08-21-2017 06:43 AM - last edited 3 weeks ago by ROGBot
08-22-2017 10:58 AM
08-22-2017 11:15 AM
UndeadStudios wrote:
Hi, looking at building a new pc next month to replace my ancient crosshair IV and was thinking about the same cooler..
I was wondering what the temp's you are getting with it are as there is no performance info out there at the moment for this cooler 🙂
Thanks
08-22-2017 12:06 PM
08-22-2017 12:07 PM
08-22-2017 12:46 PM
Thanks
08-22-2017 12:49 PM
08-22-2017 01:15 PM
panzlock wrote:
https://www.techpowerup.com/reviews/Noctua/NH-U14S/6.html
http://www.tweaktown.com/reviews/5434/noctua-nh-u14s-cpu-cooler-review/index8.html
http://www.tomshardware.com/reviews/best-heat-sink-haswell,3554-22.html
Lots of reviews of the NH-U14S. It's a very good cooler.
08-22-2017 01:28 PM
Yes, lots of reviews for the non threadripper version using an i7-3960X, an i3-7200k and an i7-4470k none of which are the cpu i'm buying 😉
I agree it looks like a good cooler but I was after temp's for the threadripper version on the 16 core 1950X as that's the cpu i'm buying and there is no temp's or detailed tests / reviews for the threadripper version 😉
08-22-2017 01:38 PM
