Results 1 to 8 of 8
    ROG Member Array
    Jul 2017
    5
    [SOLVED] Strange G752VM battery charge drop when laptop is shut down
    I have very strange issue with my G752VM ROG.
    I left my laptop fully charged (to 100%) for a few days turned off (anticipating any further questions - yes, laptop was turned off, I know the difference between shut down, sleep and hibernate), and when I started it again, it had 90% instead 100%.
    I left it again for 2 full days and from 100% it went down to 95%.
    Laptop is brand new, bought 3 months ago, although probably manufactured last year.
    I found some posts, that this might be related to Win10 but I tried lots of proposed solutions (turning off fast boot in BIOS and Windows), I did recent BIOS upgrade to 306, nothing helps, battery is still dropping. However I din't try to reinstall Win (yet).
    Can this be related to OS or Should I send it to service for battery repair?
    Thanks in advance
    M.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    309
    7,674
    I don't think this is unusual. I have a lenovo laptop that also loses charge over time. Maybe another 752 owner can chime in as to how much charge they normally lose.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    105
    4,149
    Have you disabled Hybrid shutdown in your power options/ advanced settings, some loss is normal, I don't know how much since I never use my G752VY on battery the only time is when we have a power outage then I shut it down and unplug it to protect the power supply from taking a hit from the power surges as the power restores
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    ROG Enthusiast Array
    May 2016
    42
    It may be the fact that usb's are always powered even when shut down. But I'm not 100% sure on that.
    ROG Guru: Brown Belt Array Darnassus PC Specs
    Darnassus PC Specs
    Laptop (Model)G752VS -=-=- G750JX
    MotherboardASUSTeK COMPUTER INC. G752VS (U3E1) -=-=- ASUSTeK COMPUTER INC. G750JX (SOCKET 0)
    Processori7 6700HQ @ 2.60GHz -=-=- i7-4700HQ CPU @ 2.40GHz - 3.40GHz
    Memory (part number)2x16gb (M471A2K43BB1-CRC) -=-=- 2x8gb (HMT41GS6AFR8A-PB)
    Graphics Card #1GTX 1070 (8GB) -=-=- GTX 770M (3GB)
    Sound CardRealtek High Definition Audio / NVIDIA High Definition Audio
    MonitorGSync IPS 75HZ -=-=- Chi Mei 60Hz (Overclocked to 85Hz)
    Storage #1Samsung SSD 960 EVO 250GB x2 -=-=- LITEONIT LCS-256M6S
    Storage #2HGST HTS721010A9E630 -=-=- ST1000LM024 HN-M101MBB
    CPU CoolerStock -=-=- Stock
    CaseStock -=-=- Stock
    Power SupplyStock -=-=- Stock
    Keyboard Stock -=-=- Stock
    Mouse Razer Naga Epic 1st Generation
    Headset SPH 2500
    Mouse Pad Razer Goliathus
    OS Winblows 10 Pro -=-=- Winblows 8.1 Pro
    Network RouterCG3000v2
    Darnassus's Avatar
    Dec 2013
    61
    1,651
    Battery is always connected since it's integrated.
    Batteries, no matter what battery, will lose charge overtime, especially if it is in a cold environment.
    You may have Power 2 USB installed, which can remain active on your shut down laptop, essentially turning your G752 into a glorified power bank.
    Your date of manufacture might be longer than your purchase date.
    I suggest you let it go down to 20% then shut down, and charge it to 100% with the lappy OFF.
    Gosh Blue Lady.. ❤
    JOIN THE ASUS T-SHOOT DISCORD <-- Clicky!
    ROG Member Array
    Jul 2017
    5
    Hi guys,
    thank you for all your valuable hints. The problem looks to be sloved.
    TL;DR - I installed and then uninstalled USB Charger Plus software.
    Longer story:
    Originally, my rog didn't came with pre-installed windows, however I after 2 days I needed to send it to service on warranty, since DVD stopped opening. And it came back with installed Win10 Home by Asus. However, in the meantime, I bought m2 SSD and installed my private Win10 on that drive, formatting the disk with Asus-installed Win. As it was pure Win10, I was installing drivers and software directly from website, choosing which one to have. USB Charger seemed usless for me, so i skipped it. But probably it was installed previously on the windows-by-asus image, so it added some settings to bios to power-up usb when off and on battery. At first, when I discovered the loosing power issue, USB Charger was my first hint, but since I didn't have it installed, I moved on searching for other resons.
    Unfortunatelly, I didn't check before installing sofware if my rog would power some device when on battery and shutdown...
    Perhaps if someone will have similar issue or is willing to format his laptop, could check it and confirm, that even though you don't have USB Charger Installed now, previous installation "forcly" removed from laptop messes something.
    Again, thanks for your help, I'm marking topic as [SOLVED].
  7. #7
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    105
    4,149
    Yes you also have to turn off charger Plus in the Bios also.
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
  8. #8
    ROG Member Array
    Jul 2017
    5
    in BIOS? I don't see that option in my BIOS...
Tags for this Thread
