Results 1 to 8 of 8
    New ROGer Array
    Jul 2017
    4
    Collers problem - G752VT
    Hello people
    My fan is working anytime on ~1800 rpm. No app allow me to change or set speed of fan.
    A little prehistory. Once upon a time I installed and launched FL Studio 12 (x64). Fan begin work very noisy even when I exit the app and reboot. Speedfan showed 4200 rpm.
    So, I decided to do something: I deleted old VGA drivers, updated BIOS and then installed Nvidia Experience and installed recommended drivers from Nvidia Exprience app.
    And after that past few weeks the issue stays next: without any load (windows or Bios is running) fan is working at ~1800 rpm what is quite noisy, during gameplay it can raise up to 3600-3800 rpm.
    What should I do? Installing of old (original for this laptop) VGA drivers didn't help. Ohh, yeah, and is that normal that during gaming temperatures of CPU can reach 92C - does It mean that thermal grease should be changed?
    ASUS HQ Service Rep Array Bill@ASUS's Avatar
    Dec 2015
    433
    Hello TroublesMader
    May I ask that did the fan work normally before you installed FL Studio 12?
    New ROGer Array
    Jul 2017
    4
    Bill@ASUS, it was working slowly and quiet even during high load, I mean, probably less then 1000 rpm, I just didn't had Speedan then.
    I have windows 10 x64 Home
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,121
    You fan speed is controlled by your Motherboard BIOS, True These gaming notebooks run warm under full load. Fans stay quite Mine will run from 1900 to 4200 RPM I can barley hear it at 4200 I consider this a plus.
    There is a fan control program that many are using NBFC I think is the name of it. Just search these forums there has been discussions on it over the last couple of years since the G752 came out. I don't game but running benchmarks "Test In" particularly 100% load load my CPU Temp tops out at 76c with fans running 4200 RPM fairly quite. Running furMark I get the same GPU and CPU running in low 70's
    Sounds to me like your issues started with installing FL Studio, you may have to use an earlier Image of your SSD that you created and saved for times like this. So set your notebook back to a time before it got screwed up.
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    ex-ASUS Employee Array Eleiyas PC Specs
    Eleiyas PC Specs
    MotherboardASUS 970 PRO GAMING/AURA
    ProcessorAMD FX 8370
    Memory (part number)Corsair 8GB XMS3 PC3-12800 1600MHz DDR3
    Graphics Card #1XFX AMD Radeon HD 6950 - 2G
    MonitorLG Flatron E2240T 21.5'' 1080p Monitor
    Storage #1Samsung 1TB 7200RPM 32MB
    Storage #2Seagate Barracuda 2TB 7200RPM 64MB 6GB/s
    CPU CoolerAMD Wraith Cooler
    CaseNZXT Lexa S
    Power SupplyCorsair CX600 600W (Bronze)
    Keyboard Logitech Wireless AZERTY
    Mouse Microsoft Wireless
    Headset Evil Witchcraft II Gaming Headset (Black/Red)
    Mouse Pad Wild Wolf Hunter
    Headset/Speakers 4Gamers 2.1 Sound-System
    OS Windows 10 Professional - Creator's
    Network RouterZiggo
    Mar 2017
    25
    378
    I have FL Studio 12 and it only causes my fans to ramp up when using high-usage VST plugins or a lot of samples (HDD usage).
    I am on a custom desktop though, so things differ slightly.
    I have seen a lot of units with a bugged fan running at max RPM: 99% of the time I managed to fix the issue by simply resetting the BIOS to default.
    P.S: Collab bro? x)
    New ROGer Array
    Jul 2017
    4
    Quote Originally Posted by Clintlgm View Post
    Yeah, It helped, I just made full restore to factory settings. Now fan works automatically depending on load.
    I'll also check that app that you counceled. Thank you
    Eleiyas, worked without bios resetting, but next time if I'll have such problem I'll try your way - It's easier (cause now I need to install some apps and games that was delated during reset).
    P.S. yeap, Collab
  7. #7
    ROG Enthusiast Array
    May 2016
    42
    @TroublesMader
    I don't know about the fans, but I had CPU temps of 99C sometimes. I decided to disassemble my laptop (losing the warranty I had left of about 7 months, but I trust myself more than the guys at the repair points here in Romania) and repaste. I was very happy at first, the temps were way better in FireStrike (benchmark) but after playing Player Unknown's Battlegrounds, I found out my CPU and GPU would thermal throttle at <85C. I probably didn't do a good job covering the VRM's, I only used 0.5mm pads on them and I think they needed thicker ones. I just ordered 1.0 and 1.5mm ones and will do another repaste today, hoping for the best. So be careful about how you repaste if you decide to do it, the space between heatsink and VRMs is quite big.
  8. #8
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,121
    If you set up and maintain disk/ssd images you'll never have to reinstall your software again. unlike resetting to factory condition and using up a couple of hours or more of your time, You can just restore an image of your hard drive/SSD takes about 15 minutes of so and when complete you are right back exactly were you were when you created that Image. I personally keep full images and incremental to these images. I can roll back a day or 3 days or a week or a month or evern 6 months if nessary and only have to reinstall anything that was installed after the Image was created. I also use Macrium Reflect to do this. There are other Imaging/backup software out there use one and you'll be happy you did when these issue come up. I always run a Incremental or full image before any major windows updates or installing any software program. If something goes wrong your like 15 minutes to being fully recovered and running again.
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
Tags for this Thread
