200PD
    OS Windows 10 Pro RS4(1903)
    Clouseau's Avatar
    Jun 2017
    146
    Also keep in mind that if anything in the CBS section is altered from Auto, OC mode is automatically engaged; nullifying XFR.
