Results 1 to 7 of 7
    New ROGer Array
    Jul 2017
    5
    Red Light in Dimm 2
    Hi. My Maximus IX Apex Z270 has red light in dimm 2.
    I dont like this red color, because red color can men a failure.
    I have disabled Aura in motherboard, but red color continues.
    What can i do?
    New ROGer Array
    Jul 2017
    5
    more data
    My pc works correctly, but i dont like red color in Dimm 2.
    Actually there is Samsung 960 m.2 256gb. I also used a Samsung 960 Pro and red color continues.
    I tried both sides of Dimm 2, and red color continues.
    What can i do?
    ROG Guru: Black Belt Array Korth PC Specs
    Korth PC Specs
    MotherboardASUS X99 R5E (BIOS2101/1902)
    ProcessorHaswell-EP E5-1680-3 SR20H/R2 (4.4GHz)
    Memory (part number)Vengeance LPX 4x8GB SS DDR4-3000 (CMK32GX4M4C3000C15)
    Graphics Card #1NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Graphics Card #2NVIDIA Quadro GP100GL/16GB, 16xPCIe3, NVLink1 (SLI-HB)
    Sound CardJDS Labs O2+ODAC (RevB), USB2 UAC1
    MonitorASUS PG278Q
    Storage #1Samsung 850 PRO 512GB SSDs, 4xSATA3 RAID0
    Storage #2Comay BladeDrive E28 3200GB SSD, 8xPCIe2
    CPU CoolerRaijintek NEMESIS/TISIS, AS5, 2xNH-A14
    CaseObsidian 750D (original), 6xNH-A14
    Power SupplyZalman/FSP ZM1250 Platinum
    Headset Pilot P51 PTT *modded*
    OS Arch, Gentoo, Win7x64, Win10x64
    Network RouterActiontec T3200M VDSL2 Gateway
    Accessory #1 TP-Link AC1900 Archer T9E, 1xPCIe
    Accessory #2 ASUS/Infineon SLB9635 TPM (TT1.2/FW3.19)
    Accessory #3 ASUS OC Panel I (FW0501)
    Korth's Avatar
    Mar 2015
    152
    2,719
    Cover the LED with a bit of tape/plastic. I used a small LEGO piece for this in my rig, lol.
    [/Korth]
    ROG Enthusiast Array lufiron PC Specs
    lufiron PC Specs
    MotherboardMaximus IX Apex
    Processordelidded 7700k @ 5ghz 1.35v
    Memory (part number)gskill 2x16 3200 cas 14
    Graphics Card #1GTX 1080ti @ 2 ghz
    MonitorAsus ROG Swift PG279
    Storage #1960 pro
    Storage #2960 pro
    CPU Coolernoctua D15S
    CaseCooler Master 5 freeform
    Power SupplySeasonic 850w prime titanium
    Keyboard Logitech G810
    Mouse Logitech G502
    Jan 2017
    28
    53
    Have you tried this?
    New ROGer Array
    Jul 2017
    5
    HORIZON access
    Thank you Lufiron. I try your option, but light continues.
    Korth good idea.
    New ROGer Array Skunkfoo PC Specs
    Skunkfoo PC Specs
    MotherboardASUS ROG Rampage VI Extreme
    Processori9 7940x
    Memory (part number)64 GB G.Skill 3733 RGB
    Graphics Card #1Titan Xp
    Graphics Card #2Titan Xp
    Monitor3x ASUS PG278QR
    CPU CoolerEK Monoblock
    CaseThermaltake Tower 900 Snow
    Power SupplyThermaltake Toughpower iRGB Plus 1250W
    Keyboard ASUS ROG Claymore
    Mouse ASUS ROG Galdius II
    Headset Apple Airpods
    Mouse Pad ASUS ROG Sheath
    OS Windows 10 Pro
    Network RouterASUS ROG
    Sep 2017
    74
    Same issue on Rampage VI Extreme
    I hate that light on the dimm.2. On the R6E there are 2 jumpers for LED on the dimm.2 card that clearly say L_LIGHT and R_LIGHT. Unfortunately switching the jumpers don't do anything and the LED light remains.
  7. #7
    ROG Member Array
    Mar 2014
    9
    Those LEDs are terrible, so bad that I've contemplated desoldering the LEDs but I don't want to damage the DIMM.2 card or possibly short out and take my NVME's with it.
    I desoldered the red LEDs on my SB Recon3D; it was one the best things I ever did.
