Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    ROG Guru: Brown Belt Array Darnassus PC Specs
    Darnassus PC Specs
    Laptop (Model)G752VS -=-=- G750JX
    MotherboardASUSTeK COMPUTER INC. G752VS (U3E1) -=-=- ASUSTeK COMPUTER INC. G750JX (SOCKET 0)
    Processori7 6700HQ @ 2.60GHz -=-=- i7-4700HQ CPU @ 2.40GHz - 3.40GHz
    Memory (part number)2x16gb (M471A2K43BB1-CRC) -=-=- 2x8gb (HMT41GS6AFR8A-PB)
    Graphics Card #1GTX 1070 (8GB) -=-=- GTX 770M (3GB)
    Sound CardRealtek High Definition Audio / NVIDIA High Definition Audio
    MonitorGSync IPS 75HZ -=-=- Chi Mei 60Hz (Overclocked to 85Hz)
    Storage #1Samsung SSD 960 EVO 250GB x2 -=-=- LITEONIT LCS-256M6S
    Storage #2HGST HTS721010A9E630 -=-=- ST1000LM024 HN-M101MBB
    CPU CoolerStock -=-=- Stock
    CaseStock -=-=- Stock
    Power SupplyStock -=-=- Stock
    Keyboard Stock -=-=- Stock
    Mouse Razer Naga Epic 1st Generation
    Headset SPH 2500
    Mouse Pad Razer Goliathus
    OS Winblows 10 Pro -=-=- Winblows 8.1 Pro
    Network RouterCG3000v2
    Darnassus's Avatar
    Dec 2013
    61
    1,644
    M.2 Sata problem..
    Anyone know how I can make my M.2 Sata work/show in Windows?
    I'm on the OS using my HDD, what driver would I use to make it appear so I can format it and reinstall my OS onto it?
    As of now, it refuses to show up in Disk Manager.
    Gosh Blue Lady.. ❤
    JOIN THE ASUS T-SHOOT DISCORD <-- Clicky!
    ROG Guru: Green Belt Array haihane PC Specs
    haihane PC Specs
    MotherboardCrosshair V Formula Z
    ProcessorAMD FX 8350
    Memory (part number)Gskill F3-2400C10-8GTX
    Graphics Card #1ASUS HD 6950
    Storage #1WD Velociraptor 1TB
    Storage #2Corsair Neutron GTX 120GB SSD
    CPU CoolerCooler Master Seidon 120XL
    CaseCooler Master Silencio 650
    Power SupplyCorsair HX850
    Keyboard Corsair K70 RGB
    Mouse Logitech G500
    OS Windows 7 X64
    Network RouterLinksys E2500
    haihane's Avatar
    Jul 2013
    106
    615
    curious cat peeks head in, curious cat has no idea how to help, curious cat wants moar information.
    M.2 Sata brand and model?
    did the same M.2 work in other computer?
    no siggy, saw stuff that made me sad.
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,644
    Well it's the M.2 that comes in the laptop itself. I think it's a Toshiba THNSN5512GPU7
    Anyhow, I used to be able to just load a driver, and poof it'd appear during Installation.. but it's not doing it anymore.. it's corrupt or something.
    So I'm trying to access it from the OS, but it still doesn't seem to appear..
    Gosh Blue Lady.. ❤
    haihane PC Specs
    Mouse Logitech G500
    OS Windows 7 X64
    haihane's Avatar
    Jul 2013
    106
    615
    whoa. a drive that came with the laptop gone poof.
    pls pls pls try to access it with a different computer. you have one right? if not, beg favors from a friend to use his laptop or motherboard's m.2 and plug it in there and see.
    haihane PC Specs
    Mouse Logitech G500
    OS Windows 7 X64
    haihane's Avatar
    Jul 2013
    106
    615
    if he's suspicious about your drive, say that your drive contains the most wicked vile stuff ever known to man and in the space odyssey, that a mere plug into his motherboard would cause his pc to implode and create a mini blackhole.
    and you're asking for his help anyway!
    /joke.
    Banned Array JustinThyme PC Specs
    Laptop (Model)G752VY-DH72
    MotherboardRampage VI Extreme
    ProcessorI9 9940X
    Memory (part number)64GB DDR4 8x8 Corsair Dominator Platinum 3800 MHz @ C17
    Graphics Card #1ASUS Strix 2080Ti O11G @ 2.1GHz
    Graphics Card #2ASUS Strix 2080Ti O11G @ 2.1Ghz
    Graphics Card #3ROG Nvlink
    Graphics Card #4Have to feed animals
    Sound CardExternal Audioengine D1 24 bit 192kbps DAC
    MonitorASUS PG348Q @ 100Hz
    Storage #1Intel 905P 480GB U2 flavor
    Storage #2Samsung 850 EVO 1TB X2 in RAID 0, 960 PRO 1TB DIMM.2_1
    CPU CoolerHeatKiller IV PRO and VRM blocks ,Dual D5 PWM serial, 2X 480, 1X 360 RADS
    CasePhanteks Enthoo Elite 8X LL120 PWM, 3X LL140 PWM, 12 SP120 PWM 1x AF140 PWM
    Power SupplyCorsair AX 1500i
    Keyboard ASUS Claymore
    Mouse ASUS Spatha, Logitech MX Master
    Headset Sennheiser HD 700
    Mouse Pad ASUS ROG Sheath
    Headset/Speakers Audioengine A5+ with SVS SB-1000 Sub
    OS Win10 Pro 1809
    Network RouterNetGear NightHawk X10
    Accessory #1 NetGear Prosafe 10GBe Switch
    Accessory #2 Qnap TVS-682 NAS modded with I7 CPU
    Nov 2013
    144
    3,858
    During installation try using the intel IRST drivers.
    This isnt a driver for the SSD, its for the controller.
    Winraid has perhaps the best resource, better than intel!
    http://www.win-raid.com/t2f23-Intel-...QL-v-WHQL.html
  7. #7
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,644
    Quote Originally Posted by JustinThyme View Post
    Yeah I looked at that but I can't figure out which one to pick. Can you toss me a direct link?
    Gosh Blue Lady.. ❤
  8. #8
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,644
    Quote Originally Posted by haihane View Post
    Yap that's the big screw over.. I don't have any other way to access the NVMe..
    I need to find an NVMe type M adapter to plug into SATA or something, then I'd plug it directly in, format it through Windows Install then plug it back into the PCIe slot.
    Gosh Blue Lady.. ❤
  9. #9
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,644
    If anyone's able to help me out real-time, I have a Discord here.. https://discord.gg/MPq347V
    Is there a way to pick up the NVMe SSD and format it with LINUX..?
    G752 won't even launch Ultimate Boot CD.. ;f
    Gosh Blue Lady.. ❤
  10. #10
    Darnassus PC Specs
    Headset SPH 2500
    Darnassus's Avatar
    Dec 2013
    61
    1,644
    Can NVMe SSD's be mounted through USB / SATA? :f
    They're PCIe but, can it still work?
    Gosh Blue Lady.. ❤
