Page 8 of 12 FirstFirst ... 6 7 8 9 10 ... LastLast
Results 71 to 80 of 116
  1. #71
    ROG Member Array
    Nov 2017
    Angry
    Quote Originally Posted by derrickmehaffy View Post
    Glad I haven't updated yet, ASUS pushed this build on their driver page as well, and I'm running 2x nvme drives raid 0 as my boot drive and would really rather not have to reinstall after updating. I'll hold off until something a bit better built comes out.
    If anyone has tried the update and maintaining the raid let us know. ASUS come on man I've seen much better testing being done, for a 500 Mobo without basic raid testing is pretty bad.
    I just checked the official BIOS page and you're right. They posted it up as official update (really ASUS?). There is a note on the bottom:
    NOTICE: If you are upgrading from beta BIOS 0801 and have a SATA/NVMe RAID configuration, backup your data and remove the array before updating to this build.
    It doesn't say if the RAID can be re-enabled (there was no option to anywhere) and reconstructed later. Just says backup data and remove RAID. How the hell does this happen? 801 has been around for a while and people have tested it plenty I think. If 801 was official I'd be OK with that. It's been through testing by people and for the most part it works. Yet, you post 804 firmware as official after it has been available on this forum for a fraction of a time 801 has been, doesn't fix jack, removes NVMe RAID, and who knows what other gremlins reside in there. What the hell?
    Unbelievable...
    The support for this board is dismal.
  2. #72
    ROG Guru: Yellow Belt Array Dimitrios1971 PC Specs
    Laptop (Model)GX700VO 1TB SSD + 64GB RAM
    MotherboardASUS ROG ZENITH EXTREME ALPHA
    ProcessorAMD Ryzen Threadripper 2950X
    Memory (part number)F4-4000C18Q2-64TZR (3333MHz)
    Graphics Card #1ROG Strix GeForce® GTX 1080 Ti OC-Edition
    MonitorROG Swift PG348Q Gaming
    Storage #14 x Samsung SSD NVMe 960 PRO 1TB Raid0
    Storage #24 x Samsung SSD NVMe 970 PRO 1TB Raid0
    CPU CoolerCOOLER MASTER MasterLiquid ML360 RGB TR4 Edition
    CaseROG Strix Helios
    Power SupplyASUS ROG THOR 1200P
    Keyboard ROG Strix Scope Deluxe & ROG Strix Scope TKL Deluxe
    Mouse 2 x ROG Chakram
    Headset ROG Throne Qi
    Mouse Pad ROG Balteus Qi RGB & ROG Sheath
    Headset/Speakers 1 x ROG Strix Go 2.4 & ROG Strix Wireless
    OS Win10_x64
    Network RouterFRITZ!Box 6660 Cable
    Accessory #1 BW-16D1H-U PRO
    Accessory #2 ROG STRIX ARION & Asustor AS6404T
    Accessory #3 2 x HYPER M.2 X16 GEN 4 CARD
    Dimitrios1971's Avatar
    Apr 2015
    74
    141
    From another forum--
    Code:
    Not fully up to date on this, but most likely due to updated UEFI AMD RAID module which would be a change from AMD's side and not ours. The updated version is not backwards compatible, was the same situation when NVMe RAID support was added, any existing AHCI RAID array got lost.
  3. #73
    ROG Member Array ManMountain PC Specs
    MotherboardAsus Zenith Extreme X399
    ProcessorThreadripper 1950x
    Memory (part number)Kingston HyperX Predator 32GB (HX433C16PB3K4/32)
    Graphics Card #1MSI GTX 1070
    Sound CardOnboard
    MonitorLG 34" Ultrawide
    Storage #14 x Seagate BarraCuda 4TB 5900RPM SATA 6Gb/s
    Storage #22 x SSD (120 GB OCZ, 250 GB Samsung)
    CPU CoolerCorsair H80i V2
    CaseCorsair Obsidian 650
    Power SupplySuper Flower Leadex II 850W 80 Plus Gold Modular
    Keyboard Microsoft keyboard
    Mouse Microsoft mouse
    OS Windows 10 x64 Enterprise
    Dec 2017
    11
    Another beta BIOS, version 0012 (Based on 0804 final). Posted by elmor (at ASUS) on another forum here.
    Addresses:
    A few more fan tuning and control issues should be patched in this test BIOS. PWM/DC seems to detect properly. I still get bad min fan speed detected after running Q-Fan Tuning, but way more seldom (2 times out of 50).
    Download here.
  4. #74
    ROG Member Array
    Nov 2017
    Quote Originally Posted by Dimitrios1971 View Post
    Code:
    Yup, I saw that. I can understand loss of RAID volume and having to recreate the array. I couldn't even find where to enable the NVMe RAID support lol. It wasn't in any of the menus I checked. I would format and start clean slate if the X4->X8 issue was fixed and I could recreate RAID, but the option wasn't even there. Without the option, there is no RaidXpert. Without RaidXpert, I can't delete volume. Chicken and the egg problem kind of if they require complete wipe to even show the option. I wasn't ready to risk it and delete array on 801 and go to 804. I may do it once I image the volume and can easily put things back the way they were without going through pain of reinstalling Windows and all the software.
    Edit:
    Update on this. 0801 was updated to a new AMD UEFI RAID driver, but we found it caused some issues when using SATA RAID. 0804 is downgraded to an older version which does not support NVMe RAID at all. Next BIOS will have this fixed, sorry for the confusion.
    I guess that explains a thing or two.
  5. #75
    ROG Enthusiast Array IvoSilva PC Specs
    IvoSilva PC Specs
    MotherboardAsus ROG Zenith Extreme
    ProcessorAMD Ryzen Threadripper 1950X Hexadeca-Core
    Memory (part number)G.SKILL F4-3200C14Q-32GTZ (4x8GB)
    Graphics Card #1SAPPHIRE Radeon™ RX Vega64 8G HBM2 Limited Edition
    Storage #1Samsung 960 PRO NVMe M.2 1TB
    CPU CoolerNZXT Kraken x62
    CaseThermaltake View 31 TG RGB
    Power SupplySeasonic Prime Gold 1000W 80+ Gold
    Keyboard Logitech G910 Orion RGB Spectrum Mechanical Gaming Keyboard
    Mouse Logitech G502
    Headset Sennheiser HD650
    OS Windows 10 Professional x64
    Sep 2017
    33
    From Elmor;
    Beta BIOS 0901 http://www.mediafire.com/file/8tp9l0...-ASUS-0901.zip
    Have not tested this extensively, let me know how it works for you.
    - AGESA 1.0.0.4
    - Fan fixes from 0012
    - UEFI RAID driver updated (and hopefully back on track)
    Source: http://www.overclock.net/t/1636566/a...#post_26499346
  6. #76
    New ROGer Array
    Jun 2017
    3
    strix x399 bios updates??
    Hey guys, just wandering if well see any love or beta bios's for the Strix X399 gaming board ?
  7. #77
    ROG Member Array CaptainFist PC Specs
    Processor1950X
    Memory (part number)F4-3600C16D-16GTZR
    Graphics Card #1Nvidia 780ti
    Graphics Card #2Nvidia 780ti
    Graphics Card #3Nvidia GTX 580
    Monitor3 x Asus VG236
    Storage #1Samsung 960 Pro
    CPU CoolerEK-Supremacy EVO Threadripper Ediiton
    CaseLian Li 8500D
    Power SupplyBeQuit Black Power 1200w
    Keyboard Logitech G19S
    Mouse Logitech G502
    Headset Razer TIAMAT 7.1
    Mouse Pad Logitech
    OS Windows 10 x64 up to Date
    Network RouterAVM Fritzbox 7490 / 6490
    Sep 2017
    24
    Quote Originally Posted by sam350 View Post
    Sure but not in the Thread for Zenith Extreme Beta UEFI....
    Elmor Posted Beta Bios 902....
    Compared to 0901:
    - AGESA 1.0.0.3
    - 1DPC SR M-die fix
    - Dropping DRAM channels fixed
    http://www.mediafire.com/file/d9xx4a...-ASUS-0902.zip
  8. #78
    OS Win10_x64
    Apr 2015
    74
    141
    thanks but I still remain in 0801.
    in 901 hate in cpu fan probeleme after 2 days
  9. #79
    Processor1950X
    CaseLian Li 8500D
    Mouse Logitech G502
    Mouse Pad Logitech
    Sep 2017
    24
    I am on 901 Best performance for me. Memory @3200mhz stable no freezes
    Cpu Fan is not needed here, Watercooler.
    Today i wil try my Raid Controller again because of Agesa 1.0.0.4
  10. #80
    OS Win10_x64
    Apr 2015
    74
    141
    I also have a watercooler but not like you have
    meanwhile have BIOS 0902
