Results 1 to 6 of 6
08-21-2017 01:26 AM #1
- Join Date
- Aug 2017
- Reputation
- 10
- Posts
- 73
Do I need to connect both EATX12V power connectors?
I'm used to connecting just EATX and maybe one 12V auxillary power (on my SuperNOVA I assume that is CPU). But do I need to connect EATX12V_2 (the second one) as well? Or is that just for extreme overclocking?
08-21-2017 04:52 AM #2
- Join Date
- Nov 2014
- Reputation
- 10
- Posts
- 140
Great to see you sorted the socket problem^^
And yes manual says to ensure to connect both 8-pin power plugs.
Asus tends to add a lot new features now and then so I try find the
important bits in the manual on every new motherboard. Thou I maybe use
some time to find all the useful features.
08-21-2017 02:13 PM #3
- Join Date
- Aug 2017
- Reputation
- 10
- Posts
- 73
Thanks!
Where does it say that in the manual? The ATX power connection has just one of them plugged in? (the 24-pin and one of the 12V 8-pin connectors from what I can tell).
Anyway, I have both 12V 8-pin power connections plugged in and it POST'ed on the first shot! Go me!
08-21-2017 02:19 PM #4
It is a good idea to use both.
08-26-2017 01:47 AM #5
- Join Date
- Mar 2013
- Reputation
- 10
- Posts
- 32
You dont *have* to use both... I ran my system for several days with only one plugged in as I was still waiting for my new power supply. Having said this, you will see a warning telling you it could lead to overheating conditions. I had no stability issues or cooling issues whatsoever running this way. Having said this, I wouldnt run it full time like this. This thing draws a ton of power so it wouldnt surprise me if using only one would eventually lead to system instability.
03-07-2019 05:22 PM #6
js753 PC Specs Motherboard Asus maximus XI Extreme Processor Intel i9 9900k kaby Lake Memory (part number) cORSAIR VENGENCE DDR4 -32GB 3400 mhz Graphics Card #1 EVGA 1080 Ti Sound Card ASUS on board Realtek Monitor Samsun 27 inch Storage #1 Samsung SSD 1TB Storage #2 Samsung M.2 nvme 970 1TB , WD black 1TB, WD blue 1TB CPU Cooler Corsair 150I hydro series Case Phanteks Enthoo Luxe Power Supply Corsair 1200W Hx 1200i Keyboard Coraair K70 Mouse logitechG703 Headset/Speakers Orion legacy OS Windows 10 home Network Router TP link
- Join Date
- Aug 2018
- Reputation
- 10
- Posts
- 3
Thank you for a great answer that I was looking for.
This is for a maximus XI hero and I have a Maximus XI extreme, which
uses TWO 8 pin , not and 8 pin and a 4 pin. So I was concerned
Great information that I really needed.
Thank you so much!!
John
js753@comcast.net
PS good thing Corsair has the cable on the web site
could not find it anywhere else.
