Use on board sound card and creative sound blaster zxr together at same time?
armin_maleki
I have rampage v10 can I use on board sound card and creative sound blaster zxr with two speaker  together at same time?
My os is windows 10 enterprise x64
startekselva
you can't use both
Vlada011
Disable onboard audio in BIOS and than install Sound Blaster ZxR.
You have settings Advanced - Onboard Devices Configuration - HD Audio Controller - Disabled
Save and Exit.
If you had some Realtek drivers and software uninstall them before install new card.
You have Driver Cleaner Pro for cleaning Realtek files if some of them stay after uninstall.
Save and Exit.
thank you
