Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 44
  1. #21
    ROG Enthusiast Array
    Feb 2012
    25
    After mounting a fan cooling "The Super I/O ITE IT8665E" chip ( located under the back plastic cover, in line with the battery cell ), I have had no more minus-temperatures nor speeding fans. I have run with all of the suspected apps for two weeks and had no problems for a month. :-)
  2. #22
    ROG Guru: Orange Belt Array AQUASTEVAE PC Specs
    AQUASTEVAE PC Specs
    MotherboardROG Crosshair VI EXTREME
    ProcessorRyzen 7 1700
    Memory (part number)32gb GSkill FlareX 3200mhzC14
    Graphics Card #1GIGABYTE 1080 ti EXTREME
    Monitor55" UHDR 4K TV
    Storage #1SAMSUNG 960 EVO M.2 NVME 500GB
    Storage #2SAMSUNG 951 M.2 PCIe AHCI 512GB
    CPU CoolerNZXT kRAKEN X62
    CaseCOOLERMASTER MAKER 5T
    Power SupplyCORSAIR RM850X
    Keyboard LOGITECH K850 WIRELESS BACKLIT
    Mouse LOGITECH M570 TRACKBALL WIRELESS
    Headset 2.4GHz Wireless Headphones with Detachable Mic and Rechargeable Battery
    Mouse Pad LOLOLOLOLOLOL....
    Headset/Speakers VIZIO SOUND BAR, SUBWOOFER AND SURROUND SPEAKERS
    OS WIN 10 PRO
    AQUASTEVAE's Avatar
    Nov 2011
    11
    374
    Quote Originally Posted by marblesrx7 View Post
    Just wanted to start a thread and see how many other people are having this same issue. Basically the conditions are as follows:
    Just using the PC as normal and the I hear all the Case Fans Max out! If i check any monitoring software it states that the motherboard temp sensor is reading -109C. Also all other temps(CPU, CPU DIODE, CHIPSET, and VRM) stop responding to change in CPU load. A quick restart fixes the problem but it is very annoying. It happens on a daily basis. I have not figured out what is causing this.
    I have seen similar posts on the forum but have yet to see a solution.Figured if we could compile everyone that is having this problem on a single thread it would help and maybe @ASUS has something in the works for this.
    This is a common problem of the "x" chips. Probably has nothing to do with the mobo. There is tons of info on this problem from the "x" Ryzen chips if you google.
    CoolerMaster Maker 5T - ASUS CROSSHAIR VI EXTREME - 55-inch UHD 4k Display - AMD Ryzen 7 1700 - NZXT Kraken X62 - 7 CoolerMaster/NZXT RGB Case Fans W/ HUE+ - Gigabyte AORUS 1080 TI EXTREME - 32GB GSkill FlareX 3200Mhz DDR4 - Samsung 960 EVO M.2 NVMe 500GB - Samsung 951 M.2 AHCI 512GB - Samsung EVO 840 1TB SSD - Crucial MX100 SATA 3 500GB SSD - WD BLUE 8TB HDD - Logitech K350 wireless wave keyboard - Logitech M570 wireless trackball - Dual booting WIN 10 Pro Fall Creators Edition
  3. #23
    ROG Member Array
    Feb 2014
    15
    Quote Originally Posted by AQUASTEVAE View Post
    that's a myth. its the mobo. other boards work fine with x series chips. buddy has a 1600x build on a msi b350 board and has 0 issues with temps or oc.
    my board (this one) and 1800x have been RMA'd already once with occasional reoccurring temp errors. I get BSOD in games regularly from overheat and it wont let me restart until it sets for a while and cools down. I am at stock speeds on an h100i... every bios update to date has not solved the temp spikes problem.
    just checked today and saw my 1800x at stock speeds idleing go from 50C to 68C back and forth in corsair link software. cycling the fans up and down.
    the issues with this board are incredable
  4. #24
    ROG Guru: Yellow Belt Array andyliu PC Specs
    andyliu PC Specs
    MotherboardCrosshair VI Hero
    ProcessorAMD Ryzen 7 1700X
    Memory (part number)(32GB) 2*F4-3200C14D-16GFX
    Graphics Card #1EVGA 980 FTW
    Storage #1Samsung Evo 850 500GB
    Storage #2Mushkin Enhanced ECO3 480GB
    CPU CoolerCorsair H105
    CaseMastercase Maker 5
    Power SupplyThermaltake TOUGHPOWER 750W
    Keyboard Logitech G910
    Mouse Logitech G502
    OS Windows 10 Pro
    Network RouterASUS RT-AC3100 + PCE-AC88
    Accessory #1 1701(3.9 1.352v_llc3_3200) https://pastebin.com/PzEezvHU
    Accessory #2 bios 1501 (3.9Ghz, 1.352v) setting: https://pastebin.com/fDLrXHLM
    Apr 2017
    14
    139
    Quote Originally Posted by vogner16 View Post
    I dont know how accurate the temp reading is. if it's 50c with ryzen master @ stock, I think you wanna check few thing first.
    idle with 50c @ stock sounds more like AIO/CPU issue than motherboard issue. (my corsair h105 keep my 3.9 O.C 1700x at 63c after an hour realbench)
    I dont have experience with corsair link software (not available with my h105 ;p), but I would assume it's capable checking pump status.
    it sounds like the pump isn't moving water and it gradually overheat.
    if the pump is running and moving water, well gotta make sure the cooler is making proper contact with CPU.
    I will quote from the article http://www.tomshardware.com/news/amd...lem,33771.html
    We’ve discovered that the backplates provided with some major motherboard brands could come with a screw that is too long. The screws reach their safety stop too soon, leaving the spring with too much headroom, and then the pressure of the sink on the CPU is inadequate.
    Since there are 2 different version of h100i and I dont know which one you use, here is the link for am4 retention bracket.
    go check if you need it.
    http://www.corsair.com/en-us/am4-amd...series-coolers
    Promo code: CORSAIRAM4BR
    I assume it's still free to obtain, if not, try to contact corsair.
    But ya, I actually waited till I received my bracket before I build my system with c6h, and I dont really have issue with the overheating like some other ppl experiencing with corsair AIO. Hopefully you can solve your problem with either suggestion. GL
  5. #25
    ROG Member Array Sunwalker1337 PC Specs
    MotherboardAsus Crosshair VI Hero
    ProcessorAMD Ryzen 1800x
    Memory (part number)16GB Corsair Vengeance LPX 3200
    Graphics Card #1MSI Sea Hawk GTX 1080
    MonitorACER KG271A
    Storage #1Samsung 960 EVO 250 GB
    Storage #2Samsung 840 EVO 120 GB
    CPU CoolerAlphacool XP³
    CaseThermaltake Level GT 10 Battle Edition
    Power SupplyEnermax Revolution 87+ 850W
    Keyboard Logitech G910 Orion Spectrum
    Mouse Razer Death Adder Elite
    Headset Corsair VOID Pro + Rode NT1-A
    Mouse Pad Corsair MM300
    Headset/Speakers Logitech 2.1
    OS Windows 10 Pro x64
    Network RouterFritz Box 7590
    Mar 2018
    9
    Here!
    It seems, i have a very similiar problem too.
  6. #26
    ROG Enthusiast Array Lightbringer PC Specs
    MotherboardAsus Prime X370-PRO
    ProcessorAMD Ryzen 7 1700x
    Memory (part number)GSkill Trident Z RBG F4-3200C14D-16GTZR
    Graphics Card #1Asus ROG Strix GeForce GTX1080TI-O11G
    Sound CardCreative Soundblaster Z
    MonitorAsus ROG PG279Q 68,6 cm
    Storage #1Samsung 960 EVO MZ-V6E500BW Internal Solid State Drive (500GB)
    Storage #2Crucial MX300 2TB SATA 2.5 Inch Solid State Drive - CT2050MX300SSD1
    CPU CoolerNoctua NH-D15 SE-AM
    CaseFractal Design Define r5
    Power SupplySeasonic SS-650KM3 X650 80 Plus Gold
    Keyboard Asus ROG Claymore
    Mouse Asus ROG Gladius 2
    Headset Beyerdynamic DT-990 Pro / ModMic
    Mouse Pad Razer Goliathus Gaming Mouse Mat- Small (Speed Edition)
    Headset/Speakers Logitech Z506 5.1
    OS Windows 10 Home Edition
    Network RouterAsus RT-AC68U AC1900 Black Diamond Dual-Band WLAN Router
    Accessory #1 Asus PCE-AC68 PCIe WLAN Card
    Jun 2017
    60
    Hi guys,
    see my post here.
    looks like i'm experiencing the exact same thing. As long as i ONLY use MSI afterburner for temp readings, nothing happens. As sson as i use ANY OTHER software to read my sensors, everything gets screwed up randomly.
  7. #27
    ROG Member Array KEyBAD PC Specs
    KEyBAD PC Specs
    MotherboardCROSSHAIR HERO VI
    ProcessorRyzen R7 2700x
    Memory (part number)F4-3200C16D-16GVKB
    Graphics Card #1R9 290
    Sound CardCreative SoundBlaster Katana
    MonitorSamsung S27A950D
    Storage #1Corsair Force 3 SSD
    Storage #2Western Digital WD10EZEX
    CPU CoolerNoctua NH-D15 SE-AM4
    CaseCooler Master Cosmos 2
    Power SupplySea Sonic X-650
    Headset/Speakers Sennheiser G4ME ONE
    OS Windows 10 Pro
    Network RouterAsus RT-N56U
    Apr 2017
    20
    I have same problem. on Ryzen 1700, from BIOS 3008 to 6001. IO Skew auto or disabled (tried both). Idle 50 C @ stock on BOX Wraith cooler.
    Sometimes fan maxed out to 100% until reboot.
    Sometimes fan keeps 1000 rpm even after 70+ С until reboot.
    Sometimes on idle vcore go to 1.4v and temps to 63+ C, and fast back to ~50 C.
    Sometimes SoC voltages goes up to 1.4v constant until reboot.
    Sometimes all ok until reboot.
    * Reboot = manual rebooting.
    Monitoring with AIDA64 and Ryzen Master.
    After AiSuite 3 / DIPS 5 and their rpm control i can fix that, but have BSODs.
    Strange voltages reading (0.8v where must be 1.8v) and "below zero" temps occures.
    So i uninstalled ASUS software, buggy non-functional whistles and bells no more.
    Restart & wait & get over it - it is my way.
  8. #28
    MonitorACER KG271A
    Mar 2018
    9
    Today i get my new Crosshair 6 ... After 6 hrs running the CPU Temps Stucked and one of my Fans runs @ 100% ... Its Time for an Gigabyte Board!
    Well, i think, after 14 Years of ASUS, its Time to Change.
    An 231€ (285 USD) MoBo should work much Better!
  9. #29
    ROG Enthusiast Array aaraujo PC Specs
    aaraujo PC Specs
    MotherboardASUS ROG STRIX X470-I GAMING
    ProcessorAMD Ryzen 7 2700X
    Memory (part number)G.SKILL F4-4400C19D-16GTZSW
    Graphics Card #1PALIT GeForce GTX 1050 Ti KalmX
    Storage #1Samsung SSD 970 Pro 512GB
    CPU CoolerNoctua NH-D14
    CaseLian Li PC-Q33
    Power SupplySeasonic SSR-600TL
    Keyboard Logitech K310
    Mouse Logitech M105
    Mouse Pad ASUS ROG Whetstone
    OS Microsoft Windows 10 64bit
    Dec 2015
    39
    I acquired an ASUS X470-I motherboard along an AMD Ryzen 2700X CPU late May 2018. I have had similar issues as the ones reported here. I have read the whole thread, and followed some of the suggestions but without success. In my case using an additional fan blowing at the Super I/O ITE IT8665E chip is very difficult. So I got one of those raspberry pi small heatsinks, measuring 14 mm by 14 mm with 7 mm height, which is about the size of the Super I/O ITE IT8665E chip. I applied the heatsink over the Super I/O ITE IT8665E chip using Thermal Grizzly minus pad 8. Unfortunately this did not work! Running AIDA64 system stability test failed after a few minutes due to the fans being stuck on low rotations. Then I remembered the hypothetical cause suggested above in this thread. Since the cause of the issues is related to the chip being frequently stressed, then if the chip controls the fans less often, maybe the issues can be minimized, I thought. This would need to be implemented in the firmware by the programmers. Until I found the following settings in the BIOS:
    CPU Fan Smoothing Up/Down Time
    Chassis Fan Smoothing Up/Down Time
    These settings both were at 0 sec by default. So I increased to the next available option, which is 2.6 sec.
    After increasing these settings I was able to run AIDA64 stress test for at least an hour, until I decided to stop it. I have been running HWiNFO64 in the background while working on this computer for many hours, without any issues with the fans.
    Only once the Chassis fan got stuck on a high rpm setting. This was when I opened AIDA64, while HWiNFO64 was already running.
    So I suggest those observing these issues, try these settings in the BIOS.
  10. #30
    aaraujo PC Specs
    CaseLian Li PC-Q33
    Mouse Logitech M105
    Dec 2015
    39
    I think I spoke too soon. The CPU FAN just got stuck on the maximum speed a moment ago! Maybe it is not the "CPU Fan Smoothing Up/Down Time" setting! I had lowered the SOC voltage to 1.1V. If I leave it as "Auto" it defaults to 1.15V. Maybe it is this! Before I had SOC voltage at 1.15V. I will try 1.15V SOC again and stress test. I do not no if this makes sense. Maybe a lower voltage could lead to memory errors in turn leading to a defective fan control. I do not know if this control algorithm is processed by the CPU and system memory though.
