Zenith Extreme Beta UEFI 0901
Raja
From Elmor:
Beta BIOS 0901 http://www.mediafire.com/file/8tp9l0...-ASUS-0901.zip
Have not tested this extensively, let me know how it works for you.
- AGESA 1.0.0.4
- Fan fixes from 0012
- UEFI RAID driver updated (and hopefully back on track)
Beta BIOS 0804 https://www.mediafire.com/file/hurdeb58o4mtjq2/ROG-ZENITH-EXTREME-ASUS-0804.zip
* AGESA 1.0.0.3
* Hynix 2DPC patch (POST issues with all slots populated)
* Fan control fixes, including EXT_FAN card
* PCIEX8/X4_4 lane switching tested and works fine, however, I haven't verified the issue on older BIOS
Please note, some boards have older firmware for the onboard OLED/Aura, which can cause some strange issues. Update to the version here. Run the .exe from within Windows.
After applying the update above, you can apply the version here
UEFI build
0801
NOTICE: If you already have a SATA RAID configuration, make a backup of the array before updating to this build, then rebuild it once you have flashed the BIOS.
For more details and instructions regarding the BIOS/RAID driver, please refer to the following
link
Revised memory rules
Fixed CPU temp reporting issue after CMOS clear
Secure Erase string update
UEFI build 0603
Includes Ai suite patch, RAID driver update, and a patch for Inateck 7-port KTU3FR-5O2U to solve POST issues.
UEFI build 9960 based on 0601:
Automatically applies a 2T Command Rate for 2DPC configs when above DDR4-2820.
UEFI build 0601
public release build.
This will be on the support pages soon. Same as the 9910 beta. Please clear CMOS after updating (allow the update to complete fully before doing so!).
For those of you still experiencing memory instability, try setting a 2T Command Rate.
Older beta UEFI:
UEFI beta build 9910
More memory tuning for dual rank configs
UEFI beta build 9906
More DRAM tuning for compatibility/oc
Added CLDO VDDP Voltage under Tweaker's Paradise
Also synchronized hwm CPU temp with monitor
UEFI build 9980
Improves memory overclocking - again.
UEFI build 9964
Improves memory overclocking, and adds 'Ln2 Tune' option to Tweaker's Paradise.
118 REPLIES 118
starlightknight
Linux user here. Can you provide a way to flash the new OLED/Aura firmware that does not require Windows? Is it possible to flash it off of a dos boot usb?
http://uk.pcmag.com/operating-system...om-a-usb-drive
Prereqs: >=16GB USB stick and another computer with Windows 10 installed.
Use a Windows 10 USB stick. I too am running Linux and that is how I upgraded to 9910.
Ljugtomten
Raja@ASUS wrote:
Please note, some boards have older firmware for the onboard OLED/Aura, which can cause some strange issues. To update to the latest version click here. Run the .exe from within Windows.
UEFI 0601 public release build.
Version 0601 is not the same as 9910 regarding reported CPU temperature.
In 9910, HWMonitor Pro 1.29 would report the same temperature for CPU as Ryzen Master, this is no longer the case:
66953
66953
I comfirm
E
0601:
Temp reporting is off as stated above. This shouldn't be public release with such a simple bug?
Still can't get a stable 3466 much less 3600 on memory.
Is this mobo already losing update focus already?
when is the next bios being released?
and what agesa version are we currently on?
Raja
0603 added to OP.
Raja@ASUS wrote:
0603 added to OP.
Can you specify what "RAID driver update" is referring to? Does this update the BIOS to configure raid from within the BIOS (For Sata Drives)
