Results 1 to 9 of 9
    New ROGer Array
    Oct 2014
    7
    Cooling pad for Laptop GL502VM?
    Hi everyone,
    I got my Latop ASUS ROG GL502VM 2 months ago and I'm very satisfied with it.
    But I wanted to know if it worths it to get a Laptop cooling pad. I've been checking in forums and reviews and found mixed opinions about them. What eveyone seems to agree on is that they are more efficient with each laptop model.
    Is anyone who has this laptop has noticed any improvement by adding a cooling pad?. if so, which do you recommend it?.
    Right now my usual temperatures are:
    CPU
    Idle: 40/50C
    Gaming: 80/90C with peaks up to 95C
    GPU
    Idle 30/45C
    Gaming: 75/85C
    Room temperature: 20/25C
    If I lower the maximum processor state to disable turbo boost, the CPU temps don't go higher than 85C, but I'd like to be able to use Turbo Boost.
    Thanks in advance!
    ROG Guru: Yellow Belt Array StarJack's Avatar
    Apr 2017
    42
    187
    Quote Originally Posted by pepilo View Post
    Hi everyone,
    CPU
    Idle: 40/50C
    GPU
    Idle 30/45C
    Gaming: 75/85C
    Thanks in advance!
    I have used numerous cooling pads with my GL702VMK and I have found the cooler master notepal x-slim to work the best. It has one large 180mm fan and seems to cool my rig by about 2-3 degrees C more than any of the others which had 3 smaller fans rather than one large one. If you want more cooling, look at the Opolar LC06 heat vacuum.
    StarJack
    New ROGer Array
    Oct 2014
    7
    Quote Originally Posted by StarJack View Post
    StarJack
    Thanks!, I believe the Opolar LC06 (and all those kind of vaccuum cleaners) is meant for laptops with side ventilation and mine has them in the back. The CM notepal X-slim II seems a pretty good option. Thanks!
    Cheers,
    Apr 2017
    42
    187
    Cheers,
    I use two of them and they definitely help.
    New ROGer Array
    Oct 2014
    7
    Oh, that's great!, I wanted to buy the opolar but tought I couldn't use it becase the screen covers the airvents a bit when you open it, I'm going to check them out then.
    Thanks!
    Oct 2012
    128
    the vacuum won't fit because you said it, the screen lid blocks part of the vents.
    This is what I use when I need extreme cooling.
    It has legs that can tilt the fan up when lying on a table.
    like this.....
ID:	66835 Click image for larger version.
  7. #7
    New ROGer Array
    Oct 2014
    7
    Quote Originally Posted by link626 View Post
    like this.....
    Thanks for your suggestion!, that would truly put some air to the laptop!, but I move around a lot and need a more "portable" solution.
    That reminds me when I had my old AMD K6 II and in summer I had open the case and put a fan on the side to throw some air at it so it wouldn't shut down )).
    Cheers,
  8. #8
    Apr 2017
    42
    187
    Cheers,
    The Opolar does not fit perfectly but it does work. It drops my temps during gaming by approximately 6 degrees. It is the difference between 78/79C in PUBG or 72C (in my case). I have 3 other friends with GL702VMs and they all use an LC06 and swear by it.
    Here is a close up of the Opolars and lid:
    StarJack
  9. #9
    New ROGer Array
    Oct 2014
    7
    Yeah, the Opolar should fit, actually in the questions in Amazon there's a few who ask about this Laptop model and the manufacturer confirmed it does fit. Also it should be very good for the latop because it would prevent the hot air to go to the laptop's screen.
    I ended up undervolting my CPU following this thread:
    https://rog.asus.com/forum/showthread.php?89061
    and using a cheap cooling base I had for my work laptop and the temps decreased significantly, almost 10C while gaming. So for now I won't be buying any cooling solution.
    Thanks for your help!
Tags for this Thread
