08-01-2017 01:49 PM - last edited on 03-05-2024 10:08 PM by ROGBot
08-01-2017 01:56 PM
ufotheswe wrote:
So like 5 months ago my ROG didnt want to charge to 100% anymore. I didnt like it but never used it without the AC, so I didnt think much of it. So I went away for a week so i disconnected the AC - when I came back the battery was dead. It says "0% avaliable (plugged in, charging). Its not really a big deal since I always use it with the AC, but recently when I am gaming the laptop just turns off. I can turn it on right away - so it seems it loses power for half a second or something, which is enough to turn it off.
Anybody managed to fix this without opening the f'ing thing and replacing it with a 100 euro battery?
Thanks
08-01-2017 02:23 PM
Eleiyas wrote:
The only thing I can recommend is this:
- Power off unit
- hard reset (push power button for 1 minute)
- power off unit
- plug in
- charge for 10-12 hours (do not turn it on in this period)
see if that works 🙂
08-01-2017 02:24 PM
- Power off unit
- power off unit
- plug in
see if that works 🙂
08-01-2017 02:43 PM
ufotheswe wrote:
Thanks alot for the reply. Just to be sure I am doing it right. After I do the hard reset, the laptop will turn itself on? And then I turn it off immediately and leave it off for 12 hours? I'll have to leave the AC plugged in during all these steps, right? Because my ROG doesnt work unless I have the AC plugged in. But since you said "plug in" I got a little confused.
Thanks again
08-02-2017 03:34 AM
Eleiyas wrote:
It might turn on, but it shouldn't.
Don't plug it in until all other steps have been done. Then when you do plug it in, don't turn it on or use it for 10-12 hours.
08-01-2017 10:02 PM
08-02-2017 03:54 AM
JustinThyme wrote:
The G751s have had a bad run with batteries failing prematurely. Sounds like you have the same problem as in battery is toast.
Batteries serve more of a purpose other than running with no AC. They provide extra current during high demand usage like heavy gaming and also carry you through brownouts.
08-02-2017 12:38 AM
