Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    ROG Guru: Brown Belt Array davemon50 PC Specs
    davemon50 PC Specs
    Laptop (Model)Asus G752VY-DH72 (17") and Asus G752VT-DH74 (17")
    MotherboardAsus ROG LGA2011-v3 Rampage V Edition 10, x99 EATX
    ProcessorIntel Core i7-6950X Extreme 10-core 25MB Cache 3.0 GHz
    Memory (part number)Corsair Vengeance LPX Red DDR4 DRAM 64GB-4x16 3333 (CMK64GX4M4B3333C16R)
    Graphics Card #1Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Graphics Card #2Sapphire Nitro Radeon R9 Fury 4GB HBM Backplate
    Sound CardAsus SupremeFX Hi-Fi Audio DAC
    Monitor(2) Dell UltraSharp U2515H 25-inch monitors
    Storage #1(4) SSD's - Samsung 960 & 970 1TB M.2, Intel 535 480G, Intel 510 250G
    Storage #2(3) HDD's - Western Digital Caviar Black 2TB 3.5-in SATA III 64MB Cache
    CPU CoolerCorsair Hydro Series H80
    CaseCorsair Obsidian Series 650D Black, ATX, Mid Tower
    Power SupplyCorsair Digital AXi-Series AX1200i (1200W) 80+ Platinum Rating
    Keyboard Logitech Wireless K360
    Mouse Logitech Wireless MX Anywhere 2
    Headset HyperX Cloud II
    OS Windows 10 Pro 64-Bit
    davemon50's Avatar
    Apr 2017
    48
    1,126
    Quote Originally Posted by davemon50 View Post
    ...then I suspect either your pump block has failed (or in process of failing) or you have a cable problem...
    From my post above. It's speculation, but if you rule everything else out...
    Davemon50
  2. #12
    ROG Enthusiast Array
    May 2012
    42
    Think something is wrong with it considering the CPU header. So orderd a kraken 52x.
    CPU: i7 7700k
    GPU: EVGA 1080ti Kingpin
    Ram: GSkill TridentZRGB 2x8 3200mhz
    cooler: NZKT kraken x52
    Psu: EVGA G2L 850watt
    HD1: Samsung 840 EVO 256GB
    HD2: WDCB 1T
    HD3: WDCB 4T
    OS: Windows 10 64bit
    Case: HAFX
  3. #13
    davemon50 PC Specs
    davemon50's Avatar
    Apr 2017
    48
    1,126
    OK, good luck with the changeout, and remember to post results back to close the loop.
    Davemon50
  4. #14
    ROG Enthusiast Array DevBiker PC Specs
    DevBiker PC Specs
    MotherboardASUS Zenith II Extreme
    ProcessorAMD ThreadRipper 3970
    Memory (part number)8x16GB Corsair Dominator Platinum 3466
    Graphics Card #1EVGA 1080 Ti SC Black
    CPU CoolerCorsair HydroX Loop
    CasePhanteks Enthoo Primo
    Power SupplyCorsair HX1200
    Keyboard Corsair K95 PlatinumElite
    Mouse Corsair M65 Pro
    Headset COrsair Virtuoso
    OS Windows 10 x64
    Network RouterAsus RT-AC3200
    Mar 2017
    27
    I had the exact same problem. It's your pump. You should be able to RMA it through Corsair. In the meantime, get an inexpensive air cooler to hold you over while Corsair does their thing. The CoolerMaster Hyper 212 EVO has excellent reviews and is pretty inexpensive. And you can keep it on hand for backup should you have an issue again.
  5. #15
    ROG Guru: Brown Belt Array Vlada011 PC Specs
    Vlada011 PC Specs
    MotherboardRampage V E10 (BIOS 1903)
    ProcessorIntel®i7-5820K (4.5GHz 1.325V)
    Memory (part number)CMD16GX4M4A2666C15
    Graphics Card #1ASUS GTX1080Ti Poseidon
    Sound CardSound Blaster ZxR
    MonitorSamsung P2450H
    Storage #1Samsung 970 EVO PLUS 1TB
    Storage #2Samsung 850 EVO 1TB/WD Black 2TB
    CPU CoolerEK RGB Monoblock RVE10
    CaseLian Li PC-O11 WXC
    Power SupplyEVGA 1200 P2
    Keyboard Deck 87 Francium PRO - MX Brown DS PBT
    Mouse Logitech G900
    Mouse Pad Steeseries QCK
    Headset/Speakers CREATIVE T5900 5.1
    OS Windows 10 Pro x64 v1903
    Accessory #1 iPhone SE Space Grey
    Accessory #2 EK XRES D5 Revo 100 Glass PWM + CoolstreamPE 360
    Accessory #3 Noctua NF-A12x25 PWM x3 (radiator)
    Vlada011's Avatar
    Oct 2013
    21
    1,475
    My hardware is hot as well. GPU up to 85C if side panel is closed, CPU can't be overclocked more than 4.2GHz because H100 can't resist more.
    And I should easy to think about cheaper watercooling kit.
    That will have influence and on my new GPU model.
    EVGA 1080Ti FTW3 Hybrid I stay with AIO and CPU on 4.2GHz and it's not cheap.
    GTX1080Ti Founders temps and noise will force me to upgrade on watercooling soon as I can but need 120 euro for GPU block.
    GTX1080Ti Poseidon work on Air temps better than Founders but not amazing because it's design for water, I save 120 euro on waterblock but it's expensive same as FTW3.
    All other models will heat my case and I will need to open side panel as now and I didn't made progress.
    EKWB A240G kit is affordable and have nice waterblock for GeForce and CPU block but problem is aluminium radiators and kit is optimized for aluminum parts not copper, brass,...
    I'm really angry because price of hardware, when GTX1080Ti was launched everything looked that gamers will be able to build at least reference design with watercooling for 1000. Now only GPU cost and over 1000 euro for some models. Poseidon is exactly 170 euro more than in Germany, in my country. Insane and 120 more than in Hungary. That mean I lose EKWB X-Res Revo D5 100 + fittings If I buy Poseidon in my country.
    Most important and most expensive part of loop and best from EKWB at the moment.
Tags for this Thread
