[Guide] How to see fan speeds on gl502, gl702 and others+ Adding Heatsink on GL502VMK
Nevortic
Hi guys, I found the way to see the speeds of both fans with our dear gaming center!
Here is the link to the video guide!
https://www.youtube.com/watch?v=zaB10DNWBts
13 REPLIES 13
Nevortic
I also made a change on the gl502vmk which reduced the heat by 5 degrees.
https://www.youtube.com/watch?v=LSdZOMAddDs&t=1s
Oooh this is interesting!! Did you stress test it with a high demanding game? The laptop usually goes over 90°C at certain games without a cooling pad. If this little heatsink helps during gaming I'll buy it instantly.
After adding that dissipator I noticed that the video card has dropped 4 degrees with strong stress on it. I'm making a heatsink so I can cool all that part under the cpu and gpu where there is no heatsink.
Is the chip you added that little heatsink to part of the graphics chipset? what exactly is its function?
StarJack
In very few words....
Is a support chip that manages the data the gpu has to handle.
By testing, I noticed that the chip was very hot.
So I decided to put on a heatsink and see the effects.
It's a passive heat sink so it does not do miracles.
I'd say 5 degrees off the GPU under load is pretty close to a miracle for the effort involved in that mod.
Sent from my SM-G925W8 using Tapatalk
Now, with undervolt on cpu and gpu after 4 hours playing rainbow six all ultra MAX CPU: 75 ° MAX GPU: 69 °
Do you play with turbo boost?
How much did you undervolt the CPU?
I set 99% of the cpu on the control panel.
If you want to get the most out of it, I recommend 99% + undervolt -100mV CPU.
